Question about Gateway Computers & Internet
Can't recognise my Hard Drive with a USB to IDE cable.
I have a WD2000BB, Western digital hard drive 200 GB. I have it attached to a USB to IDE cable. Im trying to ''save a friends bacon''. I am fairly certain the HD is still operational. I can't seem to be able to initialise the disk. Also, it is only recognised as a mass storage device. I can't assign a drive letter to it either. I always hear how easy it is to hook up a USB to IDE and retreive data.... Of course Im not finding that to be so. I have trying switching the jumpers, I have it hooked up to a 400w power supply, tested with a power supply tester and its checking put fine. I ve hit every combination in the disk managment utility. Ive tryed Acronis and Get My Data Back, neither ''sees'' the drive. Ive switched the jumpers from CS, to SL, to MSTR. Is there any more steps I can take other than throwing the HD in the trash or telling my friend that it'll cost 800+ from data doctors? Thanks
  • 447 Answers
Aside from what you're trying you can also use ubcdwin4 to create a boot cd which may give you access to the data on your friend's hard drive (with network support for copying the data to another PC), it might be worth a look.
As far as your WD is concerned, if you have the ability to remove the drive from it's external case and plug it into the system via the IDE plug you may have better luck. You may also want to try changing the bios in order to boot from USB device and plug the WD into one of the USB ports.
Posted on Feb 22, 2009
Turn into usb drive
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.09 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
Wd50000aakb make into a external usb
AU $8.10 free postage worldwide
Have a Gateway computer with WD2000BB HD. Want to put in a larger one will a WDBAAV50000ENC-NRSN work?
Generally, the concerns you would have when getting a new HD are...
A) Does your case physically have an open slot for it? B) Does your particular computer model have the correct connection for it i.e. IDE, SATA, etc. C) Which OS you are using because this could have limitations on your partition size.
Jul 17, 2011 | Western Digital Caviar WD2000BB...
Wd drive PATA wdc-wd2000 jb - 00fua0 should be a 200 gb drive. said was running out of space and when checked found drive was only reporting it's size as 31.49gb. have tried everything I can think of to...
Check the hard drive for partitions, it could have several partitions, but only the first partition has been formatted.
Go to Control Panel - Administrative Tools - Computer Management - click on Disk Management and look at the Western Digital it could be Disk 1.
If you see unallocated partition, you can create and format this partition.
OR
You can delete the existing partition and create a single large partition and then format this partition.
NOTE - this process will delete the existing data on the hard drive.
Dec 16, 2010 | Western Digital (WD2000BB) 200 GB Hard...
Wd2000JB formats as a 20GB drive, whats wrong?
3 things to verify.
1. Check if there is any other jumpers other then the salve one or master.
2. Get in the computer management. Go in the control panel/ Administrative tools/ computer management. once there click on disk manager and see if it is actually a 20 Gig partition instead of 200Gig.
3. the drive might be defective in that case go on the Western Digital website and download the utility to test your hard drive.
WD support area for WD2000JB
Oct 29, 2010 | Western Digital (WD2000BB) 200 GB Hard...
2 x 500Gb HDD's no longer recognised. IDE not SATA. They were recognised until 3 days ago. I swapped one for my 85Gb HDD that contained my operating system (XP) and neither has been recognised since. 80Gb...
Good day!
Did you try to use another IDE cables?If not,please find some IDEs there and try it.You can also use another PC and try the said HDD just to recognize it.or try to swap it in the IDE1. See if its work.
mastergani
Jul 06, 2010 | Western Digital My Book Essential Edition...
200gb drive registers as 2000gb when I try to format
why not either rename this drive at the correct size or format and partion etc,
If the drive shows 2000GB then why not put some stuff on it say 300GB and if its a 200GB it will give you a FULL message once it reaches 200GB
May 27, 2010 | Western Digital (WD2000BB) 200 GB Hard...
Western Digital HDD Recognise as 0.0Gb
does this HD have an operating system installed on it ?, check the IDE
connection sometimes the IDE cable degenerates or is simply not fast enough for the drive , get back to me I'll help if I can
Jan 11, 2010 | Western Digital Caviar 40 GB Hard Drive
Vista OS computer does not see WD400 connected externally via USB to IDE cable.
Purchased a USB to IDE cable. Looked like it was communicating with the hard drive (WD400) my computer did not see the drive. (Vista OS).
Western Digital customer service recommended that I change the jumper pin to position #4 on the hard drive and install inside the computer as a an additional slave drive.
Worked perfectly.
Oct 08, 2009 | Western Digital Caviar 40 GB Hard Drive
Computers & Internet Logo
102 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
