Question about ASUS W3J PC Notebook
Asus w3j orange led battery light keeps flashing, and the lappy doesnt turn on? This occures while running both through the battery alone, and then with only the AC adapter connected. Do you guys have any ideas? Thanks in advance :)
  • razarlionz Feb 22, 2009
    Thank You very much mate :)
    I'll follow up on your suggestions, and if the problem still persists, I'll report back.
    Cheers :)
  • 129 Answers
This seems to be a issue with the AC adapter. Its not driving enough power to the laptop and neither charging the laptops battery. Try using a different adapter.
If the problem still exists, Then its to do with the internal power supply setup inside the laptop and probably you need to rip the laptop apart and check the power chipset.
Posted on Feb 22, 2009
Asus k52j flashing orange battery light
If you have access to a multi-meter check that the power brick is delivering the correct DC voltage at the plug that connects to the laptop. Remove the battery from the laptop and see if the computer runs.
The two common problems are either the power brick has failed in which case it can be replaced, (check ebay), or the battery has failed, same fix can be used.
Mar 04, 2014 | ASUS Netbook
Flashing led's on battery pack
Charles,
The battery turns on steadily or blinks to indicate battery charge status.
If the computer is connected to an electrical outlet, the light operates as follows:
  • Solid blue - The battery is charging.
  • Flashing blue - The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
  • Off - The battery is adequately charged, or the computer is turned off.
  • Flashing orange - The battery charge is low.
  • Solid orange - The battery charge is critically low
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 28, 2013 | Dell Inspiron 1420 Notebook
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Jan 04, 2013 | Toshiba Satellite U305-S2804 Laptop
My hp dv2988se not powering on just displays all the led light then the
search the reset button below your lappy use a saftey pin to press it.
your lappy will restart .
Dec 01, 2011 | HP Pavilion dv2988se Laptop
Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works...
Dell Inspiron 1525 PC Notebook Hi,\r\nAt my dell 1525 the battery... Answer Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell... (More) Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works well, the battery is charging, the AC adaptor is working properly. What is happening? Stefan
Feb 19, 2010 | Dell Inspiron 1525 Notebook
Problem with my ASUS W3J also with BIOS.
Sounds like your hard drive is toast. Replace your hard drive and try again. If it continues, it may be time to replace your laptop.
Also check your recovery disks for heavy or concentrate scratches.
Nov 25, 2009 | ASUS W3J PC Notebook
My pc partially doesnt work. when i press the
I would start with a new bios battery first.
There is absolutely no need to reformat a hard drive for a bios issue.
I would also hold off on flashing bios just yet although that could be a later option.
Just take note of the battery position IE positive "+" up or down.
Sep 03, 2009 | ASUS P4PE-X Motherboard
Battery light flashes 4times orange then 1green
We had the same problem. I figured out it was NOT the main battery, but the auxilary battery. The batter life WITH the auxiliary was 68% total, when I removed the 2nd battery the battery life shot back up to 98% AND the flashing orange / red lights were gone (both on the power source and off). I then replaced the auxiliary battery with a spar back up to make SURE that it was not a fluke and with the new backup battery firmly in place the lights still did not flash. Problem solved.
Jun 17, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Dell Latitude C610 battery claims its too hot to charge....
The charge light flashing orange-orange-orange-green....-orange-orange-orange-green.... usually means the battery has reached the end of its life and now it needs replacing.
There are three ways to test your battery:
1) If the battery has a button on the bottom of it and a row of 5 leds, then push AND HOLD the button for 5 seconds. The LEDs should all turn OFF, then turn back on showing a pattern. If all five LEDs turn on, the battery is dead.
2) Open the Dell Quickset application (doubleclick it in system tray), go to Battery Meter, go to the battery health tab, and pick your battery. It should tell you there if the battery is healthy or not.
3) Reboot your computer and go into the bios. Pick the Battery tab in the bios. It will list the battery health there.
Jan 20, 2008 | Computers & Internet
ASUS W3J PC Notebook Logo
2,805 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
