Question about Homelite Garden
Problem oil doenst arrive at chain Homelite model CSP 4016 40cc
Oil doesn't arrive at chain of the chainsaw
  • apprendrelan Feb 25, 2009
    there is no bar the oil doen't reach the chain, no blockage in view
    Problem Solver:
  • 7 Answers
Remove your bar and free rev the engine, check that the oiler hole is pulsing and free from debris.
Posted on Feb 25, 2009
I need to remove the automatic oiler in my homelight chainsaw z3850b
Chainsaw Oil Pump Replacement - Homelite ... - YouTube
? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
How to Repair a Homelite XL Chainsaw Oiler - Home Guides
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Dec 21, 2015 | Garden
What is the oil to gas ratio for homelite model 360?
I cannot find the full details for the model 360 chain saw but a typical Homelite chain saw uses the 50/1 gas/oil ratio.
1 gallon (US) 2,6 oz
1 litre 20 cc (20 ml)
If you want to download the user manual for your chain saw then please check the full model number . for example UTxxx and select this in the Homelite site.
Product Owner Manuals
Aug 21, 2014 | Homelite Garden
Homelite CSP 4518 oil pump
The most probable cause is the oil line inside the saw from the oil tank to the pump or oil flow being blocked at the rubber ball that you can see when you remove the chain, bar and plate before it has a chance to get to the bar. in my case i had the oil line itself blocked from dust getting into the oil tank over time
Mar 11, 2012 | Homelite Garden
I brought a brand new homelite 33c-csp 3314 and my wife threw the manual out or i lost it ,how much chain and bar oil do you put in the oil part? i cant open pdfs cause somethings wrong with that thank...
Hi, basically you fill it up every time you fill up with two stroke fuel as it uses about 3/4 of a tank of bar oil to a tank of fuel. Regards Phil.
Aug 11, 2011 | Homelite Garden
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Need service manual for Homelite 16'' electric chain saw model UT 41320. Motor runs but chain stopped in middle of second cut.
chain is too tight on the bar or is lacking lubrication oil. loosen up the bar nuts and back off the chain tensioning screw a touch. make sure the bar oil reservoir is full and the chain is receiving oil when its running.
Oct 20, 2009 | Homelite Garden
Need replacement Chain oil pump
Go to the Homelite web site, which will get you to HCPI Electronics Parts catalog. You will need the model number. The parts are illustrated as a break-away drawing for various portions of the saw. Hope this helps.
Aug 29, 2009 | Garden
What is th petrol and oil ratio for a homelite petrol chainsaw 33c- csp 3314
Generally you're looking at a 50:1 ratio on most chainsaws and I wouldn't see any reason the homelite should be any different. Usually it's one 2.5oz container of the oil mixture to one gallon of gasoline but check the label to be sure.
Jul 30, 2009 | Homelite Garden
Homelite CSP 3314 Chainsaw
starts no prob will not rev , just stalls when you try
Feb 11, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
999 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
