Question about Radio Communications
Uh049sx will transmitt but cannot hear response
  • 1 more comment
  • gavan1 Mar 14, 2009
    the word "BUSY" appears on the screen and i cannot find how to turn it off in the manual
  • beeeeen Apr 20, 2009
    I have the same problem. I can't get rid of the word 'Busy'.
  • Anonymous May 20, 2009
    something inside on the squelch side has to be soldered i just cant find what
How to program a new alarm remote
Transmitter Programming
No Tools Required
In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Perform the following steps:
Sit in the vehicle driver's seat.
Remove the ignition key from the ignition lock cylinder.
Close all of the vehicle's doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body and Chassis.
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open and then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If you do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
Repeat step 8 in order to program each additional transmitter.
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body and Chassis.
Validate that all the transmitters that were programmed operate properly. Refer to Keyless Entry System Operation .
Hope this helps, I found it online
-Scott
Feb 19, 2015 | 2004 Pontiac Grand Prix
Have a general lee transmittes.canhear myself talking but cant hear any response,changed mic,antan,coaix,still no change,need help
See if you can connect an external speaker and see if you get received audio. You might also see if you can connect directly to the audio output on the main board directly to see if there is detected audio.
Sep 29, 2014 | Radio Communications
Uniden uh049sx stuck on busy
Replace the ceramic filter on the circuit board with the part number CQ33-455D or similar
Aug 28, 2011 | Uniden Radio Communications
I have a Sanyo DP46841 TV and would like to hookup wireless speakers since i am hearing impaired. Can this be done and if so what are the best system to use? Jim
The Sennheiser Set 820S is a TV/music listening system specially designed for hearing aid wearers. With roughly a 100 foot range, Set 820S users can leave the room while still being able to listen to a TV program or music. Enhanced with radio frequency (RF) technology for a larger coverage area, users won't need to worry about missing a word of the program or song. The Set 820S consists of the 820 RF stereo transmitter and 820-S RF stereo bodypack receiver. The transmitter connects to a TV set or hi-fi system; the receiver can be clipped to clothing. The receiver can be coupled with an induction neckloop (sold separately) (hearing aid must have a t-coil), direct audio connection (to cochlear implants or BTE hearing aid) or Sennheiser headphones with a 3.5mm jack. Two year warranty. · Bodypack receiver · RF wireless transmission · Stereo or mono operation · Quick charge feature · High SPL (125dB) · Approximately 100 foot range · Maximum volume and bass response adjustable by hearing professional
http://www.mcssl.com/store/familyhearingcare/catalog/product/7f146beca0684d65a142df331ef59c00
wireless speakers are also available ........ but you may not hear 100% of sound............. click above shown link.... you will find many similar products ...... you can check thier price , features, etc & then you can finalise the one that suits you best ..............
Aug 09, 2011 | Sanyo Televison & Video
My Uniden UH049SX has the BUSY indicator on all
velohead says.....
Factory reset is to turn unit on, whilst pressing SCAN and MEM buttons.
Mine also has same problem, and factory reset did nothing.
Is this a common problem ?
May 08, 2010 | Radio Communications
How do you program the remotes for keyless entry with a 200 pontiac grand am?
No Tools Required
Important
Important
Oct 21, 2009 | 2000 Pontiac Grand Am GT
Can't program keyless entry remote.
Try this,
No Tools Required
Important
Sit in the vehicle driver's seat. (actually it’s much ezr from the front pass seat)
Important
Good luck and hope this helps.
Jun 23, 2009 | 1995 Cadillac DeVille
Esky 0404 would not work with usb
Disconnect from the internet. Then try turning off you anti virus software and try again. If it works you can change your exceptions in the antivirus software.
Jan 09, 2009 | E Sky Flight Simulator Training Kit
Uh049sx." BUSY" light on all the time. wont recieve
Contact a service center in your own country.
turn the squelch button down.
Oct 19, 2008 | Radio Communications
No response to radio check
Try this: find another CB radio and tune it into the same channel as the other one and talk on the one you have trouble with and if you hear yourself on the other CB, your radio is fine. But if no one can hear you, you might need to find a better antenna, I'd recommend Shakespear or Moonraker antennas. They're pricey, but worth the money.
However, if you still can't hear your voice on another radio, you may have either a Mic problem or a Transmitter problem. If so, use a different Mic and see if that solves the problem. If not, you may need to get another transmitter or new radio.
Best Regards,
Gavin93
Aug 05, 2008 | Radio Communications
Radio Communications Logo
287 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
