Question about Microsoft Works 8.0 for PC
M/s Works 8.5 labels printing blank fields
Running Works 8.5 ( on Vista). On labels and mail merge all set up and working EXCEPT that the Blank fields are also printing on the labels.
How do I stop printing the blanf fields???
This didn't happen on an earlier version of Works
MIKE W
  • 78 Answers
When you choose print there is a Mail Merge option that says "Don't print lines with empty fields" (company name, address line 2, etc.). check this box before sending to printer
Posted on Mar 21, 2009
When using Mail Merge, how can you make Word 2007 ignore any Blank cells in Excel 2007?
  • Open the Microsoft Excel 2007 spreadsheet file on your computer that contains the blank cells that you want to merge.
  • 2
    Use your mouse to select the adjacent blank cells that you want to merge together. The cells you want to merge should then be highlighted in blue.
  • 3
    Click on the "Home" tab and then click on the "Merge and Center" option from the "Alignment" group. The blank cells will all be merged and centered.
  • 4
    Click on the arrow next to the "Merge and Center" option and then click on the "Merge Across" option if you don't want the blank cells centered.
  • 5
    Select the merged cells and then click on the "Merge and Center" button again at any time to split the cells.
  • Mar 07, 2011 | Computers & Internet
    NEED TO KNOW HOW TO PRINT MORE THAN 1 ENVELOPE AT A TIME. DO LETTERS AND ENVELOPES ONCE A WEEK BUT THE PRINTER WOULD ONLY PROCESS 1 ENVELOPE AT A TIME AND I HAD TO DO THAT ONE MANUALLY.
    Hi there !
    For printing bulky letters or documents of the same format, I suggest you use the MS word mail merge document. You need to set up the mail merge document and the data of the file. For examples, the list of names, addresses telephone numbers and others should be input to the envelops.
    Here's how to create mail merge document file.
    1. Open a new blank MS word document or if you have a format already in a MS word format, just use it as default letter.
    2. Go to menu bars (Home, Insert, Page Layout, References, Mailing, Review and View) and choose Mailing.
    3. From Mailing, click on select recipients, choose use existing lists and find the excel document files that stores all the information like list of customers, company names, addresses, telephone numbers and others.
    4. Open it and select table will appear and just click ok to merge it automatically to your default envelope.
    5. Now you need to set up or format your envelope. from the Mailing menu, Insert Mail Merge Field will appear and click it to display the headings of your data source. Put the headings wherever you want.
    6. After that, press preview result to display the datas. Save your work and it is finished
    7
    Jan 06, 2011 | Lexmark X 546dtn AllInOne Laser Printer
    How do I print just one mailing label without running through an entire sheet time I print using an Epson LQ-590 and printing from the mail merge option in MS Word (MS XP)? In other words, when I print...
    I assume you are using a sheet of labels, such as the typical 3 x 10 sheet. Word sets up the mail-merge document for printing the whole sheet, so if you print just one or two labels, you will `waste' the rest.
    One way of using that sheet over is to create a mail merge that contains blank `dummy' addresses. It is rather involved and at best time consuming, and considered not worthwhile to save a partial sheet.
    I service printers, and personally do not recommend that any label sheet be re-used. The printer curls the paper, in some cases fuses it, and causes the corners of the labels to be exposed, and possibly get caught in the printer (I have removed a lot of labels from inside printers)
    Oct 18, 2010 | Office Equipment & Supplies
    Intermec PC4 is skipping over blank labels when it prints. It prints one label then skips over 3 or 4 labels before it prints the next one
    Make sure that the label is not larger than the printable area, carriage returns and spaces count as part of the label too. Also make sure that in the printer properties you didn't set the page width wider or higher than the actual label. Especially using MS Word, you may have to adjust the label slightly smaller to compensate for margin, header, and footer settings. Also be careful of mail merges which merge data larger than the viewable area on the label.
    Oct 02, 2009 | Intermec Office Equipment & Supplies
    I am having problems with a mail merge for tent card 5302 - can someone tell me how to merge an exisiting excel document into word?
    In Word 2003:
    Open the Tools Menu >> Letters and Mailings >> Mail Merge.
    Select Labels and click Next
    Click on Label Options and select your tent card and click OK and then Next
    Select Use Existing List and click Browse to find your Excel document. Click Next.
    Add in the fields you want on your cards to the first and then click Update All Labels.
    Finish Mail Merge Wizard.
    -- Word 2003 doesn't come with the 5302 label template. You'll need to download that from http://support.microsoft.com
    In Word 2007
    Select Mailings from the menu list at the top,
    Click on Start Mail Merge and select Labels
    Select Label vendor Avery US Letter
    Select your product number 5302 and click OK
    Click on Select Recipients from the top and select Use Existing List to browse to your Excel document
    Using the buttons on the top for Address Block/Greeting/etc add in the fields you want to the first label.
    Click on Update Labels
    Click on Finish and Merge
    Apr 28, 2009 | Computers & Internet
    Printer will print everthing but labels from Word mail merge
    did you set up a lable templete for the lable???
    when yo do amail merge, you need to go through the trouble of seting up a mail label templet in accordance to the label you are going to use.
    Dec 11, 2008 | Kyocera Mita KM-2050 Printer
    Printer keeps printing blanks...
    We have found a reset that we use.
    We unplug the printer and then we hold down the feed button and we keep holding down the feed button while we plug back in.
    It goes through some sort of a reset and this sometimes works.
    Jan 23, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
    This is where I get stuck in trying to make Labels in Microsoft Works
    Create a mail merge label with the Address Book
    On the File menu, click New.
    In the Works Task Launcher, click Templates.
    In the Letters and Labels category, click Mailing labels.
    Click Use this style.
    In the Labels dialog box, click Mailing labels.
    Click OK.
    The Label Settings dialog box appears.
    Under Printer Information, click the option for the printer you are using.
    Under Label Information, select the label product and style.
    If you're seeing 30 of the same label, try adding <<Next Record>> to the beginning of each label (including the < > characters as shown). If you need more help please simply reply to this by posting comments, and I'll be notifited right much faster than happening across a request for help by chance; the system will send me an e-mail to make me aware of your comments.
    Hope this will FixYa!!!
    Thanks,
    Aimiel
    Jan 05, 2008 | Microsoft Works 8.0 for PC
    How to create mailing labels in Microsoft Works
    With a Microsoft Works Word document open, select: Tools>Labels>(the list of available label types will pop up, select the label sheet you're using) then select: Tools>Mail Merge>Open Data Source...
    Don't know how it could be simpler.
    Dec 18, 2007 | Microsoft Works 8.0 for PC
    Microsoft Works 8.0 for PC Logo
    130 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
