Question about Apple iMac 24" Desktop
My macbook wont recognize my hp camera, i installed the software that came with it but it still wont even recognize that its even connected.
  • Anonymous Mar 30, 2009
    HP digital camera, iMac 20". iPhoto does not know there's a camer plugged in. The camera works fine on another Mac.
  • 3 Answers
I have had this problem with my HP Photosmart M415 and my Sony digital video camera ever since installing the latest Apple X 10.5. I solved the HP camera problem by taking the memory stick out and putting it into a SanDisk reader and plugging that into the USB. Worked like a charm. Still can't get the Mac to recognize the video camera. Seems to be an Apple problem.
Posted on Jul 01, 2009
  • 55 Answers
Your camera should work fine with the built in iPhoto software, simply launch the program and connect your camera, you should be able to download your pictures immediately.
Posted on Feb 22, 2009
Why my camera tell me "impossible connection" when I try to put my photos on my Mac? And what is the software which is installed when I read the CD?
The Nikon download software is called Nikon Transfer 2. I would remove the SD card from your camera and slide it into the SD slot on your Mac. If you have an iMac, the slot is located just below the CDROM slot on the right side. Do not do this by feel. Look as you insert the card because if you insert it in the CDROM slot, you may not be able to extract it. If you have a MacBook or MacBook Pro, check the manual for the location. When the computer recognizes your SD card, it will either open Nikon Transfer 2 or a folder will appear on your desk top. If Nikon Transfer does not open, just copy your pictures from the SD card folder to a folder on your Mac.
Jun 16, 2014 | Nikon COOLPIX S9500 Digital Camera Black
Macbook pro doesnt recognize my canon vixia hv30
Try a different cable, the one you're using may have got damaged.
Check the firewire driver is installed and running on the Mac.
If the camera came with software, try re-installing it.
Good luck.
Dec 05, 2012 | Canon VIXIA HV30 DV Camcorder
Computer does not recognize the camera. I am
The HP Image Zone or HP Photosmart software is not installed on the computer. Install the HP Image Zone or HP Photosmart Software, or see Using Your Camera without Installing the HP camera software in your camera User's Manual.The computer is configured such that it cannot recognize the camera as a digital camera using the Picture Transfer Protocol (PTP) standard. Set the USB configuration in the Setup menu on the camera to Disk Drive mode.
Jun 30, 2010 | Canon PowerShot SD950 IS Digital Camera
Canon Powershot S2 IS is not recognized on my iMac
Simple fix...use a separate card reader to download to a folder you create on your desktop. Once there, you can move them to iphoto.
Jan 05, 2010 | Canon PowerShot SD870 IS Digital Camera
I have a macbook and i connect the usb cable to upload my photos, but the usb is not recognized do i need to download any software. Its says that mac autmatically recognized the camara
the Mac normally recognizes the camera and launches iPhoto.
Try launching iPhoto, then plug in the usb cable. Make sure the connections are tight on the camera end of the cable.
Apr 22, 2009 | Fuji Finepix Z20fd Digital Camera
My Mac does not recognize my Canon HV 30 DV when i connect the FireWire.
I've been around the block with this for days, including a fresh installation of the software on my MacBook Pro. Sigh.
Here's what seemed to work:
1) Reset Vixia HV30 (tiny reset button behind the battery). Did not change any settings on the camera after that.
2) Installed Canon's software that dropped some canon-related files in Library/Quicktime folder.
3) Opened new iMovie 6.0.3 and Final Cut Express HD 3.5.1 projects (a) FCE (using Easy Setup in FCE) to Apple Intermediate Codec 1080i60 (b) iMovie 'HDV 1080i'.
4) Connected 4-pin --> 6-pin firewire cable out of the camera to a bus-powered external drive and from the drive, firewire 800 --> firewire 800 --> MacBook Pro 10.5.8.
This was a last-ditch, Hail Mary effort. It worked, and the camera showed up in the System Profiler firewire window, too, whereas it had not before all of the above. Still does not show up when hooked directly from the camera to the FW 800 input, but at least I can capture now.
Oct 18, 2008 | Canon VIXIA HV30 DV Camcorder
Connection between camera and computer
What operating system are you using? Is you camera connected via USB? Have you tried using another USB port? Did you make sure to install the software before plugging in your camera?
Generally if you are running Windows 98, you will need to reboot after installing the software to even have a chance of the camera being recognized correctly.
If you are running Windows 2000, XP or Vista, the camera should be recognized and a driver installed or searched for from the CD software you installed before plugging in the camera.
Sometimes if you plug in the camera first without installing the software, the PC finds a new device with no driver. You can see this by going to Control Panel -> System -> Hardware -> Device Manager and you should see and exclamation on a device in the list. You need to remove this item and reboot your PC.
Now install the software first and when the install is done, then plug in your camera. Generally this works out pretty well.
Apr 29, 2008 | Canon PowerShot A80 Digital Camera
Not recognizing my camera
Check your Mac OS X version number then go to the website below to download appropriate updater for your finepix viewer program.
Mar 31, 2008 | Fuji FinePix A345 Digital Camera
Apple iMac 24" Desktop Logo
335 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
MarkMAlford
MarkMAlford
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
