Question about Otis Rome Vamp Snowboard Boot - Women's
Boot lacing system broken at first use, how to fix?
Where can i get a new lace for my BOA System
Posted on Nov 14, 2009
    Problem Solver:
  • 14 Answers
What type of lacing system is it?
Posted on Jul 10, 2009
  • Cody Thomas
    Cody Thomas Jul 10, 2009
    what type of lacing system is it?
3 Suggested Answers
SOURCE: I have a pair of DC Siloh boots that are a couple
I have exactly the same problem. I just wounder if you managed to solve it yet? I don't know what to do, but every time I try to put them on I have to struggle for about 20 min! It gets so annoying!
Posted on Jan 09, 2011
  • 3 Answers
SOURCE: Broken cable on BOA lace system on snowboard boots
i just recieved a new lacing for my Rocky revolver boots... there is a little tool to loosen the set screw in the knob...works like a charm.
Posted on Mar 17, 2010
Rapid lace system problems.. uneven lace
Hi All,
I had an uneven problem with the DC Siloh '09s. Not sure if it will cover all makes and models but I will explain how I fixed it.
Key for the instructions:
Numbering the laces from top to bottom 1-8, outer side of the boot = little toe, innerside = big toe, and on the two laces that lock on either side of the boot (4 in total) toe and heel lace.
1. In order to make the laces even again you need to unlock the heelside lace on the outerside of your boot, this lace controls lace 3.
2. Pull lace 3 using creating slack now that it is unlocked
3. Pull the slack through lace 4 and then 5.
4. Once you have slack in lace 5 unlock the toe side lace on the inner side of your boot.
5. Holding that same lace pull the slack through the locking mechanism until you are happy with the balance.
For moving slackness from the inner to the outerside the opposite approach applies.
If it is not clear, reply and I'll try and take a photo or post a video or something.
Cheers
Mikey
Aug 12, 2012 | DC Shoes DC Methvin Snowboard Boot Men
The patent leather on my laces are coming off took them to a shoe repair he said nothing he can do help I want to wear my shoes
Theres the obvious which is get new shoes because they do still make them, but there are other solutions. One you can wear the laces as they are. Two you can look online to find new laces, but they are extremely hard to find. Three look for laces that are similar but can replace the laces. Four buy a used pair just for the laces. Now all of these will only work if they laces can come off. If not then there is nothing you can really do to fix the laces the way they were unfortunately.
Jun 03, 2011 | Rocawear Sofi Sandals for Women
My Burton Snowboard Boot laces have come detached from the boot. Looking at the Burton website they say that it is from resting my board on my boot. Basically the bottom two laces have become detached. I...
Do you mean the lace eyelets?
if this is the case, you can either sew them back on with thread or hot glue them. if it is the actual laces that came out. Buy new laces and replace them
Mar 01, 2011 | Burton Mint Snowboard Boots (Women's)...
My Burton boots are loose around the ankle and the laces do not stay tight. Any recommendation would be appreciated.
For the ankle you may need some specially shaped foam inserted between the boot outer and the liner to take up the space. This can be done at any good snow store. As for the laces make sure that when lace up in the morning lace the boots all the way to the top and when you reach the top, while holding the laces, flex in the boot a few times and kick your heel against the ground to make your your foot in snug (this may also help issue #1. Once you have done this, pull up hard again on the laces and loop them once around the top before tying a double knot.
Mar 12, 2010 | Burton Winter Sports
I have a pair of DC Siloh boots that are a couple years old, and I'm having some trouble with the rapid lace system. The lace on the inside of the leg, which tightens the lower half of the boot, will not...
Mar 05, 2010 | DC Shoes DC Siloh Snowboard Boot - Women's
Feb 28, 2010 | Burton Winter Sports
My right boot laces are unraveling, about to break. where can i go to get them replaced?
i bought a set of lacing. BOA on the internet..little tool comes with them..easy to replace.
Feb 20, 2010 | Salomon F20 Snowboard Boot Women's
I am unable to loosen the laces on the exterior of the boot. Only the bottom half is loose and the top three laces remain very tight.....as if there is a knot inside the boot lining.
Sometimes if the boots have been well worn the lace will pill inside its tubing and become stuck. The best way to fix this is to untie the jammed lace at the bottom and then pull from the top to remove the damaged lace. You will also need to get a replacement lace from your Burton store to repair in reverse.
Feb 11, 2010 | Burton Moto Men's Snowboard Boots '09
Size 13 black 2008 DC torch boa lace on the lower half is jammed....any idea what i can do?
Hello. you will have to use a pair of pliers to remove the lace and then use an ice pick or similar tool and a hammer to reshape the hole that the lace goes through. If you go to a hardware store they will have cold steel punches of various sizes that may be useful to you.
Dec 07, 2009 | DC Shoes 08 Dc Torch Snowboard Boots Size...
Single or double boa lacing for snowboarding boots?
Ok so I have had both the single and double boa lacing system boots before. the string on my double boa boot snapped once but that's because my boards edge was grinding into it when i rest it on my free leg on the chair so thats my bad. I thought that they were really comfortable when i was wearing them. Then last year I switched to Burton Ruler boots and OMFG are they good. They are wayy better than the boa system. The rules have an individual lacing system for the the foot and leg so you can tighten each section to your prefrence. They also feel really comfortable and are faster to get on and off than the boa. When I got them I was walking around my house for a few hours with the boa boot on one leg and the ruler on the other. The ruler was just as stiff as the other one, but felt a lot more comfortable. Its hard to describe but the boa boot felt like it was some kinda of mechanical contraption on my foot while the ruler had a very natural feel to it. Dont know if that helps but thats the only way I can describe it. Check out your local shop and try on both at the same time and you will feel the difference. I used to be a DC only person, but now I am sold on the Burton boots. Good luck.
Dec 01, 2008 | Kicker Forum SLR Snowboard Boots
Otis Rome Vamp Snowboard Boot - Women's Logo
853 people viewed this question
Top Otis Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you an Otis Winter Sport Expert? Answer questions, earn points and help others
