Question about WYSE WINTERM 1200LE Network Terminal
I have some problem with my monitor frequency and wyse terminal frequency.Its overrange, i can't see anything when i power it up.Can smbd tell me how to reset factory default with power on.
  • kuldeepmehra Apr 15, 2009
    I M USING 17' TFT with wtos 1200le model. It is showing "out of sync" error on the monitor screen.
  • 25 Answers
This is caused by the terminals default display resolution (or the resolution that it was set to in its previous environment). The easiest way to get a display, would be to use a different monitor with a higher range of supported resolutions.
Fingers crossed the previous wnos.ini file would allow a G-key reset. If so, just hold down the G key when the terminal is booting, and it will reset to factory defaults. This might allow your monitor to work. (I think the default resolution is 800x600)
The problem you have is that the terminal might be locked down via the .ini file. So changing the configuration might be difficult. You could use a program like Wireshark to perform a network trace, this would tell you where the terminal is looking for it its wnos.ini file.
Then you will be able to setup a new wnos.ini on an FTP server set to the IP address(and path) the terminal is looking for, and this will allow you to set your own configuration
Posted on Jul 07, 2009
Wyse S30 power settings
You can check the settings in the bios (password will be "Fireport") I dont think there is anything in there that would trigger this.
Is there a screen-saver option in the control panel for the device? If so, see if it is set. If not, then try using the Wyse website to update the terminals OS to the latest. This will hopefully solve the problem. It might just be an incompatability with the older OS version.
Jun 22, 2009 | WYSE Winterm S30 Network Terminal
View sonic -E70fB monitor displaying H.V frequency out of range when ever i play a game on the monitor screen it is displaying h.v frequency out of range....how to solve this problem
view sonic -E70fB monitor displaying H.V frequency out of range
Jun 06, 2009 | ViewSonic G70F 17'' Monitor + Wyse Winterm...
Wyse 1200LE - error - out of frequency
Then you will be able to setup a new wnos.ini on an FTP server set to the IP address(and path) the terminal is looking for, and this will allow you to set your own configuration.
May 28, 2009 | WYSE Winterm S30 Network Terminal
Monitor flickers with changing colors making it almost impossible to see anything, it started & stopped for a while then after maybe three weeks after it started again ! I tried disconnecting & changing...
I suggest upgrading the OS on these problem terminals to the latest on the wyse website. It might be an incompatibility with the monitor and terminal (might have been fixed in later builds), in which case you will need to log it with Wyse directly, as they will need to test this.
Chances are though you either have a faulty monitor cable, a faulty unit, or faulty monitor. Perhaps even a combination of more than one of these above problems. Try to rule out each bit of hardware before blaming anything in particular.
Try a few different monitor resolutions, colour depth and refresh rates too. Cant hurt :)
Mar 31, 2009 | WYSE Winterm S30 Network Terminal
The wyse 50 terminal does not work properly
Wyse 50/60/150/160 monitors were my specialty!
From what you were explaining it seems to me that you have a bad internal battery and it needs to be changed and a factory reset/ calibration needs to be performed.
I can repair wyse terminals at my facility if you like. The repair cost is not that high and we can also perform the regular repair and adjustments on all wyse monitors if needed.
Please contact me if you have any questions.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Mar 18, 2009 | WYSE 50 Terminal
WYSE S30 RESOLUTION SETTING TO HIGH
Try resetting with Control + g rather than just g
Turn on the Winterm and immediately hold control + g (at the same time)
The display should flicker for a bit then release the control + g
This will reset the device to factory defaults, (you'll lose your connection settings, network settings, etc) -- but you'll be able to use it again. :)
Feb 11, 2009 | WYSE Winterm S30 Network Terminal
Problem with WYSE Winterm 3235LE
Tsaukpaetra is correct it's a resolution mis-match with the monitor you are using. If you have Rshadow loaded on the winterm you can VNC into it and change the resolution. If not you can hold down the letter "G" on the keyboard to perform a factory reset.
Aug 29, 2008 | WYSE Winterm 3235LE Network Terminal
The display settings are not valid with the monitor. Either you are using a new monitor or you have changed the settings. If you are using a new monitor, swap with the old monitor and configure the appropriate refresh rate for the new monitor.
If you have changed the settings you may need to either reset all default settings, or setup a parallel unit and use the same key strokes to change the display settings on the problem unit.
Cheers..
Apr 02, 2008 | WYSE Winterm S30 Network Terminal
No display in monitor
This may be the problem with the WYSE driver. Ensure that correct driver is intalled and colour profile is compitable. Syncmaster is auto detected by window based OS.the message "Sync out of range" comes due to improper out put video signal.
Jul 24, 2007 | WYSE Winterm 3235LE Network Terminal
H.V. frequency over range
I have a philips 105s5 crt monitor.First problem is vertical dead.Replaced this ic .Power ok but screen appear" H.V frequency over range" .How to solve this problem.Please suggest me.
Dec 23, 2006 | ViewSonic G70F 17'' Monitor + Wyse Winterm...
WYSE WINTERM 1200LE Network Terminal Logo
495 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
