There had some kind of registry problem my son tried doing "something" dont know what When first turned on showes COMPAQ in red and displays accross bottom screen esc boot menu, f1 setup f10 system recovery have hit all seperately does recovery shows boot meny ans set up restart goes back to same message
May I suggest use the Restoration Disk?
Turn computer on, open optical drive (CD/DVD drive), and put disk in.
Close drive tray.
When asked choose Repair. Non-Destructive Installation.
Repairs the basic Windows files, and your on your way.
Do not have the Restoration Disk? No problem. Get it from HP Support.
Posting from a USA view;
The disk is free. The shipping and handling is not.
$17 for a 5 to 7 day ship, $24 for a 2 to 3 day ship.
Call 800-474-6836 - 24 Hours a day, 7 days a week.
Write down the Serial Number, and have it ready to give to the nice representative on the phone.
This is in the white Service Tag, on the back of the computer.
S/N = Serial Number.
For all countries use HP Support Worldwide,
http://welcome.hp.com/country/w1/en/support.html
If I may;
If you do send for the Restoration Disk, and are not in the USA; may I ask are the shipping charges about the same?
For additional questions please post in a Comment.
Regards,
joecoolvette
SOURCE: my pc only goes to reboot screen i have tried all
CHECK HARD DRIVEIS DETECTED OR NOT ...IF DETECTED INSTALL OPERATING SYSTEM
SOURCE: compaq presario 5000 desktop won't boot!
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
SOURCE: Issues with some programs and
Boot from your Windows installation disk and try to repair the Windows installation. NTLDR means NT Loader,it's the primary boot file for your OS.
You can repair if it can,or re-install.Just don't reformat during the process or it will wipe everything off your HDD partition.
Bob
SOURCE: What keys do I press to get the CMOS setup screen on a Compaq Presario 5222?
<DELETE> is what works on mine
