Question about Goodman CLQ36AR49 Air Conditioner
Heat pump does not seem to be running but fan will not shut off - it runs all the time. Themosat is set on auto but fan will not shut off.
  • 700 Answers
If the fan is running all the time then yoiu have a sequencer thatt is bad on the air handler. you probebly need to contact a service company and set up a service call. Have then bring along a sequencer for the air handler soo that the tech has the parts on his trech.
Posted on Feb 22, 2009
I have a Honeywell thermostat and the fan runs continuously. Not sure if need to set on Auto fan and Auto Heat or what.
Hello Donna,
You are right. The Auto setting will allow the fan to shut off when the fan is no longer needed.
Jan 14, 2018 | Honeywell Heating & Cooling
I am new to a heat pump. The thermostat has an 'auto' setting and an 'on' setting. I am confused as to which one to use for heat. Can you help me?
n most heat pump thermostats you have two control switches and the temp setting. One control switch will say "Heat", "Off", "Cool" while the other says "On" and "Auto". The three position switch is for whether you are heating or cooling. The two position switch is for the fan control. "On" will make the fan run constantly whenever the three position switch is in HEAT or COOL mode. Some people use this to circulate air at all times. MOST people use the AUTO mode, where the fan is controlled by the circuitry and runs during the times of heating and cooling only.
Oct 16, 2015 | Heating & Cooling
Why heater fan will not come on?
Wish I knew how old your furnace is. Let me answer your question directly. In the heat mode the fan runs independently from the air conditioning fan relay. Its either brought on by time or temperature. An old furnace will use a fan and limit control that uses a coil to sense the heat exchanger temperature and turn the fan on or off. Newer furnaces use a timer on a circuit board. 20 years or newer Ill bet its a timer board. Follow the blower motor wires back to the component and ill bet that's the culprit. Hope it helps. Good luck.
Oct 12, 2014 | Heating & Cooling
Furnance running all the time never shuts off
Turn the thermostats fan position to Auto instead of ON. If it already is in Auto, then there is a fan relay stuck in the board.
Dec 13, 2013 | Goodman Manufacturing Goodman AEPF313716...
THE FAN WONT SHUT DOWN ON MY DUCTED HEATING. THE HEAT DOES BUT NOT THE FAN. IT SEEMS THAT THE ON/OFF BUTTON ON THE WALL UNIT IS NOT WORKING. THERE IS NO REMOTE CONTROL FOR IT.
Check the thermostat ... assure the "FAN" setting has not been set. FAN makes the fan run all the time. You want your switch to be set on "AUTO"
Thanks for your interest in FixYa.com
Aug 12, 2010 | Heating & Cooling
Fan running constantly in the house
Check t-stat and make sure fan is set to "Auto", that might be why fan is running all the time, or it could be a fan relay that is stuck closed. It sounds like you A/C is over charged or you have a bad high pressure switch, this was a common problem with this manufacture especially in the heat mode.
Apr 24, 2009 | Ruud Central System Air Conditioner
Blower won't shut down
Is the switch on the thermostat set to auto for the fan?
Apr 14, 2009 | Heating & Cooling
Ford galaxy over heating
need more info if it overheats in urban driving but not on hiway prb is in cooling fan electric or viscous?
Nov 24, 2007 | Baby Gear
Goodman CLQ36AR49 Air Conditioner Logo
112 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
