Question about Homelite Mighty Lite Lawn Trimmer
Homelite trimmer has two black hoses in fuel tank, both have severed at entry point to fuel tank. how do I fix or replace? Also, filter on one has come off hose - petrol has softened has destryed hose
  • 398 Answers
SOURCE: Fuel filter.
well i can tell you you gotta pull the filter with hose attached th ru the gas filler cap. i usually am able to get it when i tilt it towards the cap and grab it with some long bent needle nose.
Posted on Mar 26, 2009
#1 Taper
  • 1040 Answers
SOURCE: Replaced fuel lines and pressing the primer pump does not feed gasoline to the car.
Sounds like you have the fuel lines switched around. The fuel line closest to the primer bulb will be the shortest line. It only goes 1" or so into the tank. The other line will be the longest line, and sometimes the smallest in diameter of the two depending on the size of your trimmer, and must rest comfortably on the bottom of the tank.
Jim
Posted on May 26, 2009
#1 Taper
  • 1040 Answers
SOURCE: how do you replace the fuel filter on a homelite
Take the old piece of fuel line and have the vendor match the size. Buy 1 ft. so that you have a little extra to work with. Cut fuel line at an angle. This will allow for easier insertion into the hole in the gas tank. Feed the line through until you can pull it out of the opening where the gas cap is. Cut the line off square. Attach the fuel filter. Pull the line back through until it rests comfortably on the bottom of the tank. Assemble the trimmer. You will then get a more accurate measurement to the carburetor.
Jim
Posted on Jun 11, 2009
  • 54 Answers
SOURCE: Primer button on homelite gas trimmer
It's possibly the filter, can't help there. I would check for a split line or loose connection between the tank and bulb and even splits in the bulb itself.
Posted on Apr 26, 2010
rycgl
  • 1545 Answers
SOURCE: Homelite UT2680 trimmer fuel line (25cc engine)
You can go to a small engine repair shop, parts shop or look on eBay and they should have the fuel lines you need. Not very expensive, about $1.00/foot for new Tygon lines. You are way overdue for replacing yours. The ethanol in the gas does a job on them.
Posted on Jun 09, 2010
How to replace the fuel tank
308181004 Homelite Ryobi String Trimmer Fuel Tank ...
www.amazon.com > ... > Replacement Parts
Amazon.com, Inc.Amazon.com: 308181004 Homelite Ryobi String Trimmer Fuel Tank replaces ... Ryobi CS30 & Homelite C300 Trimmer Replacement (2 Pack) Air Filter # 98760-.
Oct 07, 2015 | Garden
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Internal line in gas tank came loose
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 23, 2012 | Homelite Mighty Lite Lawn Trimmer
Model ut21004 homelite gas weedeater want stay
fuel issue, look for cracks or holes in the two lines from tank to prime bulb, check prime bulb, adjust/clean carburetor, may also need to check filter inside tank it is connected to the bigger of the two hoses. Tim
May 30, 2011 | Homelite Mighty Lite Lawn Trimmer
Hello i have a question on changing th fuel
how to change fuel filter in gas tank remove line from carb pull line through the fill hole in gas tank remove filter replace & pull hose back up reconnect to carb & your done
Jun 27, 2010 | Homelite Mighty Lite Lawn Trimmer
Jun 09, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
Apr 24, 2010 | Homelite Mighty Lite Lawn Trimmer
Fuel line on Homelight
the filter in the gas tank that line goes to carb
and the one that line goes to bulb
Jul 18, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
How do you replace the fuel filter on a homelite st 145? the hose snapped and the filter fell into the fuel tank. Thanks
Jim
Jun 10, 2009 | Homelite Garden
Fuel filter.
Mar 25, 2009 | Homelite Garden
Homelite Mighty Lite Lawn Trimmer  Logo
376 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
