Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I receice " no broadcast now" ec 203 on my tv
I cannot turn power off or change channels.  I can remove power by unplugging the tv fron the wall but when I replug the tv, I have the problem.
  • Devon Sacco
    Devon Sacco May 11, 2010
    Did you try the system reset button on the back of the TV?
    Sergeant:
    Champion:
  • 267 Answers
Either one of thje buttons on the unit itself is stuck in, or you have a problem with the main total assy board. A data or serial line is locked up. replace board
Posted on Mar 06, 2009
Why is my remote control not working despite changing the batteries.
Not sure if this will help but, I recently put an antenna on the roof of my house. I don't watch TV much but wanted to enjoy some TV, but my remote locked up and the side buttons on the TV wouldn't work either. I tried changing the battery, but no luck. There's a broadcast station 64.2 that is locking up TV's & remotes. Here's the fix that a TV repair co. gave me which did break the lock of the station 64.2.
1) unplug antenna (not roof but connection from TV to wall)
2) unplug and plug back in TV
3) find a way via remote or side buttons to scan channels
4) Go to Menu
5) EZ Setup
6) Channel Set Up-Scan Channels
7) Channel Memory
8) Digital Set Up
9) Turn Skip On for 64.2 (Delete this Channel)
10) Turn off TB
11) Hook Antenna back
You may have to play with the order to acheive the end result or figure out a way to delete 64.2, but during the process you will at least unlock from being stuck on 64.2.
Good Luck if this was the same issue!
Jul 14, 2014 | Audio Players & Recorders
Sony TV problem.
Chances are the CRT has expired. In that case I would recommend replacing the entire unit.
Mar 06, 2008 | Video Game Consoles & Games
Tip
Krups 203 Blade Replacement Procedure
<span>Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.<br /><br />Unplug your Krups grinder from the wall.<br /><br />Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.<br /><br />Put your safety gloves on and then grasp the blade of the grinder with your channel locks.<br /><br />Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.<br /><br />Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut. <br /><br />Things You'll Need<br /><br /> Cloth<br /> Safety gloves<br /> Channel locks<br /> Pliers<br /></span>
on Jun 02, 2011 | Krups 203-42 Electric Blades Grinder
Tv freezes
You need to boost your signal somehow, get a better antenna. nothing is wrong with the TV, this is a typical Dropout when signal is low.
Tony
Apr 16, 2014 | LG 32LD550 32 in. LCD HDTV
Tv come with no sound or pict.
Check whether the product is turned on.
Try another channel. The problem may be with the broadcast.
Is the power cord inserted into wall power outlet?
Check your antenna direction and/or location.
Test the wall power outlet, plug another product's power cord into the outlet where the product's power cord was plugged in.
If these tips don't work, you can also try to power cycle the TV. Turn the TV off and unplug it for about a minute. Plug it back in and power it back on to reset the settings back to factory default.
Oct 18, 2013 | LG 32LG30 32 in. LCD HDTV
Television buttons unit do not work
Try power cycling the TV. To do so, unplug everything from the back of it, power off the TV and unplug it from the wall. Leave it unplugged for a few minutes, and then re-connect and plug the TV back into the wall. Turn it on and reset any system setting changes back to factory defaults. If the problem(s) still exist(s), then I would recommend scheduling repair service.
Oct 05, 2013 | Insignia IS-LCDTV32 32 in. Television
I took off cable box,turned cable off on tv menu. Put rabbit ears on then went channel set up to auto programming.It asked me, are you sure. I said yes, now my tv is stuck on one channel. How can i solve...
I do beleive most tv companies stopped broadcasting over the air. the only way to receive more channels is to take the cable wire that comes out of the wall and then into the tv then auto pragram one more time and see if this helps. One question why would you remove the cable box? if you cancelled cable tv all together you will not get any channels. And like i said before all tv channels are removing there air broadcasting. so rabbit ears are going to be in the past soon. i hope this clarifies the situation.
Feb 22, 2009 | iLO 3200 32 in. LCD Television
Digital Converter Box
Hi William
You TV is able to receive Free to air Terrestrial Analog broadcasts by just connecting the antenna. However if you wish to receive Digital Terrestrial broadcasts (DVB), you need to obtain a digital receiver for Terrestrial Digital Broadcasts. It can be easily connected to your TV.
Nov 11, 2008 | Televison & Video
My dvd shows prog 200 and wont change
FIXED! LG DAT-250W INSTRUCTIONS: TURN OFF THE MAINS POWER AT THE WALL UNPLUG ANTENNA FROM THE BACK TURN POWER BACK ON AT THE WALL & START AS NORMAL IT WILL COME UP WITH "POOR SIGNAL" THEN WE FLICKED THROUGH THE CHANNELS & TURNED IT OFF AGAIN AT COMPONENT & AT THE WALL PLUG THE ANTENNA BACK IN TURN EVERYTHING BACK ON Note: **Just avoid the channel that keeps locking up** LG are aware of this issue
Sep 30, 2007 | LG Televison & Video
RCA MM61110 Television
I had the same problem sometimes when my Gold Plus would reset itself and include all the channels but only those Over-The-Air channels. The only way I could change the programming was to completely shut down the power. Not just turning the tv off but completely unplugging it from the wall outlet. When you turn your tv back on you'll be able to choose from Antenna/Cable option. As for Guide,if you don't want to use it, don't set it up, it won't effect anything else on the television.
Aug 08, 2007 | RCA MM61110 61" Rear Projection Television
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
67 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
