Question about Averatec AV5500-EA1 Notebook (AVERTECAV5500) PC Notebook
Hi, I have an Averatec av5500 when I turn it on I can hear the fan and harddrive kick in and the cd drive reads but I have no picture. Have tried resetting bios and have changed ram cards but no joy. Please help
Where can I find audio driver for av5500-AE1 ????
The drivers are rather old but you can get them and more by using free driver update utilities like device doctor, drivermax and driver agent.
Sep 15, 2010 | Averatec 5500 Notebook
Averatec AV6130HS won't boot beyond the BIOS? It says SMART enabled but SMART failure - but there's no SMART feature in the BIOS.
The harddrive on the unit can be causing the problem. Disconnect the harddrive and check if the error code changes.
If the error changes , it a faulty harddrive.
Second , you can reset the BIOS to factory defaults and then check for error.Also let me know if there are any beep codes that hear when the SMART error is displayed
Thanks
Proton
Jul 11, 2008 | Computers & Internet
A kind of sound is coming from left side of touchpad in my new dell inspiron 1545 laptop problem:
Hi i'm Rain.
Ok there are only 3 sounds you will here from your computer laptop.
  1. You will hear the fan running.
  2. You will hear the HardDrive running.
  3. You will hear a CD-rom drive running. Wheather its a DVD or CD-RW.
You will need to turn it over and listen from the bottom.If there is venting then more than likely its the fan.
If its where the Media drive like i mentioned {DVD/CD-rom}. Then thats your sound. If the sound is coming from an area that you can't visually see something that it could be.
Then its your hard drive. To resolve the problem you will need to first locate and name the item that is making the sound. Follow the steps i have given you and locate the source of the sound.
Nov 22, 2009 | Dell Inspiron 1545 Notebook
Avertec 2300 laptop will not start. Have tried removing ram and battery. All I get is a blue power light and wifi light. HD clicks a couple times and cd drive spins if there is a cd in it. Fan does not...
Hi as for symptoms you have problems with you hardware. Basically thats means that one of the devices like harddrive or Video card fail to go through POST test. You can check your users manual for this very symptom
Sep 15, 2009 | Averatec Computers & Internet
I have a EMachine T6534 which won't start. I shut
I agree...sounds like a power supply problem. Typically a bad power supply will not damage the motherboard. It should still be functional.
Sep 02, 2009 | Computers & Internet
Suddenly getting boot failure message averatec 3200
this could be do to a bad connection to the boot device such as the harddrive.
I would try to boot from the cd rom using the OS disk.
Aug 07, 2009 | Averatec Laptop Keyboard for 3200 Series
Do you know what mobo the av5500-ea1 uses?
Download Driver Detective - > http://www.drivershq.com/
Jan 18, 2009 | Averatec 5500 Notebook
In need of an owners manual!
A user manual is available for free download at:
http://www.trigem.com/us/support/manuals.asp
It will ask 2 questions.....
your category is "all in one pc's"
your model is AVERATEC 5500 Series
Both responses are input through drop down menus.
The manual is a .PDF file readable through Adobe reader.
Jan 18, 2009 | Averatec AV5500-EA1 Notebook...
Will not read any disc.
Dear Kentrell,
Please try to run cd lens cleaner once ,maybe the problem is rectified , if no then please contact to any authorised service centre to replace this optical drive.
Regards
Sep 10, 2008 | Averatec 6200 Notebook
I need to replace my hard drive.
You have to remove the piece of plastic below the keyboard. the screws are on the bottom. becareful not to unplug anything else without notice how to replug the harddrive is behind the usb's. remove rubber spacer and unplug drive and then put everthing back...
May 12, 2007 | Averatec 3200 Notebook
Computers & Internet Logo
47 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
