Question about Tyan Tempest i5000PX (S5380) (S5380G2NR) Motherboard
PC not Booting up
Hi My name is John and I have a problem, cpu fan on my Asus baord is running but there was no display on the monitor, also no beep sound at POST. Can some body help me where can the problem be?
  • 60 Answers
Dissemble your whole PC. Clean thoroughly. Check BIOS battery with a multimeter. Try to boot without expansion cards. Change RAM if you have extra one. There are so many procedure you can take. Keep informing.
Posted on Feb 22, 2009
Asus p5sd2-vm no beep, no monitor display. psu and cpu fan are both running,processors is okey when tested,cmos battery removed for 24 hours and re-installed again still theres no life sign of my pc.... no...
Hi, you can download a manual here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5SD2-VM&p=1&s=22
Please select your operating system.
Select manual and click on global for download.
The file needs to be unziped before you can read it.
I think the the graphic card has maybe burned off or simply
not working.
If you can enter the bios to look for fault.
Try also to test the monitor on another pc
You can add a display card in the PCI-E x 16 slot
then you have graphic again. Its the black slot on the mainboard.
Make sure you have drivers or can find drivers for it.
ATI and NVIDIA makes such a card.
Aug 26, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Not booting
listern to what ur beep codes say. one short-fine, one long & two short beeps-video failure, so on ... ... ...
May 02, 2009 | Dell Dimension C521 PC Desktop
ASUS P5KPL-AM CPU fan connection.
You should still be able to connect the 3 pin connector of the fan to the 4 pin connector on the mobo, the keying tab is offset so that you cannot connect it to the wrong pins.
If you still don't want, or can't connect it there, simply go on the Bios (press delete after you turn on your computer) and you will find an option to monitor CPU fan speed.
If you need any more help, let me know
Alex
www.CAS411.com
Mar 28, 2009 | Computers & Internet
Asus p5b-mx motherboard not showing display but every thing is on
Hi camlamm, check out Asus CPU supported list link;
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5B-MX&os=17
See if your CPU is in the list.
Bios not booting? If you are receiving any display on your monitor the trouble is not the graphics card. Suggest you clear the cmos jumper. See page 1-26 instructions your manual. This Asus board is warranted for three years. If nothing gives you access to the bios, suggest you call Asus tech, M-F, 8:00AM to 5:00PM EST at: 1-812-282-2787.
Good luck camlamm!
Thank you for using fixya.
Mike
Dec 11, 2008 | ASUS P5B-VM DO Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
Pc is not booting and no display in monitor
First, try resetting the CMOS. If it is not working, replace the RAM. Could be a damaged RAM
Sep 11, 2008 | ASUS (P4BGV-MX) Motherboard
No display, no start up beep, no post and no boot
You need a Molex power plug (same as for your standard IDE hard drive or DVD drive to an 8pin adapter. A common product. If you can't get it locally.
Without this the board won't boot as there is insuffcient power on the motherboard to drive your display adapter.
Here is the link to the product at crazypc.com.
Also, if you have onboard video too, make sure the bios setup pages have the property set for primary display adapter to Add-in/PCIe.
Regards,
Worldvet
Jun 19, 2008 | Intel Motherboard
try to clean your video card and ram using the eraser.
Mar 17, 2008 | ASUS P4VP-MX Motherboard
No any display in the monitor, no beep of the RAM while CPU fan is running
Check your power supply. It sounds like you have a bad power supply. Even though the computer powers up, it does not mean that it's good. I have had this problem before, and almost 9 out of 10 times the power supply had gone bad. Just try a different one and see. hope this helps you.
Oct 01, 2007 | ASUS P5S800-VM Motherboard
Tyan Tempest i5000PX (S5380) (S5380G2NR) Motherboard Logo
310 people viewed this question
Top Tyan Computers & Internet Experts
Jerry Umali
Larry Chandler
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
