Question about ASUS P4PE-L 845PE Motherboard
Drivers for asus 845 motherboard with amd athlon xp processers
Hi,i m using asus 845 motherboard,dnt know the exact confiuration,with an amd athlon xp processer.i m unable to get the drivers for dat,cn u help me plz
  • 158 Answers
You can download the driver of your motherboard but you have to specify your system model number and then the operating system .
Follow this link : http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Feb 22, 2009
Is it possible that AMD Athlon II X2 (3.0ghz) processor will fit in in this ASUS A7V8X-X motherboard?
hello there,
  • Socket A CPU support Type,
  • models Athlon, Duron, Athlon XP
  • The AMD Athlon II X2 is a Socket AM3, sorry to tell you that this motherboard and CPU will not work together correctly. New motherboards are always fun
Jan 27, 2011 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
ASUS A7S333 upgrade solution
MPN: A7S333
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
Compatible Processors: Athlon, Duron, Athlon XP
Processor Socket: Socket A
Chipset Type: SiS745
Max Bus Speed: 266 MHz
BIOS Type: Award
Storage Controller: ATA-100
your max cpu would be proably 3200 anthlon xp ok
Jan 10, 2008 | ASUS A7S333 Motherboard
A7V266E/AA MB CPU
The Ol' Asus A7V266-E?
1.The fastest Front Side Bus setting is 266MHz
2.Uses Socket 462 AMD processors
3.Uses Athlon, Athlon XP, and Duron AMD processors.
I would stick with an AMD Athlon XP. Fastest one? Hmmm, I believe that would be the AMD Athlon XP 2600+
The one that operates at 2133MHz with a FSB of 266MHz. Part number AXDA2600DKV3C
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors#Athlon_XP_.22Thoroughbred_A.2FB.22_.28Model_8.2C_130_nm.29
Here is the Motherboard Manual for your Asus A7V266-E, (It's a PDF file download. Let it download all the way before looking through it)
http://www.motherboards.org/files/manuals/1/a7v266e-100.pdf
If the above direct link does not work for you, then go here,
http://www.motherboards.org/mobot/manuals/ASUS/A7V266-E/ (Click on -> Download <- all the way to the right of -> File:a7v266e-100.pdfVersion:--Release Date:--)
Go to Page 19, Item 2. NO POWER connected to computer, make sure the SYSCLK (System Clock) DIP switches are set to 133MHz.
1, 2, 3, and 4 are set to the OFF position for 133MHz.
All you will see is the ON. The switches go to the opposite side as shown in Item 2.
I'm sure they are set there however, as your 1900+ you have in right now, uses a 266MHz FSB.
I should explain.
AMD processors are Double-Pumped. Therefore the 133MHz setting will become 266MHz for the processor. (Intel processors are Quad-Pumped.
They are both the same Core, (Thoroughbred A/B, Model 8, 130nm), so a BIOS update shouldn't be necessary.
Jul 07, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
I need ati ixp 400 driver
Hi Kurapika.
Ati ixp 400 drivers (xp/vista/win7/win8/mac) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Jul 03, 2009 | HP Computers & Internet
I have lost my motherboard driver CD( AMD Athlon(tm)xp 2000+ 1.68 GHz,),from where i can download?. plz help?
If your motherboard is ASUS then you can go directly to www.asus.com and search for the k8mv motherboard drivers or
if its a MSI board the go to www.msi.com
May 15, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
I would like to find the spec manual and what cpu slot it has.
I tried to get the exact link, but the website will not allow it.
Go to this page, and put in your model number, and you will find it really easy.
This board is a socket A for AMD processors.
You will need adobe reader to get this manual.
Apr 16, 2009 | ASUS A7N8X Motherboard
I reinstall win xp and i need the followings
I cannot determine the make or model of your motherboard you are currently using as you have only specified the Processor's make/model.
I have compiled a list below of common motherboards that work with the AMD Athlon XP processor (1500+)
Please choose from the links below one that best matches your motherboard; (These are driver links for the motherboard)
OPTION1: ---- MSI ----
K7T266 Pro
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=288
OPTION 2: ---- Gigabyte ----
VIA KT266A
GA-7VTXE
* Instruction to download product image :
Right click on the product image, choose "Save Picture As..."
* The product picture above is only for reference.
* GIGABYTE reserves the rights to alter product specifications at any time without notice.
" href="http://www.giga-byte.com/FileList/Image/motherboard_productimage_ga-7vtxe_big.jpg" rel="pic" jquery1239713741655="4">motherboard_productimage_ga-7vtxe_small.jpg
http://www.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=1310&ost=xp#anchor_os
OPTION 3: ---- ASUS ----
A7V266
Thanks
C
Apr 14, 2009 | AMD Athlon XP 1500+ , 1.33 GHz Processor
Pc upgrade !
IAN.S
Where you need to be is on Asus web site. Your board can handle ONLY; Athlon XP 3200+(400 MHz FSB)(Model 10)(Barton), AXDA3200BOX
With that CPU you must also have bios version 1004.
Check PCB and BIOS versions before flashing BIOS!
asus A7N8X supported CPU click here; http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=A7N8X
Since you seem to need your manual. Click the link:
http://dlsvr01.asus.com/pub/ASUS/mb/socka/nforce2/a7n8x/e1859_a7n8x.pdf
You do not have an intergrated video card. You have a 1.5v 8x
AGP video slot.
I suggest you call Asus & make sure your CPU model AXDA3200DKV4E will be supported over model AXDA3200BOX.
You can call Asus tech M-F EST at 812-282-2787.
Good luck & Have a great day!
Mar 16, 2008 | ASUS A7V8X Motherboard
MPN: A7S333
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
BIOS Type: Award
amd 3200 + anthlon ok with fsb 266 mhz soket a
ASUS P4PE-L 845PE Motherboard Logo
436 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
