Question about Bburago Citroen C6 Diecast Model
Replace speedometer calbe
I think my speedometer cable is broken, how do I replace it?
How can i be sure it's broken?
Thank you,
Jim. having th same kind pf trouble mine is a citreon c5 2001 plate the speed just wont read but my milage is still cloking up, any ideas how to get the clocks out or what the prob is
The problem is the speedo stepper motor inside the dashboard. You need to change this part to fix it:
http://www.freewebstore.org/Dashboard-Repair-Shop/Speedometer_case/p804140_3650336.aspx
Or whole stepper motor:
http://www.freewebstore.org/Dashboard-Repair-Shop/Speedo_stepper_motor/p804140_4756582.aspx
Posted on Oct 24, 2011
    Champion:
  • 250 Answers
Its not the cable, there is no cable, your prob is the speedo, check all fuses first but u have answered it yourself if milage goes up the signal is there.
vss sensor is working.
has to be the clock.
get back to me
Posted on Aug 19, 2009
  • lloyd cole Sep 05, 2009
    hi, there is no speedo cable, you have just answered your own prob, its the speedo pod thats bust, a set of clocks for you.
  • lloyd cole Sep 19, 2009
    your prob is the speedo. i would get a set from the scrap yard and learn when u take this 1 out. have fun.
How do i get the speedometer gear out of the trannsmission?
see if you can rock the tranmission back and forth pulling on cable what happens is they get a bur on the gear that wont let itout
Aug 19, 2014 | Cars & Trucks
How do I replace Toronado speedometer cable?
It does not have to be replaced,They can be lubricated,
Dec 04, 2012 | 1985 Oldsmobile Toronado
My speedometer didnt function anymore, i need to replace the whole assembly of my speedometer.
No I believe the speed ometer cable is broken.Dissconnect sppedometer cable from instrunent cluster,romove cable from back of speedometer &transmission case .romove speedometer from sppedometer cable housing if broken replace with new & make sure you grease cable when installing back in cale housing reconnect to transmission &back of speedometer.keep posting
May 23, 2011 | Nissan Frontier Cars & Trucks
My speedometer is not working at all i know it is the speed sensor. Now is that something that is easy to repair or is it something the tranny has to come out and get it fixed
Most speed sensors are mounted on the transmission and not that hard to replace.It should be located on the top of the tranny but all cars are different and mounted in different spots on the tranny.Your local auto parts store should be able to give you the exact location of the sensor.Its a matter of one bolt and a connector.
Mar 06, 2011 | Dodge Ram 1500 Cars & Trucks
Speedometer not working
Given that the new cable was properly installed (it may not have been), the problem is either the speedometer gear in the transmission or the speedometer itself.
If the old cable was indeed broken, I'd first check the new cable to make sure it's properly installed.
Charlie
Aug 14, 2009 | 1991 Toyota Pickup
Ihave a 91 300zx and my speedometer doesn't work.
The most likely problem is the speedometer cable is broken, probably near the transmission. if it's the cable, probably under $10. Disconnect the housing at the transmission, and the cable is inside. Pull the cable out, it should be square at both ends. a broken cable is obvious. insert a good cable (with some appropriate cable lube) into the flexable cable housing, you might have to turn the cable a bit to get the end back in the speedometer. If it is broke , you will also have to disconnect the housing at the speedometer to get the other end out. You might be able to reach it from under the dash, but you might have to loosen the instrument cluster to reach it.
Jun 08, 2009 | 1991 Nissan 300ZX
Replace the Speedometer Cable
1 - Remove the old speedometer cable from your car, first take off the doghouse and then the engine cover.
2 - Remove the screw underneath the dashboard and take down the steering column. This will give you access to the back of your speedometer.
3 - Take off the drive shaft bolt, and "O" ring, insert the speedometer cable through the firewall.
4 - Remove speedometer cable securing clamps from the engine compartment and on the transmission.
5 - Release the drive shaft nut from the "right angle" adapter (The nut is attached to the back of the transfer case).
Installing the Speedometer Cable
1 - Place the square end of the speedometer cable into the adapter and secure the drive shaft nut.
2 - Pull the speedometer cable through the firewall to the rear of the speedometer.
3 - Secure the "O" ring and attach the speedometer cable to the rear of the speedometer/odometer. It should be engaged in the speedometer's square hold. Tighten the drive shaft nut again.
4 - Replace the clamps that will secure the speedometer cable onto the transmission and in the engine compartment. Replace the engine cover.
5 - Drive your car slowly to be sure your speedometer is working properly. If it is, replace the doghouse. If you're stilling having problems, take the car to your mechanic.
Parts & tools -
Speedometer cable
Wrench
Screwdrivers
Good Luck.
Jul 01, 2008 | 2001 Honda Accord
Speedometer Stops
Most cars Speedometer cable connect to one of the front wheels, but you said your speedometer sometimes stop then your steering wheel will go stiff, I think you should fix or change your speedometer cable, maybe the cable broken inside. Fix it as soon as possible for your safety.
Speedometer cable has two parts, one is outside cable, mounted and connect to both speedometer and wheel.
The other one is an inside steel cable, outside cable protects the inside cable, because the inside cable turns as soon as you move the car. It is directly connect to the wheel gears and the speedometer inside.
If your car has speedometer cable, I think you need check it right away.
Your steering wheel sometimes stiff, you also need to check your power steering fluid level, sometimes cause this kind problem.
Hope this can help you and if you have more questions, please use whatever the Fixya allowed, contact me to discuss this matter and others. Thank you.
Jun 24, 2008 | 2001 Ford Focus
Bburago Citroen C6 Diecast Model Logo
724 people viewed this question
Top Bburago Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Bburago Toy Expert? Answer questions, earn points and help others
