Question about Philips DVP5140 DVD Player
Remote code of BPL TV model FQR 21
Hi, anyone can hep me for let me know the remote code of BPL TV model FQR 21 ( India) . Remote Conrol Model - RC-614.
BR
  • 9 Answers
SOURCE: jumbo universal remote
I found that on the back of the 2205 it said that the unit was made by Funai. I looked in the Innovage book and found that the codes for Funai DVD are 231 and 233. 233 worked on mine. Good luck.
Posted on Jan 06, 2008
  • 9 Answers
SOURCE: Remote code for Magnavox ZV450MW8A
I found that on the back of the 2205 it said that the unit was made by Funai. Check the back of the unit and find if it lists the maker
  • 230 Answers
SOURCE: universal remote magnavox model # CL034
here you go
http://www.universal-remote.net/philipsmagnavox.html
Posted on May 15, 2008
IrishDruid
  • 2712 Answers
SOURCE: Remote control codes for Symphonic tvcrg13
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 19, 2008
  • 138 Answers
SOURCE: remote codes
Contact Direct tv and they should have the codes to program the remote tothat tv. Or contact Universal remote @ 919-573-7854 919-573-7854
Posted on Aug 19, 2008
My ctv is bpl fcv23ca1 21 inch what is the remote model for this tv model ?thank u
Remote that work with this TV can be purchased from open electronics spare part market. or online. Look for some advertisements in Google. There are universal remote controls too, that can be set with setup codes. The setup code list and setup procedure is too much to type in here. If you wish to get more details visit the sites linked here. http://electronicshelponline.blogspot.com/
http://electrohelponline.blogspot.com/
Feb 23, 2017 | Televison & Video
Sir I have loss remote of BPL TV model no. FWR 59WA1.plz tell me which no remote applicable for that tv.
Umesh, Check the attached links, the remotes may be what you are looking for, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
MEPL BPL TV REMOTE Model ISORT JXPSE compatible
Compatible BPL TV Remote No RC 66RL 33RL
Jun 16, 2016 | Televison & Video
Bpl fqr 21
in home theater use pro logic mode
Apr 18, 2014 | Televison & Video
I lost my TV remote .BPL MATRIX FER-21 Flat Screen The remote is not available . Can u suggest a remote which I can use for the above mentioned TV
Since there is no such thing as a universal remote, get the model numbers from several in any department store and go to the manufacturer's website and check for your TV model to make sure it is covered. I checked on remotes.com but your set wasn't found so if you have made an error in the model number, correct it and go their to search for your remote.
Feb 02, 2011 | Televison & Video
I want the remote controller model number for the bpl tv 21 fst model
hi chalapathi4a, i too having BPL FST21 model. When my dad purchase this TV he didn't get the remote control. Is this model having remote control? Please let me know. If this model comes with remote control then i will also try to get the remote control for my TV.
Oct 29, 2010 | Televison & Video
Ihave a bpl TV with model FTR 21 my remote is not working can i get the original one if available how much the cost of remote control
hi, can u please specify the number on your previous remote,
plz, becoz i have brought the same tv from our relatives and lost their remote. now i want to buy new remote for it, but i dont know the remote code,
please mail me the number plz plz plz to my email.
crazyabtu2000@yahoo.com
Aug 03, 2010 | Televison & Video
MY BPL TV SHOWS TU OR TV LOCK,AND FN BUTTON IS NOT WORKING HOW CAN I UNLOCK IT
Sep 13, 2009 | Belkin S-VIDEO CABLE 16 FT.
BPL TV MODEL FQR 21 don't start due to moisture
i have a cpu but my monitor has been broken so i wanted to connect my Bpl feb 21 tv can i?
Sep 09, 2009 | Televison & Video
I Have a TV BPL 21 FCR
hi friend,
i too having the same tv BPL - 21 FCR,
i have brought it from my relatives, and they lost their remote years back, and now i want to buy that remote, can u please tell me the remote model number which will be printed on your remote panel.
especially on your remote only...
plz help me, with this problem.
thank you in advance...
please send me the number to my email id
Jul 21, 2009 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
TV repairs
you 15in1universal remote his code 162 made india.
Jun 09, 2008 | Televison & Video
Philips DVP5140 DVD Player Logo
942 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
