Question about Lands Phones
Touchpad does not work
My 'down' button on the touchpad does not respond at all. however, when turning phone off and then on, the 'down' button flashes along with the top, left and right sensors. how do i fix this?
  • 79 Answers
Looks like you need to replace the corresponding button to the key that is not working, within the phone. take it to a service centre. in this it is not a user serviceable part.
Posted on Feb 22, 2009
Microwave runs for 5 seconds then shuts down displaying F9 HELP
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad
Oct 19, 2014 | LG Microwave Ovens
The setting push panel does not respond - can't turn it on
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Dishwashers
Regency problems
Enter your model number to see parts for your dishwasher.
Help me find my model number
Touchpad
Main Control Board
Jun 14, 2013 | Maytag Dishwashers
My leisure dwlt65 dishwasher keeps switching its self off when going till wash
see this causes and fix it. God bless you
Touchpad and Control Panel If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been have ruled out, the main control board might need to be replaced.
Sep 28, 2012 | Leisure DWLT65 Dishwasher
Touch pad malfunctioning
Inorder to fix the Touchpad issue, try the hard reset steps:
Sometimes it is necessary to do a hard reset to erase all of the information in the temporary memory and regain functionality of your PC when it stops responding. For example, doing a hard reset is helpful if your keyboard quits responding, you cannot get your PC to come out of hibernation or sleep mode, or if a software program causes the PC to freeze.
The hard reset will not delete saved files on the hard drive.
Hard Reset Procedure:
1. Disconnect the AC Adapter.
2. Remove the Battery pack.
3. Hold the Power button down for 2 minutes.
4. Reconnect the AC adapter and Battery.
5. Turn on the Notebook power.
Also make sure that touchpad button is On. It will be just above the touchpad area where you can see the white led which shows that touchpad is on. If the led is in orange, touchpad is off.
If these steps does not work, update the BIOS version from HP website .
In rare case if the issue still persists, you need to restore the notebook to factory settings using Recovery Manager or recovery discs.
Before performing recovery, you need to backup all your data to external hard drive because it will erase the data from the hard drive:
Vista F11 procedure:
1. Reboot the notebook PC.
2. Press F11 when the HP logo displays.
3. When the Recovery Manager appears, click Next .
4. When prompted to use the Microsoft System Restore program, select No and click Next .
5. When prompted to use the System Recovery, select Yes and click Next .
6. Select the option to perform the recovery without backing up files and click Next .
The recovery process will return your PC to the factory image.
or
On some notebooks, the TouchPad can be turned off by pressing an on/off button located near the TouchPad. If the notebook does not have such an on/off button, you can still disable the TouchPad in its settings control panel.
NOTE: You will need to use an external mouse or some other pointing device to control the cursor when the TouchPad is disabled.
To disable the TouchPad:
Click Start , enter mouse in the search field, and then select the Mouse control panel program from the search results.
On the Device Settings tab of the Mouse Properties panel, click the Disable button to turn off the TouchPad.
The TouchPad can be re-enabled when needed.
May 07, 2012 | HP Compaq 6735s Notebook
Touchpad not responding in netboook
There's a little button right above the touchpad. If the light on this button is orange, the touchpad is disabled. Press it again until the light is white again and your touchpad should work.
Nov 17, 2009 | Acer Aspire One Netbook 8.9" Notebook
Power button failure.
LG has a way of letting you know if your phone is wet.take your battery out and there will be a small dot circle.when you buy a phone the dot is a blue color.when the phone gets wet it turns pink or red.the best thing to do is when your phone falls into water put it in a bag of rice.the rice will draw the moisture out of the phone.let it sit in there over nite and try in the morning.
Nov 16, 2009 | LG KF750 Cellular Phone
Touchpad doesns't respond
I'm having the same problem. I can turn it on and off but nothing else works
Aug 31, 2008 | Motorola Mobility RAZR V3
Touchpad off and blank screen
I was having a similar problem, Except that my Touchpad WORKED, You just coudln't see it working. It made noises though.
Anyways, now I have to (instead of opening the screen to view it like usual) hit the unlock button (third down on the left side) and the screen appears.
We aren't having the same problem, but it's similar. Maybe it'll work?
Oct 20, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Lands Phones Logo
124 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
