Question about ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card
What is a CHA_ fan slot ?. It is in front of my pci slot
What is a cha_ fan slot is it for a graphic card cooling if yes because i need urgent graphic card cooling
    Scholar:
  • 134 Answers
CHA_ fan slot is Chassis fan slot (case fan) you can use it for anything you'd like really, it it recommended to have a fan or 2 sucking the hot air out of the case and that connector would be perfect for such fan.
Alex
www.CAS411.com
Posted on Feb 22, 2009
Why does new memory card displays CHA?
The "CHA" means the camera cannot read the card here are a couple of reasons why this may occur. The most probable is that the card didn't seat properly when you put it in so try reseating it.
CHA can also mean that the camera has detected an invalid partition type. Reformatting the card may allow it to be used.
Jul 25, 2014 | Nikon D Cameras
Compatible video card
Any PCI-E video card will work.
Since this is an AMD motherboard,
there is not the Intel "Sandy Bridge" problem,
where the video card uses up all of the PCI-E lanes.
(A Sand Bridge CPU has only 16 PCI-E lanes)
Feb 17, 2014 | AMD GIGABYTE GA-K8N51GMF-9 NVIDIA GeForce...
What does CHA mean
Nikon says this about CHA:
When a Memory card is inserted into a D-SLR camera, the camera checks the card for compatibility and usability. There are three possible results of the test:
1) Camera detects valid Memory card, displays number of remaining images in top LCD
2) Camera displays "FOR" in top control panel LCD. The camera has detected a valid disk partition map, but was unable to read the first sector of the Memory Card. Formatting the memory Card using the cameras format option, should resolve this condition and allow the Memory card to be used.
3) Camera displays "CHA" in top LCD. The camera has detected an invalid partition type or is not working properly. Reformatting the memory card may allow it to be used. If an approved memory card causes the camera to display the "CHA" indicator contact the memory cards manufacturer for assistance.
(Nikon's list of "approved" memory cards can be found here.)
Please note that the default disk format used in Windows XP is FAT32 and if a card is formatted with this setting on an XP system, a D1 series camera will report "CHA". Reformat the card as "FAT" to use in the D1 series camera.
When the CHA error is shown, typically the camera will freeze and require that the battery be removed from the camera before it can take another picture. After that picture has been taken, the camera freezes up again for many owners.
Some owners have success removing and either re-seating or inserting a new memory card in the camera.
Some owners have success clearing the error by removing the lens and then reinstalling.
The key to these "fixes" is that they don't all work for everyone. You might need to return the camera to Nikon for repair. You can arrange for Nikon service here.
I hope this helps and good luck. Please rate this reply
. Thank you.
Apr 06, 2011 | Nikon D90 Digital Camera with 18-105mm...
After taking a few pictures I get a message that says CHA. What does that mean? I take my card out and reinsert it then it works for a while longer..
Answer fdound in owners manual: CHA=This card cannot be used. Try deleting files, try formatting card in camera, not pc) try different card. remove card, press hardware reset button on bottom of camera and reinsert card then try again.
Dec 04, 2010 | Nikon D70s Digital Camera
GE WDSR2120J wash cycle sound
It's possible that the tub suspension system is out of position. Open the cabinet top (use a thin putty knife in each front corner to release a spring clip) and watch the mechanism while washing. Try shaking the assembly to see if you can spot something rubbing. Hope this helps!
May 23, 2010 | General Electric WDSR2120J Top Load Washer
CHA?
I found this answer on the Nikon web site.
3) Camera displays “CHA” in top LCD. The camera has detected an invalid partition type or is not working properly. Reformatting the memory card may allow it to be used. If an approved memory card causes the camera to display the "CHA" indicator contact the memory cards manufacturer for assistance.
Jul 11, 2009 | Nikon D70s Body Only Digital Camera
NIKON D100 LCD DISPLAY FLASHING CHA ERROR WITH ANY CF 1 GIG
I had the same problem and thought I had looked closely at the pins in CF slot but after finally taking it to a repair shop, the tech showed me a bent pin. It really wasn't that apparent first time around. He told me its a common problem as long as they use the CF cards. I had the pins replaced and my D100 is working great. Best of luck.
Mar 21, 2009 | Nikon D100 Digital Camera
What is a CHA_ fan slot ?. It is on my motherboard in front of my PCI slot
it is for a chassis fan (case fan) use it to **** hot air out of your case.
Alex
www.CAS411.com
Feb 22, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Graphics Card Problem
im sure that is AGP, because we have the same video card on my other computer. your PCI slot is for sound cards, link modem, etc.. whenever your playing games make sure that you put the video option in to medium or low because that starts the heat of your video card when you use it into the limit. Try to cool the video card if its happening the heat again by using a fan and aim it to the video cards.
Others are overclocking their video cards to push the capability of the video card over the limit. their using a cooling fan or a tube like to maintain the temperature of their video cards. hope that helps
CHARCOIS
Jul 26, 2008 | Graphics BV200 BizView 128MB (128 MB) PCI...
ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card Logo
261 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
