Question about Lexmark Nascar Craftsman Truck Series: Daytona 250 All-In-One InkJet Printer
Lex 3300 won't print. We checked all the power cords and also did turn off and later restart both computer and printer. Also can't get rid of one print job in queue.
  • 34 Answers
  • Okay, so I go to the Lexmark web site.This is the page where you download the files you need. (Either becauseyou've lost the original CD, or because you want a more up-to-dateversion.)
  • Choose inkjet printers
  • Choose Z705
  • Choose the operating system you have (such as Windows XP)
  • Click on the file and choose Download and Run
  • The program will unpack into a folder on your hard disk, then run to install the printer.
SET UP UR PRINTER N TRY TO PRINT
RAHUL
Posted on Feb 22, 2009
Had paper jam and now green lite keeps flashing
hi
Power light is blinking, Resume light is off c00122996.gifc00122990.gif Cause
The product is receiving information from the computer, in the process of printing, or completing a print job.
Solution
Wait for the product to finish printing, and if the light continues to blink after several minutes, try one or more of the following solutions:
  • Restart the product.
    1. Press the Power button to turn off the product. If the product does not turn off, disconnect and then reconnect the power cord.
    2. Press the Power button to turn on the product, and then try again to print.
  • Restart the computer and the printer, and then try again to print.
  • Try another power cord.
  • Try connecting the product to another computer. If the product prints, then there might be a problem with your computer, the software, or a device conflict.
Sep 12, 2011 | HP DeskJet 697c InkJet Printer
My canon MX340 won't print, saying there is a printing error 5200. I tried unplugging the printer and turning it off, but it still won't work
I will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see if that fix the problem.
Jul 11, 2011 | Canon PIXMA MX340 Wireless Office...
My computer says the printer is ready to print but when you try to print it won,t print and stores the document for printing later.
try to restart the print spooler from services.msc
start>run>services.msc look for print spooler then restart it
see if that helps
Mar 24, 2011 | Dell 725 InkJet Printer
Paper jam
Hi Good day!! Follow this method to remove your paper jam:
1. Check to make sure that the power cord is securely plugged into an active wall outlet if your printer is not turning on.
2. Make sure that the USB cable connecting your computer to your printer is securely connected if your printer powers on but will not perform a print job.
3. Remove a paper jam if the "Check Paper" light on the front of the printer is blinking. To do this, first turn off the printer and unplug the power cord from the printer. Open the front cartridge door and locate the jammed paper. Gently pull the jammed paper toward you. Plug the printer back in and turn it back on.
4. Connect your printer to a different USB port on your computer if you are experiencing slow printing. The slowness could be due to a connection problem with your computer's USB port. After you've switched the port, try your print job again.
5. Make sure that a phone line is securely connected from a phone jack to your printer if you are having trouble sending or receiving faxes.
6. Clean the scanner surface if your scans are blurry or have vertical white or black lines. To do this, spray the a soft, lint-free cloth with a mild glass cleaner. Wipe the scanner glass with the cloth and then dry it with another clean lint-free cloth.
7. Hard reset the printer if you are having trouble solving your problem. Turn the printer off and remove the power cord from the wall outlet. Wait at least 15 seconds and plug the cord back in. Power the printer on and try your job again.
8. Restart your computer if you can't solve your printing or scanning job. Sometimes restarting the computer can solve an unseen problem.
Don't forget to vote thanks!!!
Oct 28, 2010 | HP PSC 1510 All-In-One InkJet Printer
My printer will not print. When you check the status of the document it says printing. When you cancel that it doesn't cancel. DAYS later the document prints all by itself. What's that about?
It's because the print queue is saved on the printer's flash memory. This happens when you don't cancel the queues properly or terminated improperly. To get rid of the issue, always try to give the command slowly and don't over load. If you are printing photos, try to make the file size small so that it'll not take long to spool and prepare for printing.
When the problem occurs, so as follows:
Cancel the queues from the print status box ("Cancel all documents"), if they are not cancelled, then turn off the printer (directly unplug the power cord from the printer), it you still see the printing status, keep on cancelling until everything's gone.
If the problem persists, restart your computer. Definitely the problem will be fixed.
It's also important to press the cancel button while the printer powers On.
Good luck.
Thanks for using FixYa.
Aug 11, 2010 | HP Officejet 5510 All-In-One Thermal...
Hi - I have a HP Officejet Pro K5400 printer. That printer & my Dell Optiplex GX620 was left on during a 2 week office absence. When I returned the blue ink cartridge indicator light was blinking and...
Please follow the steps in the order below and check.
1. Make sure the product is on, and then disconnect the power cord from the product.
2. Disconnect the USB cable from the product, and then disconnect it from the computer.
3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
5. Reconnect the power cord to the product.
6. Press the Power button to turn on the product.
Now perform these steps on the computer...
(1) Click "Start" > "Run".
(2) Type "services.msc".
(3) Click "OK".
(A window will pop-up with so many services listed)
(4) Locate and Right-click "Print Spooler" entry and Select "Restart" from the drop down menu.
(5) Now please restart the computer.
now please print and check
May 20, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
Both the orange and the green lights are blinking and printer will not print.
The printer is waiting to receive a document to print. Choose the print command from the software program that you are using.
Wait for the printer to complete the current task.
OR
If the printer continues to blink after several seconds, follow these steps:
    1. Turn the printer off, and then turn it back on.
    2. If it does not turn off, unplug the power cord from the back of the printer.
    3. Unplug the power cord from the power source. Wait 30 seconds.
    4. Plug the power cord into the back of the printer.
    5. Plug the power cord into the power source.
  • Restart the computer and the printer. Try printing again.
  • Make sure there is a direct connection from the printer to the computer. Remove scanners, switchboxes, and so on.
  • Try another cable.
  • Try connecting the printer to another computer. If the printer prints, then the problem was with the main computer, possibly a software or device conflict
Aug 11, 2009 | HP DeskJet 5550 InkJet Printer
Canon mp210 problems print spooler error
Hi wolst, try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Oct 14, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Printer not printing
ok..disconnect from computer..try restarting with hard power down(unplug from wall)..
turn on again..try to do a test page from front panel
Aug 18, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark Nascar Craftsman Truck Series: Daytona 250 All-In-One InkJet Printer Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
