I am not using this router but i am giving you normal password setting steps...
Open you web browser and put the IP address and login your router with username and password(default). Now find to reset password,it will most likely be under the "security" settings.
You will need to select WEP or WPA settings (WPA is more secure) and if WEP, choose a 128 bit encryption rather than 64 bit. Keep in mind that the moment you save it, you will loose your connection until you add the password in the settings on your computer that control the adapter that receives the signal from the router.
It is also advisable to make your SSID invisible to others; that way it will be more difficult for your system to be found and hacked.
****If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
SOURCE: Blitzz Wireless Router not working correctly
Here is a site that will help you setup & or troubleshoot ya rig.. http://portforward.com/routers.htm
SOURCE: Blitzz BWA611 Router
a router shouldnt need to dial for a connection, go to open your internet browser and go to tools, then internet options, then click connections tab and select never dial a connection so as to stop internet explorer looking for a modem connection
SOURCE: Blitzz Router
Ah, you can no longer use the modem or the Blitzz screen to connect to your Internet connection. You'll need to patch another Ethernet cord from the router to your Ethernet port on your computer and it should automatically connect. If you still get prompted to dial, open up Internet Explorer and ignore any prompts to dial and then click Tools, then Internet Options, then click the Connections tab at the top, then click the selection to Never Dial a Connection. Confirm your choice by clicking OK and then try browsing the Internet like usual.
SOURCE: Need to set a password for my blitzz wireless router
i did a google search and came up with this website: http://azureuswiki.com/index.php/RouterConfiguration#Blitzz_BWA611_NetWave_Base_G4
it has all of the information you need to set up your blitzz
SOURCE: set up password on blitzz bwa711 router
Login to the default router config page from your desktop pc. This is usually plugged straight into the router via a network cable. Go to http://192.168.1.1 in w web browser. Default login is usally "Admin/Admin" or "Admin/Password" keep trying different combos.
You may also need to press the "Reset" button on the back of the router.
