Question about HP Pavilion dv6605us Notebook
Computer starts, attempts to load display, crashes, restarts.
It's really just as the title says.
My HP Pavilion dv6605us notebook crashes when it starts up.
Here's what happens.
1)Press power
2)Wait for display to turn on.
3)Display turns on for less than one second.
4)Computer immediately shuts off
5)Computer turns on by itself after 5 seconds.
The only way I can get the display working and booting into windows is by pressing some of the F-keys while the computer is activating the display. I have no idea why that works.
This is what happened before this problem.
I came home, and my computer was hibernated as usual.
I pulled a flash drive out of the usb while the computer was resuming from hibernation. (might be a factor)
The computer didn't boot up after several minutes, so I held the power button to force it down.
Retried, then it did the whole crashing process.
Only later did I figure out that it starts by hitting the F-keys.
It's fully functional after that.
But why can't I start up normal, without pressing F-keys???
    Problem Solver:
  • 14 Answers
You should do a system restore. It may have happened because of a system update, if your set up to receive them automatically.
Posted on Feb 22, 2009
I have a HP Pavilion dv6700 lapt op and recently I installed a new game on it. When I exited the game to install updates onto my pC and restart, the color resolution was extremely distorted and all of my...
restart your computer, hold down f8 untill you see the windows trouble screen, on that screen choose: safe mode then when windows loads repair your resolution and, remove the game from your computer then restart the computer again
May 18, 2010 | HP Pavilion dv6000z Notebook
Crashing compuer when i want to play games
Install Advanced System Care and let it do the rest and also check if the game requirements to find what you need.
Jan 25, 2010 | HP Pavilion DV6500T 15.4" NOTEBOOK LAPTOP...
Pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • Jan 21, 2010 | HP Pavilion DV7-1232nr Notebook
    Slow startup from boot
    run command prompt and write msconfig then enter
    go to startup tab and remove all unnecessary programs
    Dec 29, 2009 | HP Pavilion dv6605us Notebook
    My Hp Pavilion dv5000 crashed! XP cd displays error message!
    If you are facing this issue while installing Windows, Most probably there is an issue with the memory card. If you have two memory modules try to use one of the memory modules in each slot at a time. If you have only one memory stick then try to use it one by one on each slot. If you it does not work then probably you might have to replace the memory stick.
    Hope you find this information helpful.
    Thank you for choosing Fixya
    Dec 22, 2009 | HP Pavilion dv5000z Notebook
    Computer crashed and won't boot. restarts before it loads
    Firefox is a bad virus program three thing to do
    1st safe mode
    if not, reboot vista disk.
    If can't you need to go to bios to run cd to restart fresh program. but remember if this you loose all media.
    Dec 05, 2009 | HP Pavilion DV9500Z Notebook PC
    My cd/dvd driver is not working on my hp notebook
    Go to HP's support website, find your laptop, and get the missing driver, or find out what brand your cd/dvd drive is and go to the manufacturers website to get the driver. I hope this helps!
    Jul 24, 2009 | HP Pavilion dv9000z Notebook
    Wireless connection
    I had sortof the same problem with my hpdv8000 pavilion laptop..I ended up calling the phone company that I have my DSL with and trouble shooting with them the connection. I had to get rid of one connection and start a whole new one. Until it recognized the new connection. If you call HP they will charge you $9.95 to trouble shoot your computer. Both together were really helpful in getting my computer back up and running. I also had to add the drivers back in. The disc was bought from HP My computer crashes regularly..I believe that I got a lemon....Hope this helps..The info is online under HP.com
    Apr 04, 2009 | HP Pavilion dv6000z PC Notebook
    Blue-screen crashes
    i suspect the cpu and or fan is defective
    Jan 09, 2008 | HP Pavilion dv1000 Notebook
    Turning on, crashing ans screen
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00372718&lc=en&cc=us&dlc=&product=435618&rule=44570&lang=
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00035372&lc=en&cc=us&dlc=&product=435618&rule=44570&lang=
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00037733&lc=en&cc=us&dlc=&product=435618&rule=44570&lang=
    HP Pavilion dv6605us Notebook Logo
    127 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
