Question about Lexmark X6650 4-In-One Wireless InkJet Printer
Got x6650 can not get past connect your printer on the setup Cannot get passed the connect printer when setting it up, I have tried more than 10 times to set this damn thing up....
    Problem Solver:
  • 7 Answers
Try this:
- Uninstall everything about Lexmark.
- Delete every Lexmark entry in the Registry.
- Reboot your PC.
- Make sure not to connect the USB cable.
- You need to install the driver first before connecting the cable.
- Instal the driver, make sure your using the right driver. Check Lexmark.com for the latest driver.
- If this does not work, call lexmark.
Posted on Mar 09, 2009
How do connect a x6650
Simply run the X6650 installation software on your computer. The software will also show you detailed instructions on how to setup the printer itself. If you don't have the installation disc, you can download and install the X6650 printer driver from the Lexmark website.
Please visit the Lexmark website to download and install the Lexmark X6650 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Jan 15, 2012 | Lexmark Office Equipment & Supplies
Need to delay fax pick up time
Please follow the steps below to configure the Pick-up On setting on your Lexmark X6650 printer:
  1. From the printer operator panel, press the Setup button.
  2. Go to Fax Setup.
  3. Go to Ringing and Answering.
  4. Go to Pick up on.
  5. Select your preferred number of rings before your fax picks up the message. Press OK to save the setting.
I hope this helps.
Should you still need assistance. please leave a comment to my response and I'll get back to you. Thanks.
Oct 19, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
I can't get my Macbook setup to use the Lexmark x6650. I used the install disc and the wifi light on the printer is green, but I still cannot figure out how to setup my Macbook to print to is...
Print the network settings page to identify if your printer is connected to your wireless network:
1. Press Setup on the printer operator panel.
2. Press the right or left arrow button until Network Setup is displayed, press OK.
3. Press OK at Print Setup Page.
4. Press OK when prompted to Load Paper.
5. Press OK. The network settings page will now print.
Check the Network Card Status, SSID, Trouble Code, TCP/IP Address. SSID should be the name of your wireless network. Otherwise, you may need to reset the printer's wireless network settings.
How to reset network settings:
1. Press Setup.
3. Press the right or left arrow button until Reset Network Adapter Defaults is displayed, press OK.
4. Press the right or left arrow button to display Yes, pressOK.
Once the Wi-Fi light turns on to solid orange, run the Lexmark Wireless Setup Assistant on your Mac.
Sep 21, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
How to connect my printer to wifi
Here's what you can do:
  • If this is your first time to install the printer on your computer and if you have the Lexmark installation disc that came with your printer, just insert the disc into the computer hard drive and execute the application. The software will guide you on how to setup the printer for wireless connection.
  • If the printer software is already installed on your computer, go to Start (for Windows) menu > Programs > Lexmark 5600-6600 Series > Wireless Setup Utility. Follow the instructions on your computer.
  • You can also download the Lexmark X6650 printer driver from the Lexmark website at http://bit.ly/gFQFVh. Follow the instructions on your computer.
Aug 30, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Have windows 7 setup x6650 have framework errors, have solve that now i can not use print productivity center, or scan
This sounds like a driver issue. Try to uninstall your X6650 printer driver from your computer (follow steps in this article: How to Uninstall Lexmark Printers). Restart your computer when prompted. Next, check if your Windows 7 is running on 32-bit or 64-bit System Type by clicking on Start menu (on your computer) -> Computer -> Properties. Take note of the System Type. Then, download the printer driver using the one of the links below (whichever is compatible with your system):
- Lexmark X6650 Driver for Windows 7 32-bit - Lexmark X6650 Driver for Windows 7 64-bit
Apr 19, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
I need to know how to set it up
http://www.retrevo.com/support/Lexmark-X6650-Multifunction-Printers-manual/id/22273ci877/t/2/
try this link, ou can download the manual here, hope this will help you set up your printer.
Nov 14, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Trying to copy a document. I'ts 8.5 x 11. It's only copying the upper right corner of the document. Can't figure out why. Help.
Reset the printer to default settings.
  1. Press Setup.
  2. Go to Defaults.
  3. Go to Set Defaults.
  4. Select Use Factory.
  5. Hit Ok to reset the printer to factory default settings.
  6. Reconfigure the printer with the printer settings (Country, Time, Date, etc.)
  7. Try copying.
NOTE: Wireless connection won't be affected when resetting printer to default settings.
Oct 12, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Unable to setup wireless connection
found link for the complete manual for the wireless setup. http://support.lexmark.com/index?id=so4452&locale=en&productCode=LEXMARK_X6650&segment=DOWNLOAD&page=content&actp=HOTTIPS&userlocale=EN_US#Install_and_Com_Troubleshooting
Apr 06, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
I just brought home a Lexmark X6650 and a brand new gateway laptop with windows vista. I get an error everythime I try to install the lexmark printer and it will not install correctly or print anything. It...
when you look at the icon of the printer does it have a check mark on it or in the upper right hand corner of the icon? you can also make sure its the default printer by right clicking the icon and selecting "default printer" then try doing another print test.
Feb 01, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
Lexmark X6650 4-In-One Wireless InkJet Printer Logo
162 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
