Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
DGB-900 Grind and Brew grinder
I received the DGB-900 Grind and Brew for Christmas and have used it approx.50 times. I started out cleaning the chute once every other cycle, then after every cycle because of the buildup in the chute, which I figure is attributable to the oily content of my beans and the steam.
This morning I programmed a brew cycle and noticed that the grinder sounded "bogged down" and ended up with clear water in the caraffe. So I cleaned the chute and tried again, same result. Third attempt with ground coffee was fine, so I guess the problem is the grinder motor..
How do you clean out the motor or otherwise fix the problem?? Thanks!!
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
One idea to try. I noticed with my grind & brew that the moisture never evaporated from the inside top of the machine. Since that cannot be good over a long term, I have started leaving the top open during the day after I clean the machine in the morning. Your problem is why I started doing that. Why don't you try leaving the top open for a couple of days and see if drying the machine out doesn't cause some of that gunk to dry out?
Posted on Mar 20, 2009
  • G Dean Jun 03, 2012
    There is also a small trap slide door which can get a buildup of compressed coffee silt. This causes the door to sometimes stick open or to partially close. Carefully make sure that metal door is very clean and shiny. When coffee grinding stops and water is added this door springs shut. It is a "redundant backup" to keep steam from the grinder area. After cleaning the coffee chute, also clean the top and bottom of that door.
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Need instructions to operate DGB-600BC
Thanks for the reply. Got rid of the coffee maker. Its a dud. No more information required.
Jun 18, 2009 | Cuisinart Thermal DGB-600 Grinder
Water doesn't flow through DGB-900
You should download manual if you dont have it. I was having problems with mine read the manual and worked. I think you might have to program it like I did. I set the clock and then programed it for half and hour later and it worked. You have to program it when light is blinking and same for when you are setting the time.Hope that helps.
Apr 05, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a 12 cup cusinart grind & brew. The hopper is not working
You may have to clean the grinder....even more. That happened to me once. First I cleaned out the coffeemaker with the brush, and "dug" out more coffee, then I used this product which you can find on Amazon: "Urnex Grindz Coffee Grinder Cleaner - Urnex 17-GRINDZ12-40." It's expensive, but it really worked well.
Apr 02, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Coffee grinder on brew and grind won't work
Make sure the slot between the grind basket and filter basket is clean and free of grounds - then inspect the area near the grinder motor - use the brush that came supplied with the Cuisinart to clean that area out. Once thoroughly cleaned, try one more time to Grind. Let me know if it works.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart Thermal DGB-600 Grinder
Grinder does not work
Clean the grind chute out underneath the grind chamber.
Dec 08, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
WON'T BREW OR GRIND.
Get it serviced. Probably a grinder motor issue.
If you are near new york check out http://cerinicoffee.com/Espresso_machine_service.asp
Nov 19, 2007 | Saeco Vienna Espresso Machine
DGB 600 Grind & Brew
Had the same problem, I used coffee pot cleaning solution a couple times through and it woks fine. Had to do this a few times now. Cleaning solution is the type bought at local retail store.
Aug 03, 2007 | Cuisinart Thermal DGB-600 Grinder
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
363 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
