Question about Lenovo 3000 Y410 Notebook
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously for 1 whole day.even afterwards when iam starting the system its making the same sound.please slove the problem
  • 107 Answers
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Posted on Feb 22, 2009
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
Emachines 5805
Sounds like a bad motherboard. It's getting power and turning on the fans and everything, except booting it up. Yeah, sure sounds like a bad MB. How old is the pc? You have to be careful with Emachines. They are built cheap and break often.
Jan 02, 2014 | Dell Computers & Internet
Forgot the combination to the lock. Is there a way to retrieve the combination or return it to its factory default combination 1, 2, 3, 4, 5
The instructions below are copied from the programming instructions (page 11):
ERASE ALL PROGRAMMING
(The "out of box" factory default will be restored)
1. At the back of the lock, remove the screw at the bottom of
the lock housing and remove the cover.
2. Take out the battery pack and remove battery power by disconnecting
the battery pack.
3. Plug in the (provided) male shunt connector into the yellow
wire female connector.
4. With shunt connector connected, re-connect the battery
pack. The lock will immediately sound 3 short beeps (if
these 3 beeps are not heard, then restart at step 2).
5. The lock will then sound more slow beeps, 1 beep for every
second it takes to clear the memory.
6. After a few more seconds, the LED will slowly alternate between
flashing red and green--disconnect the yellow wire
shunt connector.
7. The LED will continue to slowly flash green and red for 25
seconds. To enroll Function Cards, proceed immediately
as follows:
• With the lock LED slowly alternating between flashing
red and green, present the Function Card #1
to the lock. The lock will sound 5 slow beeps.
• The lock LED will flash green rapidly. The lock is
ready to enroll the Function Cards.
• Re-present Function Card #1 to the lock. The
lock LED will flash green then red, with two beeps
(indicating the card was enrolled successfully).
• Present Function Card #2 to the lock. Again, the
lock LED will flash green then red, with two beeps.
• Continue to present, in order, Function Cards 3-
9. Each time a new Function Card is presented, the
After the 9th Function card is presented, the lock LED will flash
green twice, sound two beeps, and will then remain silent,
ready for use. Note: If the lock continues to beep after presenting
the 9th Function Card, check to verify that the yellow
wire shunt is disconnected.
Note: If you only wish to use the first 3 Function Cards, simply
allow the lock to "time out" after 30 seconds.
Here is the link to the complete instructions, in PDF form. You will need Adobe Acrobat or equivalent to view them:
http://napcosecurity.com/download/PL3000_WI1280A.04_PROG.pdf
Good luck-and please provide feedback if this helps!
Nov 04, 2011 | Trilogy ALARM LOCK PL3000 Series T3 Prox...
My IBM T41 make beep sound and turns off itself. What is happening?
You can try the steps below.
Try removing the battery and plugin the charger and try turning on.
Do you see any thing displayed on your screen when you switch on?
Please mention the beep pattern, 2 beeps or continuous beep.
Hope this helps. Good Luck
~SmokinJoe~
Aug 24, 2011 | IBM ThinkPad T41 Notebook
Hello,my laptop HPCOMPAQ 6735S boots with a series of continuous beeps.Plz help me to solve this problem.In touch.
hi
1. make sure that any key is stick on the keyboard,
2. you will have to remove all key, one by one until the beep sound stop.
if the problem continue then, you have to open the case and disconnect the keyboard cable from
the laptop mainboard, close the case. Then use a mini or normal size USB keyboard
hope this helped you to solve the problem
May 28, 2011 | Computers & Internet
IBM Wheelwriter 10 Series II beeps
either the carriage home position sensor flag is broken or the daisy wheel can't find home. try removing daisy wheel and re-installit. turn unit on and see if daisy wheel spins if it does then the carriage home position sensor has a problem.
Nov 13, 2009 | Lexmark Wheelwriter 10 Series II...
Drivers for Lenovo Y410 for Windows 7
i have install windows7 in my y410 laptop and the sound driver is not working in it.it shows an error massage while i am trying to install the driver.
Nov 12, 2009 | Lenovo 3000 Y410 Laptop
Dryer will not heat up
remove the plastic tab infront of the machine
start you dryer. look inside the hole to see if the igniter glows.
takes 20-30 secnds.
if it glows then move to the back side of the dryer
remove the screws an check the thermal fuse, for continuity is your tester has the beep sound wich is easier to use for newbies, try it no beep sound, no good.
but if it checks ok then you probaly have bad coils
also since you are looking onthe back make sure that the vent is not restricted, a restricted vent can cause blow back an shut the dryer off if the vent is not clearly open.
good luck!
May 25, 2009 | Kenmore 73952 Gas Dryer
Lenovo DVD writer Creates sound
What kind of noise you hear?
Rising spinning noise is normal. When palying movie or music it gets to some level and continue with the same noise.
If it was not case before, then check the CD holder of your device for some dirt that might make your CDs not to be inserted proper.
Regards.
Mar 28, 2009 | Lenovo 3000 Y410 Notebook
Lenovo 3000 Y410 Notebook Logo
1,262 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
