Question about ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card
What is a CHA_ fan slot ?. It is on my motherboard in front of my PCI slot
    Scholar:
  • 134 Answers
It is for a chassis fan (case fan) use it to **** hot air out of your case.
Alex
www.CAS411.com
Posted on Feb 22, 2009
Compatible video card
Any PCI-E video card will work.
Since this is an AMD motherboard,
there is not the Intel "Sandy Bridge" problem,
where the video card uses up all of the PCI-E lanes.
(A Sand Bridge CPU has only 16 PCI-E lanes)
Feb 17, 2014 | AMD GIGABYTE GA-K8N51GMF-9 NVIDIA GeForce...
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
Diagram of xps 630i motherboard connections
xps 630i motherboard layout
1 - unused fan connector
2 - power button (POWER_BTN)
3- front LED
4 - front panel USB connector (FP_USB)
5 - floppy drive (DSKT)
6 - master I/O board USB connector (MIO_USB)
7 - front panel IEEE connector (FP_1394)
8 - reset button (RESET_BUTTON)
9 - RTC reset jumper (CLEAR_ CMOS)
10 - password jumper (CLEAR_PASSWORD)
11 - internal S/PDIF connector (internal SPDIF)
12 - front panel audio (FP_AUDIO)
13 - PCI card slot (SLOT5 and SLOT6)
14 - PCI-Express x16 card slot (SECONDARY GFX SLOT4)
15 - PCI-Express x8 card slot (SLOT3)
16 - PCI-Express x1 card slot (SLOT2)
NOTE: This slot is not available in the dual-graphics configuration
17 - PCI-Express x16 card slot (PRIMARY_GFX_SLOT1)
18 - power connector (12V_ATXP)
19 - processor (CPU)
20 - processor fan connector (FAN_CPU)
21 - black memory module connectors (DIMM2 and DIMM 3)
22 - white memory module connectors (DIMM0 and DIMM1)
23 - main power connector (POWER)
24 - IDE drive connector (IDE)
25 - North bridge fan connector
26 - SATA connectors (SATA0-3)
27 - battery socket (BATTERY)
Dec 06, 2011 | Computers & Internet
What are the basic parts of the intel motherboard?
cpu, video card.hard drive, floppy drive cpu fan, power supply, is the battery good first for cmos, are all the connection right. is the power supply good.is the mem.right in the slots is it ddr or ddr2 do you have the right speed on cpu for board as well as mem , what is the intel board numbers on it d915 or what i need to know which board to find out anymore ok jim
Jul 04, 2011 | Intel Motherboard
Does anyone know if this motherboard has an AGP slot for video or is it only PCI MSI G71-MV31009-124 THANKS
Unfortunately, I can't find any specifications for that particular motherboard. However, there's a very easy way to tell if one of the slots is an AGP graphics card port!
Look directly at the motherboard so that the white, horizontal PCI slots are in the bottom left-hand corner. There will likely be 3 or 4 white slots, some of them may be occupied by PCI cards. Just above the top white PCI slot, there will likely be either a brown horizontal slot (that's your AGP connector) or a blank space where one might fit.
If you do not see an offset, horizontal brown expansion connector above the white PCI slots but below the fan assembly, your motherboard does not have an AGP connection and you will need to use PCI for graphics.
Hope this is helpful!
May 23, 2011 | Computers & Internet
What are the three expansion bus slots that are found on the mainboard?
  1. 1 x PCI Express x16 slot, running at x16 (PCIEX16) (Note 4)
  2. 1 x PCI Express x16 slot, running at x8 (PCIEX8) (Note 4)
  3. 3 x PCI Express x1 slot (All PCI Express slots conform to PCI Express 2.0 standard.)
  4. 2 x PCI slots
(Note 1) Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
(Note 2) The DVI-D port does not support D-Sub connector by adapter.
(Note 3) Simultaneous output for DVI-D and HDMI is not supported.
(Note 4) For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot. The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When PCIEX8 is populated with a PCI Express graphics card, the PCIEX16 slot will operate at up to x8 mode.
(Note 5) Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
(Note 6) Available functions in EasyTune may differ by motherboard model.
Feb 23, 2011 | Gigabyte GA890GPAUD3H AM3 Socket 890GX ...
Motherboard diagram
A Computer Motherboard Diagram motherboard-diagram-01.jpg Once you know what you are looking at, you can recognize the components on any motherboard layout. A computer motherboard diagram is very useful for when you need to replace motherboard, do motherboard upgrades, troubleshoot motherboard, or build your own computer.
  1. PCI Slot - This board has 2 PCI slots. These can be used for components such as Ethernet cards, sound cards, and modems.
  2. PCI-E 16x Slot - There are 2 of them on this motherboard diagram, both are blue. These are used for your graphics card. With two of them onboard, you can run 2 graphics cards in SLI. You would only need this if you are a gamer, or working with high end video / graphics editing. These are the 16x speed versions, which are currently the fastest.
  3. PCI-E 1x Slot - Single slot - In the PCIe 1.x generation, each lane (1x) carries 250 MB/s compared to 133 MB/s for the PCI slots. These can be used for expansion cards such as Sound Cards, or Ethernet Cards.
  4. Northbridge - This is the Northbridge for this motherboard. This allows communication between the CPU and the system memory and PCI-E slots.
  5. ATX 12V 2X and 4 Pin Power Connection Power Connection - This is one of two power connections that supply power to the motherboard. This connection will come from your Power Supply.
  6. CPU-Fan Connection - This is where your CPU fan will connect. Using this connection over one from your power supply will allow the motherboard to control the speed of your fan, based on the CPU temperature.
  7. Socket - This is where your CPU will plug in. The orange bracket that is surrounding it is used for high end heat sinks. It helps to support the weight of the heat sink.
  8. Memory Slots - These are the slots for your RAM. Most boards will have 4 slots, but some will only have 2. The color coding you see on the motherboard diagram is used to match up RAM for Dual-Channel. Using them this way will give your memory a speed boost.
  9. ATX Power Connector - This is the second of two power connections. This is the main power connection for the motherboard, and comes from the Power Supply.
  10. IDE Connection - The IDE (Integrated Drive Electronics) is the connection for your hard drive or CD / DVD drive. Most drives today come with SATA connections, so you may not use this.
  11. Southbridge - This is the controller for components such as the PCI slots, onboard audio, and USB connections.
  12. SATA Connections - These are 4 of the 6 SATA connections on the motherboard. These will be used for hard drives, and CD / DVD drives.
  13. Front Panel Connections - this is where you will hook in the connections from your case. These are mostly the different lights on your case, such as power on, hard drive activity etc.
  14. FDD Connection - The FDD is the Floppy Disk controller. If you have a floppy disk drive in your computer, this is where you will hook it up.
  15. External USB Connections - This is where you will plug in external USB connections for your case or USB bracket.
  16. CMOS battery - This is the motherboard's battery. This is used to allow the CMOS to keep its settings.
May 31, 2010 | E-Machines T2542 PC Desktop
My motherboard has fried: Albatron KM18G Pro 2003. It no longer seems to be available. For the computer to be exactly as it was before disaster struck, do I need exactly the same motherboard?
Well you do not need exactly the same motherboard. You need a motherboard that has the exact CPU socket, DDR slots and AGP or PCI slot.
Here are the specifications for the motherboard: Processor
- AMD Athlon/Athlon XP/AthlonXP Barton/Duron Processor
- FSB 200/266/333MHz
Chipset
- North Bridge: NVIDIA nForce2 IGP
- South Bridge: NVIDIA nForce2 MCP
- I / O Chip : Winbond W83627HF
Memory
- 3 DDR Sockets:
DDR200 to 400 non-ECC DDR SDRAM up to 3GB (Single Channel) or up to 2GB (Dual Channel)
Expansion Slots
- 1 x AGP 8X/4X slot (1.5V Only)
- 3 x PCI slots (PCI 2.2 compliant)
IDE Connectors 2 ATA133 channels (up to 4 ATA 133 IDE Devices)
Onboard I/O Connectors
- 1x Floppy Connector
- 2x USB 2.0/1.1 header (4 ports USB cable optional)
- 1x CD_IN header
- 1x COM Port header
- 1x S/PDIF in/out header (S/PDIF in/out cable optional)
- 1x CPU fan header with fan rotation detection function
- 1x System fan headers with fan rotation detection function
- 2x 5 pin system panel header (Intel spec)
- 1x 3 pin Power LED header
- 1x 4 pin Speaker header
- 1x Front audio header (Intel spec)
- 1x Case Open detection header
- 1x Wake on LAN
- 1x 4 pin TV-Out header
So you have to buy a motherboard that has Socket A, that support DDR I memories and has an AGP slot (for the video card).
If you need further assistance, just leave a comment. Thank you for using FixYa.
Apr 19, 2010 | Albatron nForce2 KM18G Pro (KM18G PRO 2.0)...
Gateway 506GR motherboard configuration
Item Description Item Description A Rear Panel I/O Ports M Front Chassis Fan Connector B Auxiliary 12-V ATX Connector N Serial ATA Interfaces C CPU Socket O Front Panel Header D CPU Fan Header P Front USB Connector E Memory Slots Q Front USB Connector F Standby Power Indicator LED R Front Panel IEEE-1394a Connectors G Floppy Disk Drive Connector S Speaker H ATX Power Connector T PCI Express x1 Connector I Parallel ATA IDE Interface U Front Panel Audio Connector J Battery V PCI Slots K Intrusion Switch Header W Rear Chassis Fan Connector L BIOS Configuration Jumper
Aug 21, 2009 | Gateway 506GR PC Desktop
I don't know the parts of the motherboard.
What motherboard would you like to know the layout of? Although, many motherboards are different, most of them have the same basic parts. From back to front, you have the communication ports; (usually from top to bottom, varies by manufacturer)mouse/keyboard, usb 1.0/1.1/2.0(make and model dependant) serial, paralell, vga/monitor, then sound: midi, headphone/speaker out, line out, microphone in.
then on the board, processor, somewhere near it, cache, i/o chip, north bride chip, wich is responsable for memory(ram) access, ide(cd rom/ hard drive access) ports and power connector/s,
memory slots
then the south bridge chip witch controls isa port(old), pci slot, agp/pci-e slot (video card) along with the cmos battery, bios, and various other slots/connectors (such as fan, power button and so on) and chips, wich vary by manufacturer and model.
Dec 27, 2007 | Computers & Internet
ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card Logo
61 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
