Question about Magellan MAESTRO 3100 98083401 GPS Device
Won't shut off
My Magellan 3100 won't let me enter my return trip or turn off when I've arrived at my original destination. After trying more than 10 times to shut it off, it finally does. Then I can add a new destination and it will get me there, but the same problem on the return
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
There could be a couple of reasons of the "no shutdown":
  • firmware glitch;
  • button problem/internal corrosion of switch contacts;
  • the unit is still performing a function and has not completed doing so. Therefore it will not perform the next function such as powering off or entry of new commands/destination.
Corrective measures could require:
  • full systems reset;
  • firmware update;
  • hardware cleaning of switches/button contacts.
Good luck and thank you for using FixYa.
Posted on Feb 22, 2009
    Genius:
  • 1,550 Answers
Initially try reset in your device .
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
Magellan Roadmate 1412 won't track satellites
It might mean that the signal is disrupted. Might be a software glitch. Try going outside, get a clear view of the sky. Then reboot/reset the unit. Hold the switch to the reset position or off position for 10 seconds, it will shut off. then switch it back on. It should reacquire a signal within 2-5 minutes, then it will fix on your position. If that doesn't work, try updating your software. Call Magellan Tech Support for instructions.
Dec 29, 2011 | Magellan RoadMate 1412 Car GPS Receiver
Screen stuck at home address won't continue with any route, even when I go back and manually enter other addresses, was working great for 6 months
This is normal, this come straight of the satellite. To speed up process or bypass, reboot system. To Manually reboot this model, turn unit off like normal. Then when turning on, keep button down as it fires up, DO NOT release on button, keep it down until all fires up and even about 10 seconds passed, then let go. This reboots it and cleans up a lot of ****. Thanks Mike. Please if this helps, please give me 4 thumbs up, to help me and others. if that dont work, turn it off again fully charge it then reboot it manually again. This should do it!
Jun 18, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
Hello, I updated my Magellan Roadmate 1440 from the Magellan website. Now, when I try to put in a destination, the screen says "route error, your destination may be in a restricted area or unreachable...
I contacted Magellan about this issue for my Roadmate 5045. They told me to reset the unit by sliding the power bar to to the off position for 10 seconds, and then let it sit off for a minute or so. When it powered up, the issue seemed to be resolved. But it comes back. Successive efforts using this method have about a 80% success rate.
Mar 03, 2011 | Magellan RoadMate 1440 Car GPS Receiver
How to set the distance to destination
Not sure about this one, but most of these gps units have a sub menu in them that will ask you what to display. You activate them in one of the settings menu, and it will show you how far to destination automatically. It is programed right into the unit, just not sure how you do it any more since i don't use Magellan anymore. Sorry. Hope this helps
Apr 26, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Frozen screen with no GPS movement
Hello :
I recommend you to reset your GPS , then try to update it's software .
good luck .
please rate !
Apr 14, 2010 | Magellan Maestro 3250 GPS
3000T won'y shut off
When you turn it off, do you hold the off button in until it turns off? As for it won't let you reenter data, is the destination off or cancelled to put in a new?
Feb 24, 2009 | Magellan RoadMate 3000T GPS Receiver
Gps loading screen freezes
If Magellan touch screen, try turning unit on while holding bottom right corner of touch screen. This will reset the unit.
Jun 27, 2008 | Magellan Maestro 4040 GPS Receiver
I have heard that there is an upgrade to the Magellan Maestro 4040, where you can actually speak to the device and get things like directions to the closest resturant. How do I get this upgrade if...
Upgrade your Magellan Maestro with hands-free Voice Command & Control for the easiest, most satisfying navigation experience.
Your Maestro 4040 will respond to your voice commands to give you quick information and an instant route to nearby points of interest. Activate Voice Command & Control and find the nearest coffee, food, gas and ATM simply by speaking. Ask for your current location and distance to destination and hear the details as you keep your hands on the wheel and your eyes on the road. Just say the word and get instant information about the nearest roadside assistance.
Purchase the upgrade and you will be given a unique unlock code. Enter the code* into your Magellan Maestro 4040 and let your voice put you in command
Apr 16, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
My garmin
it may be trying to get you back on track or if when turning it on it trys to take you a previously sort location you may have set this as your home. make sure your actual home address is stored as your home address on the gps unit.
Jan 10, 2008 | Tomtom GO 910 GPS Receiver
Magellan Maestro 3100 locks
You can try a hard reset. Hold in the reset button (left side of unit, use a pin or toothpick), while turning on the unit. If you don't get the blue Magellan screen, you'll have to try again. If you get a screen with a blue background and a menu, turn it off and try again.
So far, this has fixed:
1. unit won't go on
2. unit reboots when routing
3. unit turns off after a few seconds
At least, it's fixed it for me. No idea why this happens, but it's pretty damn annoying. Give it a try.
Dec 26, 2007 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan MAESTRO 3100 98083401 GPS Device Logo
21 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
