Question about InFocus User guide, LP500 / 530 Projector Lamp
Broken glass inside infocus 530
Hi
i have a infocus 530 .
when i start it up i hear a cranking noise.
i am trying to open it up to see what's making the
noise.there seems to some sort of broken glass inside.i cheaked the lamp but that seems to be ok.
saket
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
If i had to guess i'd say you colorwheel is gone.
Posted on May 27, 2010
I instaled a new bulb after the projector took a bit of a fall, Now i have a shodow around images on the screen, How do i get rid of them please ?
hi
if the projector has been dropped, chances are that the optics inside would have got shifted / broken.
you ned to open the optical assembly to do a quick check
you may also shale the projector before opening, perhaps u will hear broken glass noise
if you are lucky, you may have to just refit the reflective glasses back to its original place
Jan 18, 2013 | Sony VPL PX20 Multimedia Projector
I have an infocus x3 projector and while watching a movie i heard a loud pop and the video went out. It sounds like glass moving around inside the projector. its fairly new and in a well vented room. Is it...
yes try to check the bulb if broken but when you replace the bulb be sure not to touch the glass surrounding because if accidentally touch the glass their will be a mark appearing on the screen.
Jun 29, 2011 | Televison & Video
No light
HI
PLEASE CHECK LAMP MOST OF TIMES FUOND BROKEN
Sep 06, 2010 | InFocus LP 530 Multimedia Projector
When I turn off my Samsung DLP it makes a pop and a sound like ''Glass breaking'' about 1 to 2 seconds after the picture and sound has stopped.
Hi,it sounds like its the lamp,when it goes out lamp will pop and you'll hear glass inside of it.Make sure you get the original Philips lamp.Also check the color wheel here;s how to take it out: http://guides.fixyourdlp.com/samsung/bp96-01579a.php It might be that color wheel is broken and that's why you hear glass breaking because it might still spin broken.God bless you!
Sep 30, 2009 | Samsung Televison & Video
Round black spot in middle of the picture/screen
Hi :-)
The round blotch your seeing on the screen is the melting of an acrylic lens inside the light engine. Its a design flaw which unfortunately Infocus will not stand behind. To fix this problem requires opening the light engine and putting an equivalent lens in place. This task is very involved, but this problem is repairable and you need a glass smith to cut the right size lens from the original.
Sep 23, 2009 | InFocus ScreenPlay 61" Rear Projection...
Manual close for sunroof
You can try cleaning and lubricating the runners. The sunroof will open as soon as it is obstructed, eg. A childs arm in the way of closing. The problem here is that you can hear the motor running, wich indicates a broken cable, or a stripped plastic gear.
Apr 30, 2017 | 1996 Audi A4
REPLACIND DRIVER SIDE WINDOW REGULATOR
Pull out window crank and door handle, remove panel, remove plastic Nylon that's between metal and panel, crank the window down enough to see the arm and the part that connects with glass. Make sure the metal part inside the door that comes from an arm and attaches to glass is clean, from broken glass and the gap that attaches to window is clean,bend the new glass to make it fit inside the opening slide down the new glass from the top using opening guides, grave it from both sides standing in between and make land on top center of the part that graves the glass, put automotive glass silicone on center of that part,just at where graves the glass, let dry, put the plastic back the door panel the window crank with the "U" shaped lock washer and the door handle, I hope I was clear
Jan 21, 2009 | 2004 Chevrolet Silverado 2500HD
Noise inside the front passenger door
could be a perished rubber in the window track or surrounding glass horizontally
May 28, 2008 | 1998 Nissan Altima
In24in26
If you're getting a black and white image with or without source, it's probably the color wheel. Do you hear anything loose inside the projector? if you do it's the glass fragments of the broken color wheel.
Jan 06, 2008 | InFocus LP70+ Multimedia Projector
127 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
