My CZ25 model of samsung do not function
I have a chance to get a CZ25 Desktop computer functioning well all its audio including VGA when I played some lan games. My problem is after I reformat I do no longer have an access to hear a music and no longer enjoy to play games like ragnarok which I used to play before I reformat it.I've gone to ''Device Manager'' on my system and I found out yellow question mark in its device.What will I do?
    Problem Solver:
  • 9 Answers
This question isn't about a Mac; i'd recommend posting this in the PC section instead. good luck...
Posted on Mar 08, 2009
POWER AT UNIT BUT DOES NOT WORK
If you hope for an answer to your problem then you need to add specific details about your problem. This appears to be a non-functioning audio card, but that's all we know. Is this a card that came with your computer, or did you add it? Did the card previously function, and then stop, or did it never function? What is the Make and model number of the card? What is your computer's operating system? Is this an internal, or external (usb connected) audio card? Once you provide answers to these questions you will have a much better chance of finding help.
Nov 03, 2014 | Computers & Internet
Acer lap top to Samsung plasma
Depends on what type of ports your HP has and what type of ports your Samsung TV has. The easiest connection is to try to connect using the ports that they both have. Otherwise, if they have different ports then you will need some type of converter that goes between the two of them to make them communicate.
Most computers have a VGA port, does the Samsung TV have a VGA Port? New computers have a HDMI port, does the Samsung TV have a HDMI Port? If so you the connections that are alike or you will need a converter.
Once you have them connected, you just have to select the Input on the TV. Most times if you use VGA then you select PC or Computer as the input. There should be an HDMI input selection if you use HDMI connections.
Reboot the computer and the display might appear on the tv. If not you will have to hit some keystrokes to toggle the display between the computer and the tv. Most times on the computer you will hit the FN function key and one of the F1 thru F12 keys that controls the display on an external. The correct F1 thru F12 key will have LCD/CRT on it or it will have the icon of a display. Press and Hold the FN function key then hit the correct Function key (F1 thru F12) that toggles the display.
Apr 07, 2012 | Computers & Internet
Vga compatible
Hi, here you can find drivers and a manual for your
mainboard:
http://support.asus.com/download/Options.aspx?SLanguage=en&type=1
You can use this function:
Model Automatic Detection This function will automatically detect your model, and direct you to the appropriate download page.
Hope this will help you.
Aug 16, 2011 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
A compaq sr1000 need to know what no VGA input means. Will no allow my computer to come on
Welcome to FixYa
No VGA input means that the computer is not detecting video input from the video card. Usually you get this message if the video card of your system is not functional, the VGA cable is unplugged or the VGA cable is defective. To try and remedy this problem try these.
Check if you can hear sound coming from the system. If the video card is functioning then you should here the startup audio from windows.
Check the VGA connection on the back of the system. The VGA cable looks like thismalups_6.jpg
Please note that the VGA cable has two screws, make sure that both are fastened correctly
If the VGA cable is plugged in and you cant hear audio coming from the system. Then this would likely be caused by a defective video card on your computer
Hope this helps
May 28, 2011 | Compaq Computers & Internet
Connot play sound in my pc desktop. os window xp professional. model-compaq pressario-gs178aa-acj sr 5420il
Try one of these solution:
1.Try to get the latest update for your XP OS. (i. e latest service pack and update)
2.Try to download Driver for the audio to function properly (if it is external)
3. If you have a built-in sound controller Try to install your motherboard driver to update all its chipsets
4. Check your hardware stability by right clicking the my computer on the desktop,select properties,select hardware tab, select device manager button,under the sound, expand to see all the listings, check to whether audio devices are present.
5.Try to check in the control panel,select sound speech and audio devices,select sound and audio devices, click sounds tab,under the program events select one of those programs and click the play button if sound can be heard.
Sep 27, 2010 | Compaq Computers & Internet
Onboard VGA port disabled, in Vista
You should try to disable it in the hardware list.
E-machines have an odd bios where not all the functions of the motherboard are available to the user.
If you can find the make and model of your board there is a good chance you can find the PROPER bios for it.
Emachines use motherboards from a variety of regular motherboard suppliers
My older e-machine has a hacked bios so that I can alter ALL the settings.
Aug 24, 2009 | eMachines EL1210-11 PC Desktop
Monitor fault
vertical controll is damaged
Aug 16, 2008 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
