Question about Sony God of War 2
I cant pass a gate that it has two bottoms and one dead man
There is a gate with a hole in the middle that moves up and down.It has two bottoms.The one is in front of the gate.The other one is behind of some bars.Some of them are high and some small...
    Problem Solver:
  • 10 Answers
On the right take the dead man drop him in the water right beside were u pick him up at and run to the other side and wait for him to float around it will take around 10 seconds then pick him up and drop him on the pressure plate. then run to the middle jump on the second plate then it will take about 5 seconds for the gate to shut and that is plenty of time
Posted on Mar 01, 2009
How do I fix speedometer that is stuck below zero?
dealer might be able to fix with the computer diagnostic tool. If there is a push button to reset odometer you can take a small wire and try and feed through the hole and raise needle above the pin. removing the instrument cluster cover is a pretty big task, if you cant find a place to insert a wire, only bypass I can suggest is drilling a tiny hole in the instrument cluster cover off to the side or top wherever the hole is least bothersome to you and then use a wire to raise above pin, after put a little clear silicone or a piece of tape over the hole to prevent dust building up inside the cluster
Oct 17, 2015 | 2001 Honda Accord 3.0 EX
If my kx 125 has no compression when I try to kick start it but it does have fire what do I need to do
If no compression, then assuming the piston is moving up and down the pressure is either passing back past the piston (could be the rings or a hole in the piston) or escaping through the head (head gasket, spark plug hole, hole in head). First check the piston is in fact moving as it should. If it isn't moving you need to find out why (bottom end problem?). Can't see you getting away without stripping the engine to fix problem.
Aug 13, 2015 | Motorcycles
How to set top dead center on 98 grand am 2.4liter
Remove the number one spark plug. Put a gauge in the hole. Top dead center is on the compression stroke when the piston reaches the top of the stroke. When you see the gauge begin to move, remove it and put a straight piece of wire in the hole. Turn the crankshaft clockwise by hand/wrench till the wire comes up and then starts to go down. When it goes down, you just passed TDC. Back it up a bit until you are comfortable with it being at TDC.
Nov 15, 2014 | 1998 Pontiac Grand Am
Mtd yard machines
if it has the briggs and stratton engine this is prettry straight forward pass new cable (anchor end) thru control console and seat it with a "click" then locate the area between the gas tank and the engine block to see about finding slide cam that other end of cable connects too it has three holes drilled thru it locate the middle hole and holding new cable at a 90 degree angle pass end thru hole push in till you reach bend in cable now move cable down to horizontal posisition now place spiral covering under screw clamp at bottom of bracket on gas tank and tighten with wrench (right angle) this point might need some adjustement after starting to achive choke and full throttle but thats about it
Apr 27, 2014 | Garden
No display problem, vga's out to external, then after 2nd reboot, internal display works, but with errors
If you have already replaced the screen...
Common problem when replacing equipment on laptops is that the "cable" goes into a flat housing that requires you to lift a little white "gate" then insert the cable and put the "gate" back down. Problems usually occur when snapping the "gate" back down. Pull the cable back out and be sure to lift the gate insert the cable and then put the "gate" back down. Once done give it a light tug and it should hold very firm and not move at all
Nov 20, 2013 | Dell XPS M1530 Laptop
Jeep compass transmission problem
state the symptom , the FSM lists about 100.
and year,
but> ? (simple?)
slips? aka: flare or false neutrals. (doom)
fails to shift up or down automatically.?
car wont move.?
noise.?
passing gear dead.?
wont down shift on hills.?
cant shift out of park.?
stuck in 1 gear, name it?
Oct 23, 2013 | Jeep Cars & Trucks
The gate stays down when the power to the train is on
The breaks should be on one of the outside tracks along with a wire to the gate and the ground wire from the transformer is attached to the other outside track. Power wire is attached to the center track and the power terminal on the crossing gate. When the train passes the break the metal wheels connect the ground rail to the rail with the break that is wired to the gate. This completes the circuit and the gate goes down. Once the train passes the other break the connection is lost and the gate goes up.
Dec 04, 2011 | Lionel Auto Crossing Gate
This is for a friend and older man in his middle 80's. His problem is with his mouse. Once he opens up his computer the mouse arrow appears but he doesn't seem to be able to move it. Do you have a quick...
This sounds like the mouse signal simply isn't reaching the computer.
First step is make sure it is firmly plugged in (and to the correct hole)
Also might find that if it is a USB mouse then plugging it into a different USB port may help.
Jul 12, 2010 | Dell Computers & Internet
Need to replace back gate and trying no to cut
You will have to get into the rear gate and disconect all wiring one by one and pass them threw the hole where the wires enter the gate.Unfortunetly this may be the only way.
May 09, 2010 | 1998 Ford Expedition
I cant move driver or pass seat fuse is good it
you neeed to tkae the seat motor off and you can manualy turn the cable with a pair of plyiers
Feb 12, 2010 | Chevrolet Silverado 1500 Cars & Trucks
Sony God of War 2 Logo
417 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
