Question about ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card
I have a asus 256mb en7200gs graphic card it worked fine for a month but now it does not work when i install it with it's drivers it installs and after restarting my pc it just restarts just after coming to desktop. what to do
  • 1,602 Answers
Remove the card, get the old drivers for the motherboard and reinstall them, then see if you can get the system running, if the problem continues to reboot every time you are going to have to reset the motherboard this means shorting out the bios and setting everything back to manufacture orignal setting, before doing this go in to bois and write down everything on the type of drive and all the information on that line
cyclinders
heads
precomp
sectors
lba
so one
how the systems boots firsat hd, dvd, cd, floppy
on the motherboard is a sitch 1-3, most of the time it is on 1-2, you need to move the switch 2-3 for a few seconds and move back to 1-2, reboot
go into cmos
set up everything the way it was before you reset the system everything should work fine
reinstall the video card and drivers
disabling old drivers
Posted on Feb 27, 2009
Pis driver
hi
go to following link you will find your drivers
http://www.userdrivers.com/Video-Graphic-Adapter/Asus-EN7200GS-HTD-256M--Graphics-Card
Oct 06, 2010 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Install VGA of Video card
with your VGA card in pci slot locate the vga pci slot in our motherboard insert it firmly. Turn on the pc and make it sure that pc detects your new card and install the vga card driver supported by the manufacturer.
Feb 09, 2010 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
My Asus EN7200 GS stoped working, lines appeared in my monitor
you must be reset your bios put on jumper coms clear choice 2-3 then reset configure position again 1-2 then computer is ready activate built in agp
Thanks
Nov 22, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Asus EN7200GS
PCI simple Communication controller refers to a modem which is installed in your computer but with no driver installed.
Here is the web address for your graphics card:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Regards,
Graemevm
Apr 20, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
I bought a asus 256mb en7200 gs graphic card it worked fine for a month but since two months it is not working properly it just get hang when i start my pc when coming to desktop or in games and restarts...
If the problem occurs right as the windows desktop comes up from a cold boot, it is not a cooling problem, the card hasn't had time to heat up yet.
You probably have a bad driver, download at http://support.asus.com/download/download.aspx your series = Nvidia, model=en7200 series and install new drivers.
Also, check to make sure the card is fully inserted in the AGP slot, I've seen some odd things happen because of a loose card.
Feb 23, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
My pc starts hanging and after that restarts
THE PROBLEM IS THE POWER SUPPLY MAY NOT HAVE ENOUGH POWER TO SUPPORT THAT VIDEO CARD.
THIS VIDEO CARD IS CAUSING THE PWR SUPPLE TO OVER WORK
THE MOTHERBOARD IS EFFECTED BY THIS TO.
CAUSING RAM TO OVERHEAT ALSO.
NOT ENOUGHT AIR FLOW THREW THE COMPUTER SYSTEM.
THE BIGGEST KILLER FOR PERFORMANCE IS HEAT.
YOU NEED ADDITION COOLER IN THE SYSTEM TO COOL THE POWER SUPPLY,
VIDEO CARD, RAM, CPU.
HERE IS A COMPANY FOR THIS PROBLEM YOU ARE HAVING
WWW.ACOUSTICPC.COM
THEY HAVE LOTS OF DIFFERENT COOLING AND COOLER DEVICES FOR COMPUTER SYSTEMS
ROD
Feb 20, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
I have a asus 7200 gs 256mb graphic card my pc keep restarting
Your PC keeps restarting because while playing your video card is highly solicited,and this causes overheating. The solution to your issue is to buy a cooling fan and attach it to the cooling grid.
If this solution worked for you please rate it. If you require further assistance feel free to post a followup comment.
Feb 13, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Pc restarts in between the games
is it summer now there? It sounds like heating problems. If you keep the system very cool does it still do the same? (Try opening your side panel, and putting a fan in front of it, blowing into your case, also check to make sure that the fan on the gfx card can spin freely and isn't hampered by dust particles. Also do you have thermal paste? i recommend taking your cpu heatsink off, wiping off the old paste, and applying new paste. I've seen thermal paste get old and then cause this kind of problem. If that still doesn't work, try drivers like bunny recommended. Good luck! :)
Jan 04, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card Logo
171 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
