Question about Philips GoGear HDD1830 MP3 Player
I FILLED UP MEMORY AND NOW I CAN'T GET IT TO OPEN OR WORK
When i put music on the go gear I filled it up to where I can't open it up to play or operate or to delete some of the music. the usb recognizez it but nothing pops up for me to get inside on my pc
  • 8,596 Answers
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Mar 07, 2009
I couldn't play a song in my vodafone 803T... mp3 and mp4 file does not work... even 3gp files, but there are some 3gp file work in my phone... i dont know what to do...??? is there any file that can play...
5f1a8ee4-92ba-426c-8e3b-0b4e1c8722cd.jpgInsert your memory in your phone and start phone and open memory
then off your mobile and open your memory card for your phone and plug in memory your Computer and look folder private open this folder>Vodafone>Sound and ringtone and past all song this folder
Enjoy Music.....
Aug 04, 2010 | Nokia N70 Cellular Phone
How to save music in NDS lite???
remove yor memory card from the ds and put it into your computer. open the folder on the memory card for music and drag and drop your music onto the memory card. just know that before you drop your music into your ds that you have to convert it from mp3 format to AAC format using itunes or else they won't play on your ds..
Jul 26, 2010 | Nintendo DS Lite
I have a UTStarcom Shuttle. I am trying to play to play music
Put a microSD memory card (limit 4GB) in the phone. Take a few pictures and make a short video .Use the phone menu to transfer the pictures an video to the external memory card. Use the media player to watch your recorded video. Try to play music and you will get a no content found message. Now, turn off the phone, remove the memory card and place it into an adapter that will connect to a computer by usb port. Windows should recognize it as a removable drive. If you look at that drive in Explorer you will see 3 folders. Pictures are in my_pix. Videos are in my_flix. Transfer .mp3 files to the my_music folder. When you put the card back into the phone you can play the mp3 files with the media player. Yes, I did this and it works.
Feb 23, 2010 | UTStarcom Cell Phones
I just put music on my card but i dont know how to load it onto my phone. can someone help?
First you need to make sure that the music files that you put on the card are compatible with your phone. You have to tell the phone where to look for the music files. Access the menu on your phone, and look for "memory." You have some limited memory on your phone itself, but you want to access the memory card. You can also set your phone to "save to" the memory card as well for videos, etc., this way you won't fill up your phones memory, and it is easy to transfer you files between your phone and other devices, computer, etc. My phone for example will play only the files on my phone by default, until I set it to play files from the memory card. You need to learn more about your particular phone, not so much the memory card itself. Please rate appropriately and leave a response. I hope this helps and good luck.
Oct 23, 2009 | PNY 2GB microSD Memory Card
Lg ks360, cant get music playing off memory card
Connect USB lead, open "My Computer" access the memory card on "Removable disk (G)" - This will list the files in the "Music" folder. Open up my computer again & drag the files from the "Music" folder to the "Sounds" folder. When you then disconnect the USB the files will be in the "Sounds" section of the Media Album on the phone and can be played back. Hope this is of some use.
Jun 09, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Always shwoing update when i want to open music player
i had the same problem.
it's possibly because when you uploaded your files to your memory card, they weren't the right file type.
plug your memory card back into your computer, open the folder, right click on a file and go to properties.
if it isn't an mp3 type file, it will not play on most phones.
also, make sure you format the card before you put music on it.
BE CAREFUL. formatting the memory card will erase all of your data.
hope that helps :)
May 28, 2009 | Nokia 3110 Cellular Phone
Not able to play music from sd card on env2
HI,
what you need to do is put it in ur PC and if the option of open file location comes up use it, when u see what the file location is open another of the same file containing My_music, My_pics, Music, the file should be easy to open without the option by simply going to START then search and choose Removable disk E: , after having 2 open what u need to do is make sure ur music is in My_music now once done with that if there in Folers you need to take them out and have just the MP3 file in the My_music section when u have them all out of there folders simply delete the folders...keeping the MP3s of course.. now once you have nothing but every songs MP3 file in the My_music file u are set put it in your phone then it should say downloading or checking or doing somthing with the music for a minute till you can play them...and then you DONE....=) any questions my myspace is http://www.myspace.com/johnjg7000 have fun and enjoy took me 3 days to find a way for the phone to read this stuff haha...hope it works
Apr 01, 2009 | Verizon Communications enV2 Cellular Phone
LG shine KE970 MP3 player wont play music from memory card
yes you can, just put the mp3 file on folder "Sound" on the external memory, it will be automaticly put  in your playlist mp3 player.
Feb 23, 2009 | LG Shine KE970 Cellular Phone
Duo and music played from the memory card
open windows media player and look at bottom right of screen. open the menu and scroll down to library. open library and highlight storage card and you should be able to play music off your card then.
Oct 04, 2008 | Pantech Duo Smartphone
The music I put in my psp doesnt work
Make sure you have it in the "MUSIC"(all in caps) folder within the PSP folder of your Memory Stick.
Inside the Memory Stick's PSP's MUSIC folder, you should either have the song file itself(mp3 or wma) or no more than one folder.
I.E:
Memory Stick>PSP>MUSIC>Gwen Stefani>Don't Speak.mp3
or simply
Memory Stick>PSP>MUSIC>Don't Speak.mp3
Aug 08, 2008 | Sony PlayStation Portable (PSP) Console
Philips GoGear HDD1830 MP3 Player Logo
37 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
