Question about Gateway ADSL 1 Port VoIP, 1 Port ADSL , MGCP Router (1862A1400)
No sync i have a belkin voip 1 port wired gateway F1P1210ENau from IInet has been working fine now the ADSL light just keeps coming on and off and does not connect i tried at another friends and the same problem exists.
2 Suggested Answers
  • 2263 Answers
SOURCE: i a using cable net and not the dsl line.the net
check the wireless settings of the router .
Make sure that you are typing the correct network key if your network is secured.
May be you will need to open the ports on the router.
Click Here for more information
Posted on Jan 04, 2010
Can I set this up this wireless router if I have cable internet and not DSL?
You CAN do this if you have access to the firmware of the ADSL gateway.
Connect cat5 cable from ethernet port on cable modem to ethernet port 1 on ADSL Gateway. (Must be port 1)
-Connect cat5 cable from computer NIC to other port on ADSL Gateway.
-(You may need to) Start->Run->cmd
ipconfig -release all
ipconfig -renew
Here's the trick...
-Open web browser, go to ADSL Gateway homepage (likely
-Configuration tab, Advanced WAN->WAN
-Change WAN PORT drop down from DSL ATM PORT to ETHERNET PORT 1
-Click Edit button. Change Protocol from PPPoE to ROUTED.
-Radio button for DHCP Client to Enable.
-Click Set button.
-(You may need to) Power cycle both Cable Modem and ADSL Gateway device
Now this was done on a Westell ADSL gateway from verizon, yours may differ and you may need to look up the instructions for your specific gateway.
Aug 08, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
I am using SPA2012 with TG585v7 ADSL on PPPoE, i am not getting any incoming calls, my out going calls are ok. I have done port forwarding still no solution. When i run same SPA2102 on linksys ADSL it...
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first.
May 10, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
Router ports require configering
I know the ADSL portion of the modem needs configuration. But the routers are settup for default as dynamic and no WEP. At least the ones I have used.
Most belkin routers have a default gateway is Try that and go into the setup. There is also a CD to help with setup.
If you need more help explain more in detail what setup you need.
Oct 25, 2009 | Belkin Computers & Internet
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
RouFlashing ADSL light
have yo properly configure the setting imean dsl account ,dns setting etc of belkin
Aug 15, 2009 | Computers & Internet
Seems to interfere with volume of home phone on same line
you have to use seplitter in that you have to use the internet and calls also
Mar 12, 2009 | Computers & Internet
Trying to use VOIP-321 with a Belkin Networked USB hub
Fallonje good afternoon,
I wonder if you have a USB port on your computer? If yes, pls plug the VOIP321 into that port. Does it work?
What is the Belkin hub called networked?
Let me know. Many regards, Fred
Feb 12, 2009 | Philips DECT VOIP-321 cordless telephone
Belkin F5D7231-4 and ADSL2+
I dont know...
however I would run ipconfig command on your PC. Make sure the default gateway corresponds to your router`s IP (if you indeeed have it conected to it)
And also make sure that your modem is set in Bridging mode and your router in PPPoE a
and the appropiate password input into it.
Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
I have a ZyXEL P-660HW-TI ADSL wireless router used as the gateway and wireless AP (also the wired ports are used for LAN). It has no VoIP ports. I do have a 2nd ADSL router (not used: no wireless, 1 LAN...
No because the VOIP need to be loged in first. if you have the voip first then the wireless router and you turned off the router dchp section part of the wireless modem then perhaps it will work, plus you need a voip account.
Jul 03, 2008 | Computers & Internet
Using just the VOIP part of a Belkin all in one router??
You will probably need to set it up differently, I do not know the belking router, but normally the VOIP functions only work on the wan port of these routers so you should make the connections as follows:
INET ---> (wan) DLINK (lan) -----> (wan) BELKIN (voip) --> Phone
|--------> Wired Computers
|--- ) ) ) Wi Fi computers
On the DLINK enable DHCP and set a fixed IP for the Belkin router, either by setting the belkin in an IP outside the DHCP pool or setting it from the DHCP server.
This configuration workd well with a DLINK and a Motorola (vonage) router I have.
Apr 23, 2008 | Computers & Internet
Gateway ADSL 1 Port VoIP, 1 Port ADSL , MGCP Router (1862A1400) Logo
63 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
