Question about Samsung J700 Cellular Phone
Formatting code my bluetooth device stopped working and i can't get it to start working again, so i wan't to format the phone.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Samsung Expert
  • 131 Answers
I think you mean hard reset code: *2767*3855#
Enter this code WITHOUT simcard inside. Note that this will delete ALL user data.
Best regards,
Posted on Feb 24, 2009
Nokia x2 01
You can format your Nokia X2-01 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YES
IMPORTANT!
Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings.
Apr 21, 2014 | Nokia X2-01 RED,BLUETOOTH,FM,QWERTY...
I forget the code to format of 5530 xpress music.Then I take it to nokia care centre. they told me that its hardware is not supporting they cannot able to find the code., so they have to send it to delhi...
*#7780# - This code restores the original factory settings without affecting any of your files.It is also called soft reset.
*#7370# - This code will completely format your phone deleting all your files.It will take your software to the same state, as you first received your phone.Use this code only if something wrong happens with your phone's software like virus attack.It is also called hard reset.
*#2820# - This code tells your device's bluetooth ID.It can be used for manually adding bluetooth devices.
*#62209526# - Shows MAC address of the WLAN adapter.This will be useful while connecting to internet through your phone's Wifi connection.
*#92702689# - Life Timer - Shows total call minutes since very first call.
Sep 17, 2010 | Nokia 5530 XpressMusic Smartphone
My bluetooth dosent work in my nokia 6600
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
But if it doesn't pair after you've tried the above, that means the blue tooth is corrupted and will need to be flashed to restore bluetooth back.
FORMATTING PHONE
Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone.
Read and learn more about flashing and how to flash a phone on this link.
unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Take care.
Jun 30, 2010 | Nokia 6600
My phone is sending an unknown message to another phones.how can i stop this ?my phones bluetooth is in off possition i have nokia 6600 my phone sending unknown files to other devices if my bluetooth in...
by pressing Calling key and 3 and * and switch it on ur battery must be charged it will show formatting for 5 minutes and it is done. dont remember to vote my solution as fixya
Jun 03, 2009 | Nokia 6600
Sending bluetooth message
ur phone or mem card contain virus.. the easiest way to recover this is first put ur mem card in card reader and format it seperatly. then format ur phone seperately. there are two ways of 6600 formating !. use the coad (*#7370#) if u know ur security code. 2. if u forgot ur cade then switch off ur phone press #, 3, and dial call button at the same time and holding these buttons press switch on button n hold it. note::: hold these four buttons uptil formating doesnt start.
then insert ur formated memory card in the phone (100% working) i tried it.
WARNING format will cause deletion of ur cont nos , messages , images, softwares, videos, and all other data.
May 27, 2009 | Nokia 6600
HOW TO FORMAT MY NOKIA 5200 WITH ANY SIMPLE CODE
Connect the phone to the computer using a USB cable or through bluetooth(Your PC should have a blue tooth device for this or you should buy a bluetooth dongle). Then your phone and multimedia card will appear as seperated drives. Right-click which one of those you want to format and then choose the filesystem type. I recommend FAT32 as it is more stable. Then just press format and you are done.
Let me know if you need more help!
Sai.
Mar 15, 2009 | Nokia 7610
Bluetooth
Back up first files on your memory card on your computer. then format the memory card on the pc. Then put back the formatted memory card and format it again on the phone. Take out your memory card then put it back again on your pc to copy your previous files. This should work.
Memory cards need also formatting same as HDD's
Hope this helps...
Jul 24, 2008 | Nokia 6131 Cellular Phone
Nokia 6600 Bluetooth, gallery problem.
My nokia 6600 gallery does not load. It shows "opening" and keeps showing the opening message and hangs. The bluetooth. First it said Unable to connect , when i click pair to device it says "system Error". and Now when i click bluetooth it doesnt load options. Other than that the speed of my phone is very slow.
if u have facing this prob. then switch off the phone and then switch on the phone do this procudure 3 times
Dec 07, 2007 | Nokia 6600
My Nokia N72 problem
u need to do restore factory settings....after that scan ur fone with some antivirus software...
Oct 15, 2007 | Nokia N72 Cellular Phone
Samsung J700 Cellular Phone Logo
271 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
