Question about Whirlpool GU2400XTP Built-in Dishwasher
Model gu2700xtss1, upper rack not clean at all,
Whirlpool model gu2700xtss1, upper rack not clean at all, possible upper sprayarm problem, intermittent success with dry cycle, sometimes it works and sometimes it doesn't Help! This dishwasher is barely 1 1/2 years old
  • Anonymous Apr 07, 2009
    upper rack does not clean, sometimes lower also, not sure on age, 5, 6 years? kitchen aid, stainless steel.
I am here for the exact same reason. Mine is less than 3 months old. This may be a recall item. I bought, and paid more for a kitchen aide for the name and reputation.....Where can I find the model number?
Posted on Feb 22, 2009
  • carlfeas Jul 07, 2011
    This website is a bunch of BS advertisements not helpful
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Not effectively cleaning. Especially the upper glasses rack. It successfully runs through the whole cleaning cycle. I suspect it is the water pump or something clogging the path from the pump? It is only 2...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 26, 2011 | Whirlpool 24 in. DU1100XTP Built-in...
The upper sprarm will not spin. Plenty of water and sprayarm is clean. I know this model has a setting for upper rack alone, but spray arm sill not spin in that cycle either. Any help is appreciated.
heatman101
Apr 21, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Dishes bottom rack are marginally clean. upper rack is never clean anymore. The dish washer cycles through NORMAL and Dries dishes OK. Motor is running, and rinsing can be heard as well as washing cycles....
Just fixed my Frigidaire. The outboard o-ring on the main pump became distorted and stretched. Check your local hardware store as Frigidaire wants $17.50 + shipping. Good luck
Dec 25, 2009 | Dishwashers
Most of the time it takes two cycles to get load dry
Sounds like an intermittent fault on the heating coil (or possible intermittent pilot failure). Or thermostat out of calibration (but I doubt that last one is likely)
This fault sounds a bit dodgy and I'd recommend getting a qualified appliance serviceperson to troubleshoot this.
May 10, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
The upper sprayarm flows water but does not turn. Therefore dishes in upper rack are not geting cleaned.
i have a kenmore elite dishwasher model 665.16059400, i need a lower spray arm nut, nobody can find this part, i've been to sears and also to their on line parts department 3 times and have come up empty, the last time i was assured that the nut would be included with a new spray arm if i ordered one, it was not,i know the spray arm was made by whirlpool, is there anyone out there who knows the solution to this simple problem? does whirlpool have a cross referance model number i can use to find this part
Apr 29, 2009 | Dishwashers
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Dishwashwer not cleaning properly
You can try one of the cleaners sold for this purpose like glisten, dishwasher magic or jetdry dishwasher cleaner. It may not be getting enough water due to the fill valve clogging up. You can check this by small amounts of water slowly with a cup in the wash cycle and quickly opening the door to see if the upper sprayarm is turning. If more water helps you need to replace the valve.
Apr 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
327 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
