Question about Apple PowerBook G4 Mac Notebook
Screen moves in reverse direction to curso
When using the trackpad on my G4 laptop, the screen moves about half a centimetre in the opposite direction to the cursor on initial trackpad input, and during any subsequent change in direction. Is this problem likely to be software or hardware related? This problem developed spontaneously about a month ago. I have recently updated to Leopard, same problem. I installed two-finge trackpad scrolling around a year ago, no problems, but wonder if it might be related to this?
  • gconeill Mar 30, 2009
    I managed to fix the problem by using the Apple-F12 function key combination, which I found at this site. But thanks
  • 55 Answers
Go to the system preferences and look at the universal access, check to see if you have turned on the "seeing" section, if so turn it off, this might be the source of the problem
Posted on Feb 22, 2009
Thank you, Krabby. I installed the security update 2009-001 last night and when I started up my macbook pro this morning I had the same problem gconeill desribed above. Your suggestion was the fix.
Posted on Mar 29, 2009
My ibook g4 track pad works when i move it around the screen but i cannot click a link without having to use the button. how do i fix this.
More than likely, you have the preference for "tap to click" turned off. To fix this:
  1. Go to Applications/SystemPreferences.app or the System Preferences dock icon
  2. Click on the Mouse preference button
  3. Make sure that the checkbox next to "Tap to click" is turned ticked
* If you are using a more recent version of OS X you will instead see a "trackpad" option in System preferences. This is what you want to select to change this setting
Feb 10, 2011 | Apple iBook Mac Notebook
Curser stuck in upper left hand corner
If you want to use a mouse with your laptop, find the preference that ignores the trackpad when the mouse is present. Go to System Preferences in the Apple menu (upper left corner of screen). Click Keyboard and Mouse" or Trackpad (depending on what you see). Un-check the option that says something like "Ignore the trackpad when the mouse is present."
(I don't see it in anymore 10.6, which won't run on your PowerBook anyway.)
Bot
Apr 08, 2010 | Apple PowerBook G4 17" 1.33GHz Mac...
Screen image unstable
Sounds like your screen is set too big for your PC... it may just be a settings issue in your display properties. Right click on your desktop and go to properties, check in there and change resolution and things.
Doesn't seem like bad hardware.. just seems like a software setting is set improperly.
sorry i can;t be more help.
Sep 15, 2009 | Formac ProNitron 21/800 21 inch CRT...
Typing moves?
It could be that your hands are brushing against your trackpad.
Jun 16, 2009 | Apple PowerBook G4 Mac Notebook
Keyboard either freezes up or nonsenseical screens pop up
Sorry to hear you are having trouble,
Well, unfortunately, this PowerBook has the trackpad and the keyboard on the same cable connected to the motherboard. ( When you say the mouse works, you actually meant the trackpad right ? )
Cleaning does not help, we had the same problem but in reverse, the keyboard worked fine but the trackpad would not, even the click...
Apple will replace the entire top case to repair this even though it's just a little cable, that cable is really hard to replace by itself.
Sorry, it's a 200$ repair job.
Mar 30, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Failure to reboot after a Software update.
Hi stuart,
It sounds like you either may have a corrupt system or a faulty hard drive. Try reinstalling OSX with the system discs that came with the computer. You can still keep everything if choose the "Archive and install" option.
If this doesn't help, then I'd say the hard drive may have seen its last days.
Verb
Mar 30, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Reversing the Acer Aspire One screen
Hi there.
No you can't do that as you will wreck the laptop, to save any damage to the laptop you can use a external monitor and switch your graphics to that monitor only, it will be cheaper and more convenient doing it that way.
If you want to spend a bit of money there are laptops out there with swivel lids.
Good luck and thanks for using FixYa!!
Mar 11, 2009 | Acer Aspire One Netbook 8.9" Notebook
Trouble with screen (powerbook G4 15" 1.67 GHz)
Well the issue isn't with the graphic card. It actually is the screen of the PB (PowerBook). I had somewhat of the same issue about 6 months ago on my 17" PB G4. But when it started to do that with mine, the screen would also make sharp vertical lines when opening and/or adjusting angle. So before my Apple Care warranty expired I had the screen fixed FREE. So, if you do have your Apple Care warranty still and not expired, I'd suggest to you to find a Apple Certified computer shop or the nearest Apple store and drop it off with the explanation to have the screen replaced. Otherwise you will have to pay a pretty penny.
And if you do not have the warranty then i suggest you not to take it to a Apple store due to the extreme cost of a new screen on an old machine. Instead goto ifixit.com. This site is great for anyone who has anything portable from Apple (including the non-portable MAC-mini) for replacement or upgrade parts, cheaper and also helps with the install (DIY instructions and pictures to go with it)
- Luke
Jan 28, 2009 | Apple PowerBook G4 Mac Notebook
This is a duplicate issue with a different title. Please only post one. Check the solution given to your other post. Thank You.
-Luke
Jan 28, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple PowerBook G4 Mac Notebook Logo
316 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
