Question about Quinny Buzz Jogger
Front wheel wont roll on smooth floor !!
My quinny buzz is heard to control , wen i take it into a shop with a shiny/tiled floor the front wheel just draggs and wont roll it turns on its side and the prom wont move i have 2 drag it backwords hence the fact iv only used this pram like 4 times ...... please can u help do i need a new front wheel, 4got say aswell the front wheel doesnt seem 2 click down 2 stop the wheel from turning could this be part of the problem ? thanks katy holmes x
Hi
I have had this problem as well but what you need to do is take the front wheel off by pushing in the 2 black buttons. Then when you do this there is a hole near the bottom, what you need to do is turn the wheel until you can see the pin inside then use something thin to puch it in this will release the wheel. You need to clean the inside of this and then spray with silicon spray NOT WD40 as that will make it worse.
In the instructions it does tell you to make sure you keep them oiled but it does not tell you how to do it.
Once you have done this it will work like new again. I took mine on the beach and had to clean the sand out and i also think that from where we have had all this snow the grit has not helped either.
I hope this works for you as it has for me, i love my Quinny and would not change it for the world but i was starting to hate it before i done this
Soph
Posted on Mar 09, 2010
I have the same problem!i spoke to toysrus customer service today, and even though i bought it 9 months ago, they are going to let me return and issue a credit! although i love the design of this model, i'm going to have to go with another stroller because i'm sure it'll happen again. try to either find your receipt or if you bought it online, search your email for your order confirmation and give the store a call :-)
Posted on Feb 25, 2010
I have exactly the same problem ive found primark the worst shop ever to push it in it drives me potty. I purchashed a new front wheel and still have the same problem i would say if your guna get a new wheel go for the 4 wheel version
Posted on Aug 15, 2009
I have a quinny Buzz 3 and I find that the swivel wheel on the front locks in the transverse position and will not swivel at all when on shops smooth floors. This is when I need it most to work.. How do...
hi, this is a very common problem, you could try this first
http://www.youtube.com/watch?v=GUY6QO4w54Q
another option is to replace the front wheel unit (have you seen the new all terrain set )
http://www.kiddicare.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&catalogId=10751&langId=-1&productId=102143&source=froogle&cm_mmc=Froogle-_-Shopping%20Sites-_-CPC-_-Froogle
Nov 17, 2010 | Quinny Buzz Jogger
The front wheel on my quinny buzz 3 hardly moves and makes steering the pram very difficult. Especially on tiled floors, such as shopping centres. The wheel isn't locked, so it's on the swivel wheel...
The best thing to do is to remove the front wheel (depress the black buttons either side of the front axle and pull!) then completely clean the wheel assembly in warm water and a SMALL amount of gentle detergent, then dry completely, apply a small amount of vaseline or similar, then replace. This should help.
Sep 14, 2010 | Quinny Buzz Jogger
Quinny buzz 3 and front wheel
I would personally recommend the Buzz 4 front wheel as I beleive that this offers much more stability than a single front wheel. If this does not work out for you, you can always eBay it, it will sell within minutes!
Hope this helps.
Mar 23, 2010 | Quinny Buzz Jogger
Problem with the front wheel Quinny buzz 3
This does sound like you have got a build up of dirt within the wheel assembly unit. I would suggest that you remove the entire wheel (push the two black buttons either side of the axle and pull) then clean the entire wheel in warm water. Lubricate the moving parts with a thick lubricant (something like vaseline, not DW40 as this attracts dust) then pop it back on, that should sort it out.
If the wheel is still not working, then contact your retailier if still within warranty (two years chassis and one year fabrics). If this is out of warranty, contact www.quinny.com who will be able to sell you a replacement wheel assembly.
I hope this helps.
Oct 10, 2009 | Quinny BUZZ 3 Capri Stroller
I have lost one off my quinny buzz 3 pop on back WHEEL
Found this on the last page of user manual
Front wheel assembly
Rear wheels
Rainshield
Bug net
Shopping basket
Car seat adapters
• XL Seat Pad
To order parts call (800) 951-4113.
Include the model number and manufacture date (found on the bottom rail of stroller) and a brief description of the part.
Aug 20, 2009 | Baby Gear
Unable to fold and front wheel keeps sticking
Hi Kelly,
Over the years we have seen customers having trouble folding the Buzz. Mostly it's a combination of factors that make a Buzz a bit stiff.
Most important is that the main silver central tube must be clean and preferrably lightly lubricated. (Put some WD40 on with a rag.)
The second point of attention is the grey release knobs: Remove (blow out) any sand or debris and spray in some WD40. Especially the knob on the left that is slide-push needs this attention. (Left-right viewed in the driving direction.)
These grey knobs have to be pushed firmly to properly fold the chassis. (The left one is first-slide-then-push.) When it folds and gives a loud 'clack' you didn't push them in far enough. We know from experience that this sometimes remains difficult for some customers.
Later revisions of the Buzz have slightly larger buttons that are somewhat easier to operate.
Your front wheel probably needs some care. At the side of the black plastic front 'fork' that holds the wheel you will find a small hole. Rotate the front wheel until you see a small button come by. Push it with a pointed object. (A small screwdriver will do)
You can now remove the front wheel from the black front fork. Clean the internals and lubricate, preferrably with a teflon loaded grease or teflon spray. (Spray is less durable than grease)
This will take care of your steering problems.
Alternatively you can have a look at the Quinny Buzz All Terrain wheels. It's a sturdy drop-in replacement for the original wheel:
http://www.babycare.nl/quinny-buzz-all-terrain-voorwiel-p-1819.html
Please contact us through the contact form on our website if you need further assistance.
www.Babycare.nl
Erwin de Raad
Jun 23, 2009 | Quinny Buzz Jogger
Front wheels on quinny buzz are a nighmare....
http://www.babycare.nl/quinny-buzz-all-terrain-front-wheel-p-1819.html?language=en&name=Quinny%20Buzz%20All%20Terrain%20Front%20Wheel
Mar 26, 2009 | Quinny Buzz Three Wheel Stroller
Buzz rear wheels wont inflate anymore
I just ordered new tyres and inner tubes from my local pram shop. 8.50 for tyres each and 5.50 for inner tubes. Pram centre in Glasgow. Also ordered a new front wheel for 29.
Mar 11, 2009 | Quinny Buzz Three Wheel Stroller
Quinny Buzz front wheel.
Hi they are not very good on rough ground, you can buy all terrain front wheels on ebay.
Oct 06, 2008 | Quinny Buzz Jogger
Quinny buzz shopping basket
1. take off the front wheels by squeezing the two buttons on the aluminium tube just up from the wheels.
2. slide the metal clip up the groove in the tube.
3.use the two velcro straps around the tubes that support the rear wheels to hold up the rear of the basket.
4.re fit the front wheels and make sure the buttons snap into the holes in the tube
Aug 13, 2008 | Quinny Buzz Jogger
Quinny Buzz Jogger Logo
422 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Al Toledo
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
