Question about Pioneer DV-737 DVD Player
Replacement part Would like to purchase circuit board that contains the motor drive IC for the DV-737 Pioneer Player. Numbers on board are : VNP 1779-B, Label VQE Vide Quality Enhancer. Dimension 9.25" x 4.5". Thanks. P. Perry
@Pepdiauq did you manage to locate a new board? I think we've got the same problem! Eject wont work although motor is fine. tracked it down to a M56788FP chip (possibly).
Posted on Feb 28, 2010
Pioneer vsx 511 amp error
Hello
There are two IC links on the main PCB (Printed Circuit Board) labelled IC604 w522 491010 and IC605 w522 491010 these should measure open circuit (damaged).
The PCB has a warning:
Caution: Replace IC links as marked manufactured by Littlefuse Inc
Finding replacement IC will solve the problem.
I do hope that my information is acceptable.
Apr 05, 2011 | Pioneer Audio Players & Recorders
I have a pioneer dvd player model DV-300-K that needs a spindle motor. The brushes are completely worn out. Service manual says to replace the entire assembly which include the laser. It is available at...
Your only shot is if there are numbers on the motor. We are running into the same thing with DLP sets with color wheels so I know how you feel.
Jan 24, 2011 | Televison & Video
Region code unlocking pioneer dv-220kv
My DV-220KV-K, which is sold as a Multi Region DVD player has locked up on me. The following message comes onto the TV screen...
(Player's Region Setting) <1> : Region <2> : Region <3> : Region <4> : Region <5> : Region <6> : Region Pick out any one of these!
The message remains on the screen ALL the time and I'm locked out of viewing anything. The remote is locked and so I cannot pick any of the region numbers!
Dec 08, 2009 | Pioneer DV-220V-K DVD Player
Dsc-363 displays code " oc err 1 "
It's output power amplifier ic problem. change ur output ic
Mar 08, 2009 | Pioneer DV-363 DVD Player
Problem wit USB-port on DV-410
The 8GB is most likely what is called a SDHC or "Secure Digital High Capacity" It will not work in system that do not show they can read the SDHC drives, the 2GB is not SDHC
Apr 12, 2017 | Pioneer DV-300-K Player
How to use the usb port on Pioneer DV-410V DVD Player
Dear friends in problem solving.
My husband actually solved this problem by writing in the browser: Manual for Pioneer DV-410V DVD player.
That was available online and there it said that not all formats was supported by the USB port, so we tried to load a movie on a pen drive, insert it in the player and it opened and we just clicked play, so it was actually an issue of having an incompatible video file on the pen drive that made it not open in the first place.
Hugs from Solvejg
Dec 08, 2008 | Pioneer DV-300-K Player
Pioneer DV-260 DVD player cannot play HD DVD
thats like trying to play a dvd ina cd player. cant be done.
Feb 16, 2008 | Pioneer DV-260 DVD Player
No Power
ok! make sure ur IC regulator is good. like the 7805 or 7812 or 7809 u make sure that the following ICs are correct in voltage! 7805 is for 5V. 7812 is for 12V. 7809 is for 9V MAKE SURE THAT IS EXACTLY IN VOLTAGE!
Jun 17, 2007 | Pioneer DV-575A DVD Player
Pioneer DV-C36 disc tray will not stay open
Solution for Pioneer DV-C36 Multi Disk DVD player - tray door will not stay open.
My player would open the disk tray when the open button was press but when the tray was fully open it would retract
back into the unit leaving no time to change or load disks.
I found a poor connection at the ribbon cable connector was causing this problem. A seven conductor ribbon cable
connects the main unit with the travelling tray. A position switch (S21) senses when the tray is fully extended and retracted.
On my player pin 1 of the ribbon cable connector on the travelling tray was not making an electrical connection which
causes the control system to retract the tray. The fault lies in the connector - the tang was not pressing against the ribbon cable conductor.
I was able to desolder the connector and pull the contact out just far enough to reform the tang with fine needle nose pliers.
This is very tedious and required an eye loupe for magnification.
Tools required:
#1 and #2 phillips screwdrivers
Soldering and desoldering irons (or other desoldering tools)
Fine needle nose pliers.
Remove the tray ribbon cable
1. Remove the cabinet cover - 6 screws. Open the tray. To keep the tray from retracting pull the power cord when the tray is extended.
2. Remove the front bezel from the tray. Gently pry up the bezel by relesing the catches with a small screwdriver. Allow the tray to retract.
3. Remove the front panel - undo large ribbon and wire connections on right, remove screws left and right, release
two catch tangs on bottom edge using a small screwdriver on the inside of the unit.
4. Remove the white plastic cover over the laser mechanism ( 2 screws) Remove the disk carrier by removing the center screw.
5. Extend the tray again. When the tray is out the small ribbon cable is visible below the tray. Undo the ribon cable where it attaches to the main unit unit.
6. To slide the tray off the main unit use a small screwdriver to depress the stop catches (2) in the tray. They are molded into the tray.
Pull the tray out further then lift up.
7. Flip over the tray and find the small circuit board the ribbon cable goes to. Desolder the motor wires (red and black) and remove the 2 screws
holding the circuit board and position switch.
Use a multimeter to confirm there is an open or poor connection in the ribbon cable connector.
Remove the ribon cable and inspect the connector with an eye loupe or other magnification device. On my player contact #1 was not positioned properly
to press against the ribbon cable conductor. You can either replace the connector or repair it.
Warning: repairing the connector may damage it.
To repair the contact desolder the connector from the circuit board. Bend the circuit board prong straight and push it into the body of the
connector which will extend the contact out and the contact can be reformed. Be very gentle. Bending the contact may cause it to break.
Reassembly is the reverse. Don't forget to solder the motor wires with the proper polarity. Red and Black are labeled on the circuit board.
May 28, 2007 | Pioneer DV-C36 DVD Player
Pioneer DV-737 DVD Player Logo
497 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
