Made buzzing sound error code Ld appeared I checked hose but it keeps buzzind and will not drain
It is a common fault that the drain fails to work in
most machines in a period of time and is the most problematic fault in a
washing machine. In all occasions it is important that your observation is most
important and so is vital to the identification /rectification and solution. If
you have noticed that water has leaked then as the drain hose pump/valve and
fittings are located on the underside of the machine it is important that you
look for possible leaks here. In some cases the drain hose would be clogged at
the drain end to outlet of the house and so there will be back flushing
resulting in overflow to the outside. Also the drain pump/valve can be clogged.
Now remove the drain hose clamps and remove the drain pump/valve, clean the
drain pump/valve, use back flushing to clear off all dirt. Now test using power
to see if this works and can be simulated. When refitting, the hose must be tightened
properly. If the pump/valve does not work even with power then it must be
replaced. If there is intermittent power
to the drain valve/pump then the program controller unit is a suspect. Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp Finally the washer must be placed with a tilt- use a
spirit level- so that all water will drain to the outlet port and thereby there
is no residual water remaining. Replacing the pump on a Bosch machine, please check
this link for tips:
SOURCE: Ob and LD error codes
hello there..
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
SOURCE: Cabrio Washer LD error code
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping. Hope this helps.
SOURCE: LD error code appears on maytag nepune washer
Roz,
You have some kinda something stuck in your drain pump. The computer that controls your washer has detected that it's taking too long to pump out and therefore refuses to spin.
Now this will take alot of work, but it'll save you a couple hundred, OK? First you have to get as much water out of the washer as possible. Fortunately on the Maytags you can do this fairly easily. Use a garden hose and connect it to the end of the drain hose (from the washer)... use duct tape to secure it. Then run the garden hose outside and make sure it's downhill. Now take the corrugated drain from your washer and lower it below the base of the washer. This will drain it completely.
After the water has drained, pull the washer away from the wall... enough for working space. AND DON'T FORGET TO UNPLUG IT! Remove the rear panel (4 screws) and you'll see a big pulley in front of you.To the lower left, you'll see the drain pump. It's mounted to the base of the cabinet. Use a 5/16" to remove the hose clamps then remove the hoses. Then remove the wires that feed the pump. When that is done, you should have the pump in your hand.
Now that you have the pump in hand you'll see the pump housing (it's white). There are three screws holding the pump housing to the motor. Remove them and separate the 2 parts.Now you'll see the cause of the problem. Some trash got pulled into it. Probably a rug bottom or a dog bed....
Remove the stuff and rebuild the unit in reverse order and you're good to go.
Don't forget to rate my solution!
SG
SOURCE: Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
SOURCE: My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
