Question about Fisher and Paykel GWL11 Top Load Washer
Machine doesn't power up..
I have a Fischer & Pykel MW051-U. I went to use it the other day, and nothing when I pushed the power button, checked power-point and all is ok.
Does it have a fuse in it that could've blown.
Thanks
  • nlhjr Feb 23, 2009
    Machine stopped in mid-cycle. I pushed power button, but then 2 wash - rinse - spin cycle indicator lights came on, and won't go off, even when I disconnect the power! They finally go off after the power has been disconnected for 4 - 5 seconds. Is this a circuit board problem? If so, how much to fix it? This machine is only six years old, and worked perfectly until now.
  • 70 Answers
OK legendsinc sounds like you motor control unit has blowen and due to age of machine i would not be at all surprised if your seals and bearings have gone, cheak under machine for a brown ring around the casing this is an idicator for failed main seal. Also the big give away is nosy on spin
Posted on Feb 28, 2009
Do "we" have a reset button?
get the technician back as it appears to be a program board fault --again--
This brand is not entirely reliable and went broke and was bought out by the HAIGER company who make s fridges and washing machines
Feb 28, 2016 | Fisher and Paykel Fisher Paykel Intuitive...
I have a fischer and pykel top loader, I would like to know how you replace the valve coils?
You would need to replace the water valve as a whole, the solenoids are not replaceable. What is the problem to want to replace the valve in the first place? Do they fail to allow water to enter the unit or is the flow of water slow? If the flow is the issue, check the screens first before replacing the valve.I hope this helps
Oct 31, 2011 | Washing Machines
New Toshiba labtop. Computer went into sleeping mode How do I bring back desktop screen?
Try to move your mouse/touchpad or press any key on the keyboard. If the machine doesn't wake up, push the POWER button to wake it up.
Jun 13, 2011 | Computers & Internet
I have a MW051-U washing machine Istarted a load of washing then the machine stopped with the unbalanced beeps, I took out the towels then placed them back in, but now washing machine wont start up again....
Start by balancing the machine.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If powering off, leaving for 30 minutes then on again does not clear, a manual should help as I'm not 100% sure of another way and a manual could help for problems in the future.
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Mar 23, 2011 | Fisher and Paykel Washing Machines
Will not start washing
dear sir/mam
have you checked the motor of the washer (check the supply across the motor terminals and if you find normal supply motor should be changed and if you find no supply then check the circuit of the motor.
Sep 11, 2009 | Fisher and Paykel GWL11 Top Load Washer
Can't get the ansewering machine to work? we were gone for 3 days. When we got home the ansewering machine was not blinking, I thouht no loved me! No messages. then relatives called saying they had tried...
You might try unplugging the AC power to the unit, let it sit for 5 minutes, and reconnect the power. That sometimes resets the unit to the factory default. You can then reprogram.
Aug 23, 2009 | Panasonic KX-TG1033S Cordless Phone
After power outtage my f/p washer is dead -no lights nothing
Only reset is to unplug it. Are you sure you have power at the outlet? If you have 120V at the outlet the power surge may have blown the controller, not a cheap fix :(
Apr 12, 2009 | Fisher and Paykel Fisher & Paykel Washer
Smart drive washing machine not filling properly?
sounds like you do have a solenoid problem undo hoses from back of machine check the filters are not blocked also check at the tap end to see if filter are cleare if all filters are clear most likely you will have to replace you inlet valves assuming there is no problem with pcb board.
Mar 29, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fischer Paykell 7.5kg Smart Drive top load washer
Have you checked the lid micro switch under the motor controller which activates when you close the lid to start the machine?
Jul 24, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GWL11 Top Load Washer Logo
157 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
