Toshiba Satellite U305-S7477 Notebook Logo
Posted on Feb 22, 2009
No Audio output device is installed
I have a Toshiba U 305 S7477 laptop and I have an issue - No Sound - Once i roll the mouse pointer over the speaker logo this is message - No Audio output device is installed
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Feb 22, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
6952
Points
30
Go here "http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download" to the toshiba website and download the correct driver.
Anonymous
Level 1:
Problem Solver:
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
4579
Points
17
Updating driver will usually work, try doing it manually if it does work auto.
But if not its usually more serious, it may be damage etc.
Regards,
Asitomani
The cursor on my Toshiba satalight pro laptop has completely disappeared, its brand new and was updated last night, this has been going on since this update
Some symptoms that occur with Toshiba laptop mice include jumping and vanishing pointers.
These situations have occurred after software upgrades have been made.
The problems can often be solved by following basic mouse troubleshooting methods.
Overall, Toshiba laptop mice contain the basic functions characteristic of the USB variety.
Function
The mouse device is used to move, open, delete and otherwise connect with items available on and through the computer monitor.
In Toshiba laptops and many others, the mouse pad replaces the point and click USB mouse device. This enables the mobile computer laptop to be more compact, portable and ready to use.
Features
The mouse pad on a Toshiba laptop is located in the middle, directly below the keyboard.
The control buttons, both primary and secondary are situated below it.
The primary key, on the left, represents the left-click button on an USB mouse device.
The secondary key on the right represents the right-click button on an USB mouse.
This button is used to pull up the short menu of an item after selecting it.
Update Keyboard Driver Many Toshiba mouse issues can be solved by updating the driver.
The driver enables the mouse to function properly. Update the keyboard driver first to increase mouse and keyboard device compatibility.
To complete this task, click "Administrative Tools," accessible from the Start menu.
Next, click "Computer Management," and then select "Device Manager."
Click the "Keyboards" expansion node to bring up the list of installed hardware, and then right-click on the keyboard that is in use.
If the "Update Driver" option is available, click on it.
Otherwise, select "Properties," go the "Driver" tab and press "Update Driver."
Device Manager is a useful tool to update, rollback or uninstall incompatible drivers.
Update the Mouse Driver
Update the mouse driver by following most of the instructions in the above section, "Update Keyboard Driver."
However, after selecting "Device Manager," click the expansion node next to "Mice and other pointing devices."
Select the current mouse device in use and right-click on it.
If the "Update Driver" option is available, click on it. Otherwise, select "Properties" and go to the Driver tab and press "Update Driver."
Check BIOS Fixes
Some older Toshiba laptop models require BIOS (Basic Input/Output System) fixes.
Most of the downloads are available from their website.
Since, the BIOS chip is the liaison between the hardware and software, any issues should be addressed promptly.
Symptoms, such as erratic mouse behavior or the pointer disappearing, are signs of a need for a BIOS fix or driver update.
Compatibility
Toshiba and most Microsoft Windows products are compatible.
This is vital when it comes to updating necessary drivers needed for continual operating system function. The service packs they approve of are listed on their website.
http://support.microsoft.com/kb/283658
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/navShell.jsp?cf=su_winos
2helpful
How can I disable the pinch zoom on my Toshiba Satellite L675D-S7107? When I'm scrolling up or down, sometimes the pointer turns into a black cross with arrows at each end and the text becomes resized. ...
Try going to Control Panel - Hardware and sound - mouse. Once you have the menu for the mouse open, go to device settings. Click settings, and all of the advanced controls for the functions of your mouse pad can be found there.
My volume mixer in my laptop doesn't work.there's an X sign on it..and it says no audio device output is installed what should i do
Sometimes Windows Update will replace the manufacturers custom drivers with the newest generic ones. Download and install new drivers from the manufacturer.
I keep getting the message 'no audio output device'
1. Right click on Mycomputer, select properties
2. Select hardware
3. Select Device manager
4. double click on the sound,volume and controller
5. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
6. then select Action from the menu bar on the top and select scan for hardware changes
**** after doing this.. you can check the follwoing steps for trouble free ******
7. double click system device
8. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
9. then select Action from the menu bar on the top and select scan for hardware changes
10. then it will start scanning your new hardware and ask for the installation drivers.
1helpful
Noisy out from headphone jack
Lift your keyboard and remove the centre mouse stick cable ( the one connected to the mouse control stick in the middle of the keyboard ) interference should stop
Sound
Check toshiba website for the drivers with your system model..
2answers
Mouse pointer stalls
Here are some possible reasons why your Toshiba Satellite P15 mouse pointer is sticking or stalling when the laptop is on AC power:
Driver issue: The touchpad driver may be outdated or corrupted. Try updating the touchpad driver to the latest version.
Hardware issue: The touchpad itself may be faulty. If the problem persists after updating the driver, you may need to replace the touchpad.
Battery issue: The battery may be causing interference with the touchpad. Try removing the battery and see if the problem goes away.
Software issue: There may be a software conflict that is causing the problem. Try disabling any recently installed software to see if the problem goes away.
Here are some troubleshooting steps you can try to fix the problem:
Update the touchpad driver:
Download the latest touchpad driver from the Toshiba website.
Uninstall the current touchpad driver.
Install the new touchpad driver.
Disable touchpad enhancements:
Go to Control Panel > Hardware and Sound > Mouse.
Click on the "Device Properties" tab.
Uncheck the box next to "Enhanced pointer precision".
Clean the touchpad:
Turn off the laptop.
Dampen a lint-free cloth with alcohol and gently wipe the touchpad.
Let the touchpad dry completely before turning on the laptop.
Update Windows:
Make sure your computer is up to date with the latest Windows updates.
If you have tried all of these troubleshooting steps and the problem persists, you may need to contact Toshiba customer support for further assistance.
Toshiba sat 305 s7477 shut down while on the net,will not restart
In that case have the jack checked at a good computer shop. You need to have the jack resoldered as soon as possible.
1helpful
5answers
How do i install audio output device
No Audio Output Device Installed
Some users have been experiencing problems with a "No Audio Output Device Installed" error when trying to play music, or when hovering the mouse over the speaker icon in the system tray. You may get a white X in a red circle to indicate this error.
Go to the device manager by pressing WINDOWS KEY + R to go to the run menu, and then run "devmgmt.msc".
From here, select your malfunctioning audio device(s) and make a note of the driver name. Then, right click on it and select Uninstall. This will remove the audio drivers from your system.
Once this is done, re-load the drivers for your sound card from the CD your manufacturer gave you with your PC or sound device. If you cannot find this, search for the driver on the manufacturers website using the driver name that has been written down. No Audio Output Device Installed
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
