Question about Dell Dimension 5100 (D51L1) PC Desktop
My mic on D845GLAD board is not working - Dell Dimension 5100 (D51L1) PC Desktop
    Scholar:
  • 164 Answers
Hi!
It's very psssible that it is MUTED.
Go to the control panel and the sound icon. Open that to advanced and see if the muted is turned on.
You did not say if this was a headset or speakers. It would help if I knew it was the onboard sound or an add on.
Thanks!
Posted on Feb 22, 2009
  • Mike Davidson
    Mike Davidson Feb 22, 2009
    Hi!
    Thanks!
I have a Shure mic hooked up to my emachines T3092 through a Behringer mixing board. The board works fine, but I am getting over modulated scratchy voice when I record to cool edit pro. Tried every...
Which particular mic?
Go through the signal chain. Mic to mixer to pc.
All the level changes are suspect, what busses are you using...
e.g.
mic to channel 1 on mixer.
trim on mixer 1
fader on mixer 1
L/R balance
fader on L/R
which output from mixer are you using
Then the windows mixer (start/run "sndvol32.exe")
adjust the volume, WAVE, mic, etc.
My first instinct is the windows mic level.
Dec 03, 2010 | E-Machines T3092 PC Desktop
Hp pcdc7600s but speaker mic not working
troubleshooting steps -
*try testing a differnet mic/headphones
*open the casing to check that they are connected to the board correctly
*make sure if you are using a windows home edition or any windows under xp that you may have to download the drivers manually.
*im using windows XP professional and no issues with sound.
Nov 03, 2010 | HP Compaq dc7600 Small Form Factor PC...
I hav a microphone problem.Its working properly on my pc,but when when i connect it to my social netwoking site it doesnt work properly,some wired noice comes out th speaker of th one who is listning to my...
Go on mic. configuration and select on microphone use from configuration mic. name and test the mic. On test mic not works mic,is posible to need a driver for mic and need download and install the driver.
Jul 30, 2010 | Computers & Internet
My mic does not work. when i looked inside computer i notice that a plug that was labled mic power [yellow wire] was not plugged in. I power cleaned the inside with a air compressor and might have jarred...
Desktop PC's do NOT come with any Mic's attached, they only use a Mic, Jack usually Red. You can plug a Mic, into this and use it that way. Also you can get a USB Mic, or headset, this is usually what is done. That Mic. Power, & it supplies power to a thing called an "Electret Mic" I have found a link below.so you can find your manual http://www.foxconnchannel.com/support/downloads.aspx
Mar 05, 2010 | Computers & Internet
No audio sound, mic doesn't work.
For audio please install the mother board audio drivers for your PC. The driver cd is provide with motherboard when it is purchased. If this doesn't work, try connecting the speaker jack to front panel of your cpu.
For mic to work properly, make sure you connected the pink color jack of the speaker to the pink port of the cpu(Back side of cpu).
If did nor find drivers, download it from the internet by giving the motherboard type and the number.
I hope it should work now. Thank you
Sep 06, 2008 | Computers & Internet
Mic problems
http://www.kellys-korner-xp.com/xp_abc.htm click on s and scroll down to Sounds.....
I have Sigmatel too. try this website. I have been working three days on my computer. i tried new drivers (said i didn't need them. i actually went to a message board where people had a similar problem and downloaded (clicked on) a patch (3 small zipped files that were registry keys). It was really scary to trust a two year old message in a message board from a stranger but it restored my sounds instantly. I did back up the registry first. I had deleted codecs (xvid) that i never used and my system sounds disappeared. If this doesn't work, keep googling phrases and look for message boards. good luck
Jul 24, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Hi i have a problem connecting the front pannel mic and standard audio connections to my winfast k8m890m2ma motherboard the manual shows where the 8 pin "front audio connector" is like this...
It is a bit of a problem when you have single connectors but here goes. You use the Front Audio connectors. The manual says you have :::.:
If you turn the board round until the dots are the same way round as above. Working from left to right.
Bottom row. MicIn, MicBios, SpkoutR, empty,SpkoutL
Top row GND, empty, returnR, blank space, returnL. Now this is the tricky bit. Try the power if it works OK. Because the board and the case manufacturer work to different descriptions, try this as an alternative. You may have to swap over the two connectors for GND and Mic Bios.
Mar 10, 2008 | Computers & Internet
Mic
If your headphones have a single plug you cannot plug these into a regular speaker connection or headphone connction and get mic and sound, you will need a headset that has 2 separate plugs (one for Mic and one for headphone) or a splitter you can get a radio shack. Most headsets have only one plug and there are connections for both the mic and the headphones on this plug, but the headphone connection on the computer has only connections for the headphone and therefore cannot detect the microphone.
Feb 20, 2008 | E-Machines eMachines Refurbished EMA...
Dell Dimension 5100 (D51L1) PC Desktop Logo
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
