Question about HP Compaq 1720 (Carbon, Silver) 17" LCD Monitor
Best resolution ? with 60 mh or 75 mz - HP Compaq 1720 (Carbon, Silver) 17" LCD Monitor
  • 129 Answers
Maximum resolution for this monitor is 1280 x 1024 .
Rate this solution as fixya if the above answers your question !
thnx
AD
Posted on Feb 22, 2009
How can I adjust the height of the HP LP2465 24" LCD Monitor?
MOST OF THE TIME THEY WILL NOT ADJUST UP AND DOWN. LOOK FOR A SMALL LEVEL AT THE BOTTOM OF THE BASE OR JUST BEFORE THE BASE. I JUST GOOGLE IT AND FOUND PICTURE OF IT.
May 21, 2014 | HP LP2465 24" LCD Monitor
Two inductors 100mh and 75mh in parallel in series with a 5v power supply and a57.14mh. What is the frequency?
Isn't the frequency imposed by the voltage source?
The equivalent inductance is about 100 mH
100*75/(100 +75) +57.14 or about 100 mH.
You have a voltage source connected to an inductor with inductance equal to 100 mH. Then what? You need at least the peak current value, don't you?
Oct 07, 2013 | Texas Instruments TI-83 Plus Calculator
Va2431wm
I am sorry to say that, that mode of resolution is not compatible with this monitor, you must select from one of these modes;1920 x 1080 @ 60 Hz1680 x 1050 @ 60 Hz1600 x 1200 @ 60 Hz1440 x 900 @ 60, 75 Hz1360 x 768 @ 60 Hz1280 x 1024 @ 60, 75 Hz1280 x 960 @ 60, 75 Hz1024 x 768 @ 60, 70, 72, 75 Hz800 x 600 @ 56, 60, 72, 75 Hz640 x 480 @ 60, 75 Hz720 x 400 @ 70 Hz
Mar 23, 2012 | ViewSonic Va2431wm LCD Monitor
Whats the resolution setting for a L1715s monitor
The LG L1715s can support resolutions between 640 x 350 up to 1280 x 1024 @ 75Hz. The recommended resolution is 1280x1024 at 60Hz. The manual is available here: http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=L1715S&initialTab=warranty&targetPage=support-product-profile .
The preset modes are:
VGA: 640 x 350 @ 70 Hz, 720 x 400 @ 70 Hz, 640 x 480 @ 60 Hz
MAC: 832 x 624 @ 75 Hz, 1152 x 870 @ 75 Hz
VESA: 640 x 480 @ 75 Hz, 800 x 600 @ 60 Hz, 800 x 600 @ 75 Hz, 1024 x 768 @ 60 Hz, 1024 x 768 @ 75 Hz, 1152 x 900 @ 65 Hz, 1280 x 1024 @ 60 Hz, 1280 x 1024 @ 75 Hz
I hope this helps.
Feb 10, 2011 | Computers & Internet
Unable to get 1024 x 768 resolution on philips 105e
Hello, that resolution should be available but only at a refresh rate of 60hz as per the specs pasted below. Can you see this resolution setting on your graphics card? If not then perhaps you need to check you have the latest driver for your graphics card and just make sure that your graphics card does support that setting anyway.
Display
Diagonal Size 15" Viewable Size 14" Dot Pitch / Pixel Pitch 0.28 mm Max Resolution 1024 x 768 / 60 Hz Max Sync Rate (V x H) 120 Hz x 54 kHz Video Bandwidth 65 MHz Factory Preset Resolution Modes 1024 x 768 / 60 Hz
800 x 600 / 85 Hz
640 x 400 / 70 Hz
640 x 480 / 75 Hz
640 x 480 / 60 Hz
800 x 600 / 75 Hz
Regards,
nicam49
Dec 26, 2010 | Philips SoHo 105E 15" CRT Monitor
Recently I purchased Sanyo Eneloop NC-MQN04ES Charger. I need the user manual for this charger. How many hours does it takes to charge 4 aa and aaa Batteries. I charged it for more than 6 hrs. But the led...
This is from the user 's manual i just copy paste it
Specification: Voltage : AC 220V - AC 240V,
Input : 50/60 Hz 6W,
Output : DC 2.4V 220-280mA x2 (AA),
100-140mA x2 (AAA),
LED indicator : ON - charging OFF - Timer off (approx 16hours) Battrey/Charge Time Approximate Hours :
-Eneloop Ni-MH AA (typ 2000mAh) 10(h),
-Eneloop Ni-MH AAA (typ 800mAh) 8(h),
-Ni-MH AA (typ 2700mAh) 13(h),
-Ni-MH AA (typ 2500mAh) 12(h),
-Ni-MH AA (typ 2100mAh) 10(h),
-Ni-MH AA (typ 1700mAh) 8(h),
-Ni-MH AAA (typ 1000mAh) 10(h),
-Ni-MH AAA (typ 900mAh) 9(h),
-Dimension : 118 x 75 x 40 mm
Jul 03, 2010 | Vacuums
Video unsupported
1. Check if the graphics card and the game requirements match.
2. Check in your game configuration what frequency (Hz) you put. Most monitors can accept 60 through 75 Hz. If it's more than 75 or less than 60, change that.
3. Check if your screen resolution matches the game resolution. To check your current resolution, right click on Desktop, then Properties, then Settings and see the "### by #### pixels"
4. If it's not any of those, change your graphics card.
Sep 11, 2009 | Gateway GT5428 PC Desktop
SCREEN SAYS OUT OF RANGE
I assume that you are using a DVI to VGA connection since this TV dose not have a DVI connection.
Make sure that the resolution are set to the following supported resolution:
1280 x 1024 @ 60 Hz
1024 x 768 @ 60, 75 Hz
800 x 600 @ 60, 75 Hz
Or just make sure its set to 1366x768 @ 60Hz
May 13, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Pentax MZ-60 2x teleconverter lense
aturnbull1,
any good camera store or repair shop should have a 2X tele converter for MZ-60, new or used. i would try e-bay also.
Dec 09, 2008 | Pentax MZ-60 QD 35mm SLR Camera
Always says: Auto Image Adjust
These are the allowable resolutions and refresh frequencies for your monitor. 1280 x 1024 @ 60, 75 Hz 1024 x 768 @ 60, 70, 72, 75 Hz 800 x 600 @ 56, 60, 72, 75 Hz 640 x 480 @ 60, 75 Hz 720 x 400 @ 70 Hz 1280x720 is invalid but I see that you were having problems at 1024x768 which might mean the refresh timing was wrong. Make sure the monitor tab in the display properties (advanced) is correctly set with 'hide modes that this monitor cannot display' so that the display is locked to the valid frequencies and resolutions. If all else fails look at the game .ini configuration settings. You might be able to set a compatible mode there. Or run the game in a window.
Sep 24, 2007 | ViewSonic VA703B LCD Monitor
Open Questions:
TECHHELP 1 866 866 1752Norton Antivirus Support Phone Number? Call 1-866-866-17-52 is followed by great amount of people because this number is used for solving the issue of virus's problem . It works with the assistance of Nortan Antivirus support phone number and therefore the number is 1-866-866-17-52.Our expert will give advice to you how can you protect better and faster your pc's or Laptop and other devices.Our Team is very experts and experienced. Nortan antivirus offer technical support in a very price effective manner by means that of tollfree service at 1-866-866-17-52.Sometimes customer face the problem of pc or laptop hanging.you must tried to use that number to solve the problem of virus's or hanging problem.Our expert always available for solve the problem you just dial 1-866-86617-52 and your problem will solved in sort time.So use that number for any Antivirus problem.It provide the facility of shorter wait time and faster help.If your computer is infected please call 1-************.USA TollFree No:-1-************.Our customer Centre is all Always Opened in24*7.We are Nortan Antivirus Support USA. For Any Query Call US :-1-866-866-17-52 . Norton Antivirus Support Phone Number, Norton Antivirus Customer Service Phone Number, Norton Antivirus Tech Support Phone Number, Nortan Antivirus support Helpline Number, Nortan Customer support Telephone Number.Nortan Helpdesk number,Nortan Tech support Telephone number,Nortan Antivirus Tech Support Number,Nortan Internet Security Customer Number,Nortan Customer Service Technical Support Number.
Jul 26, 2017 | Norton Computers & Internet
See all HP Compaq 1720 (Carbon, Silver) 17" LCD Monitor Questions
HP Compaq 1720 (Carbon, Silver) 17" LCD Monitor Logo
95 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
