Question about Compaq Presario 700 470024-192 Notebook
Compq C700 My Laptop can not support HEADPHONE
  • 1 more comment
  • Anonymous Feb 28, 2009
    i have same problem
  • pankaj5114 Apr 02, 2009
    Dear sir,
    Have i found new problem that not install audio driver ,i have four times try but not install.
    pankaj kumar
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    pls elaborate sound is not coming from headphone or what ? what do u mean by does not support headphone u have a sound problem pls clarify in order to help
  • 3 Answers
Audio
Microsoft UAA driver (install first)
Conexant High-Definition Audio Driver (install later. Use ‘have disk’ method to install.
try out this. download these drivers and install it. it may solve your problem..
Posted on Apr 05, 2009
Sound problem
This could be possible if the sound port has gone bad. You have to also say if the sound is coming on the headphone.
Regards
Jun 19, 2009 | Compaq Presario C700T Notebook
My laptop model HP presario C700. when i plug in headphone the speaker still on.what should i do?
GO TO control pannel and select the sound, select the recording or playback then set as default the headphone
Jun 06, 2009 | Compaq Presario C700T Notebook
My laptop sounds from both the speaker when i connect headphone.
First go to control panel, sounds and audio devices
go to the audio tab and make sure that your usb device is selected for audio playback
then, unconnect the headphones and restart your computer
after restarting, connect the headphones and Speakers , it should work
May 04, 2009 | Computers & Internet
When i uses headphone in c700 sound comes both headphone & laptop
harsh
u just got to use the volume controller placed somewhere on the body of ur laptop (if any in ur one) and put it fully low n hence u will hear no sound from laptop but from ur headphone....
hope it helps....
Dec 10, 2008 | Compaq Presario 700 470024-192 Notebook
Driver problem in compaq presario c700 laptop
Try connecting the headphone properly.
Check if its properly inserted.
Go for windows update............... and then check if the problem is gone.
If all the above doesnot works I think there is a connection between the metals inside your headphone portal, ans as soon as you insert the jack it gets connected and you can hear sounds from both the sources.
Thank You.
Nov 13, 2008 | Microsoft Windows XP Professional With...
Need a sound sofware
i can't find sound and audio driver after formatting my laptop compaq presario C700 notebook pc
Nov 09, 2008 | Compaq Presario 700 470024-192 Notebook
About intel celdron motherboard drivers for compq presario c700
Go to intel website and try to download what you need .
From what do you said here some information:
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=49&lang=eng
If You have a warranty you should call the hp customer care they will help you more to not download uncompatible stuff from internet.
Jul 28, 2008 | Dell Inspiron™ E1505 PC Notebook
Headphone and mic
my presario c700 has a built in mic try just connecting headphones in and using the built i mic
Jul 23, 2008 | Compaq Presario 700 470024-192 Notebook
Broken headphone socket on compaq presario c700
It can be replaced as it is most likely a standard part. The problem is that 1) it is a surface mounted socket and 2) the entire laptop must be dis-assembled to get to it. This is not a repair I would recommend to a novice. Ask around for someone that can work on surface mounted parts and see how much for the repair. The part should not be more than $2-$4.
Dan
Jun 04, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
178 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
