Question about Sony Playstation 3 (PS3) Console
Turns on, but that's about it.
Yep. Already had this problem in the past, but I'm hoping this isn't as bad as it was back then.
Basically, I turn on my Ps3, and for a few seconds everything seems ok...the orchestra-like music goes on (the theme that lets you know that the Ps3 is on), and I see the usual background (the colored one, with lines that look like whisps of smoke moving delicately across the screen).
However, nothing else happens. Meaning, no programs, no games, no NOTHING. There's simply nothing THERE.
The only thing I still seem able to do is reset it by keeping the on-button pressed down for about 11 seconds or so, but that's it.
PLEASE help me out here.
  • 2 more comments
  • ozzy_benny Feb 22, 2009
    i have the exact same problem with my ps3! i turn it on and all i see is the background theme but nothing else, no icons or nothing! can someone please fix it??
  • daz150193 Feb 22, 2009
    same its lame
  • dumondbatman Feb 23, 2009
    Uhm...sorry, could you specify under exactly which of the categories you've listed on your site is the one we're looking for?
    This is MORE than simply "not reading discs", for example. There's just no freaking MENU when you turn the thing on...but it IS on, and with a green light to boot. It even shows a blue light when you put a disc in (but of course it doesn't read it).
    I've also yet to see this "yellow light of death", so it doesn't fall under THAT category.
    I'm sorry if it seems like we need to be taken each and every step of the way here, but we just want to be SURE of what we're doing.
    Thank you very, very much indeed for helping us out so far. Please, if you can, just point us in the right direction.
    Oh, wow. Ok, read what your guide says there, and it DOES explain things nicely.
    Convincing one of my friends to actually swap hard drives with me is going to be almost impossibly difficult, seeing as they're pretty touchy about their game consoles (and now I know exactly WHY), least I've got a shot, besides having to wait for weeks on end for some Sony store to just give me a new one thanks to the one-year guarantee.
    Thanks a lot for all the help, man :D
  • 2,653 Answers
I've got some answers.
Check out my common problem and easy repair guide here:
Please feel free to email me any other questions and don't forget to rate!
Posted on Feb 23, 2009
  • RescueTechLA
    RescueTechLA Feb 23, 2009
    Take a look at my guide. Your problem is the 3rd one. You just need to temporarily swap your hard drive into another PS3. My guide explains everything in detail. Let me know if you need anymore help.
  • RescueTechLA
    Your friend has absolutely nothing to worry about. It won't change
    anything on his PS3. We're just using the PS3 as a quick and easy
    formatting tool. You could always hook it up to a computer but you'll
    need a special usb dongle.
    Best of luck!
Asus k43sm doesn't boot after application of thermal paste
If you put thermal paste on the processor, you need to recheck the processor to be sure that it is seated right, no pins are bent and that the ZIF socket is put back in locked position. If this was not the processor that you put the paste on, then it might not be electrically neutral and you have shorted it out with the wrong paste.
Apr 08, 2014 | ASUS Bios Chip:K43br, K43sa, K43sd, K43sm,...
Overheating problem, what is the most probable cause?
You need to stop using it immediately before you
cause some damage or more than you may already have
That is just common sense. It should not overheat or
be any different than it was in the past without problem
The car has to be checked over/diagnosed,tested,etc for
various issues to resolve
Borrow or Rent a car until resolved
No way to guess at the problem
You should have some type of codes avail even
if the check light isn't on,you need professional help
to get a start on resolving
The timing belt maybe worn & jumped or the head gasket
Over heating isn't usually a cheap repair unless the thermostat
sticks partially closed
The RPM moves around the car is 11 years old,so it may just
need a though going over
Timing Belt,O2 Sensors,Exhaust Converter,Spark Plugs
and such
If you depend on a repair shop to do things & don't
have the knowledge to request work done throughout
the year,then you run into a lack of proactive preventative
maintenance situation. Most things are simple looking
back, once resolved
Sep 06, 2012 | 2002 Chevrolet Prizm
It turns on only when I remove and insert the batteries. Now appears Line 1111 Emulator. Does this calc have salvation?
That sounds pretty bad.... you can try to take out all batteries, including the back up, leave it sit for a minute or so. If that doesn't fix your problem you can try calling TI-cares (800-842-2737), they may be able to help. I hope it isn't lost
Aug 02, 2011 | Texas Instruments TI-89 Calculator
I have a Coby 42" tv that is a year old that turns
Check your electrical outlet. We had same issue with a different brand TV and the electrical outlet was the issue. Hope this helps.
Jan 11, 2011 | Coby TF-TV4209 42 in. HDTV LCD Television
It doesn't boot up right.
Dear Friend,Make sure the VGA cable is properly connected(also ensure Driver Properly Re-installed).Overly green color means the Red gun is turning off. This could be a cable issue or a component failing within the monitor. You can try and move the cable around and see if it improves.OR It might be with bad picture tube, but it's most likely a bad solder connection. It may probably turns out that the board connector pins are poorly soldered to the printed circuit board. As the unit warms up, stuff expands and the connection "heals" temporarily.
Hope this make you a Conclusion.... Thanks for Contacting FixYa
May 13, 2010 | Microsoft Windows XP Home Edition
When i turn my tv on the screen flashes digital then turns off
Basically, the TV is trying to power up the screen. If it fail to do so, the TV will automatically turn itself off to protect other part from being damaged inside. The problem is going to be the Backlight Inverter Board. It's the circuit board that supplies power to the screen. You can usually find a replacement board at a good price at
Aug 20, 2009 | Sylvania LC370SL8 37 in. LCD Television
My MP3 play won't stay on.
Ensure the key lock is not activated by sliding
"Power on/off ( )/Hold" towards the center
position. If your player isn’t already on, turn it on by
sliding "Power on/off ( )/Hold" to the left
and holding until the player turns on.
You can also try resetting the player by removing/reinserting (or changing) the battery.
-Tha Mp3 Doctor
Dec 09, 2008 | RCA TH1101 MP3 Player
Mobile phone enquiry
yap there is hope first clean up your battery connection the two tip connecting to the cell phone if still the same replace new battery it maybe need a new one!!!
Mar 25, 2008 | LG KG800 Cellular Phone
CompaQ DL380 will not boot
turned out to be a bad processor. put in a different one and it booted right up.
Oct 16, 2007 | Compaq ProLiant DL380 Server
F717 LCD Display Problem
Yep, sounds like a bad connection on the display's internal cable. Need to check and see if the Electronic View Finder also shows the lines. If it does, then it may be a sensor problem, instead. If not, then the display has a bad connection or has gone bad itself. In either case, it's not a trivial issue.
Sep 12, 2005 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Playstation 3 (PS3) Console Logo
120 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
