I have just bought a philips webcam for a vista computer and when i try using it on msn it doesnt work , it worked once last night but now when i try to use it it says that the webcam is already in use. PLEASE HELP !!!!!!! :( :(
    President:
  • 8,637 Answers
Normal 0 See section C. Windows Live Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
C. Windows Live Messenger: http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jun 24, 2009
Installed Philips SPC630NC web cam will not display picture on Msn Messnger live just a green screen, all drivers have been checked and software but just a green pictur, it wont work on any other cam site...
Set your mic as default
Vista
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
If it fails to work here concentrate on your webcam drivers and software before moving forward.
Set your webcam mic (if it has one as default)
Vista -
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Jun 15, 2010 | Philips SPC 630NC Webcam Fun - Web camera...
Wont work with windows live messenger 2009
Try going into the 'audio adn video' options in MSN and tuning the camera and audio.. ie testing it out. You have to choose the camera n stuff.. so you may not have it as default..
Jun 01, 2009 | Microsoft LifeCam VX-1000 Webcam
My webcam does not work on msn
first you need to know that if you used xp ...and upgraded to vista ...you need to find a compatible driver for your web cam too ...if your web cam used to work just fine on vista ...and its just the msn issue ...just reinstall the latest MSN messenger and it should be enough ...also verify the proxy servers on the messenger preferences..and set 'em to fit the kinda conexion you use...
but I suspect a problem with the program settings ...so the easy way is just to install the latest messenger(MSN) available for vista ...and it will be ok
May 17, 2009 | Logitech QuickCam Pro 5000 Webcam
My webcam wont work on msn
double check your msn settings to see if its configured to use your webcam as its webcam device. try running the phillips software first and see if the webcam is actually functioning and verify that its installed properly...you can also just try a simple re-install of the camer and see if that works. soemthing silly...see if the camera has an on/off button (they usually do for privacy to turn it off immediately and it doesnt neccessarily say "on/off".
Apr 26, 2009 | Philips SPC611NC Webcam
HP 2133 mini-note PC webcam stopped working!! Help!! PLEASE!! :((
In your control panel you can select system properties and then device manager.
If the webcam had a yellow ! then you will need to install or update the drivers. Drivers can be found under the support section at the manufactures website.
(easy way to system properties is windows key + break key)
Apr 16, 2009 | HP 2133 Notebook PC
Dell webcam manager working with msn messenger?
as ive told others, make sure u actually turn off the software program that came with the computer before using with msn! u should be able to have it on while using it but for some reason some computers wont allow it! it "tells itself" that there are 2 programs trying to run the web cam when really only one is.
but because the program is on, it sees it as being used in 2 places at 2 different times!
try turning off and exiting the software (dell webcam manager) and then go onto msn and try using ur web cam!! make sure the dell manager is exited, then when u have a msn window open, turn the cam on and see if ur friends can see u then..
good luck..
if this doesnt work ill check back and see what i can do for you!
Mar 21, 2009 | Dell Inspiron 530 Desktop Computer
Crystal Eye Webcam wont work on MSN!
your cam has to be setup on msn as well After you start Windows Live Messenger,
Next go to the Menu Bar on right side, click on Action.
let me know if this helped
Jan 19, 2009 | Acer Aspire 5610-4648 Notebook
Philips spc 700nc web cam
First of all, have you verified you are using latest version of MSN messenger. If so and the problem still exists, give one of the other instant messengers a try, say like YM or AIM or any number of others.
What exactly do you mean by ' seems to work '?? Can you see yourself in the cam using whatever software other then MSN that you may have on your computer.
Feb 20, 2008 | Philips SPC700NC Webcam
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
