Question about Asrock P4I45GV R5 Motherboard
Motherboard not working
One chip bust for high voltage chip near cmose battary
  • Roberta Smith
    Roberta Smith May 11, 2010
    if you mean burned because of incorrect voltage... buy a new motherboard
  • 60 Answers
You have nothing to do. If you have warranty, try the provider. May be they will not accept your board. Better way is that "buy a new board".
Posted on Feb 22, 2009
How to clear cmose in priya mother board
Remove the cmos battery on the motherboard for 30 seconds and put it back in. The Bios will be cleared.
Aug 22, 2012 | Computers & Internet
Have a dell inspiron 5100 notebook and I forgot the admin password that is embedded in a chip on the motherboard
just open yr cmos battary on motherboard around 5 second, then your password will reset.
regards
Jul 04, 2011 | Dell Inspiron 5100 Notebook
Hi Have brought a second hand Acer aspire 5000 laptop for a $100.00 dollars for my sons birthday was told battary light was flashing amber and it needed new battary as wouldn't run of power they said it...
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Aug 29, 2010 | Acer Aspire 5000 Notebook
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
Hello i replace my small ups 650VA battary with a car battary,when i charge the car battary with an external charger does this affect my ups if it remain connected with the battary
Should not be a problem - just make sure the charger is a good one, and avoid over-charging. Once the battery is fully charged, the UPS should maintain it properly. Also, check the water level once a month - dry cells will kill the battery.
May 04, 2010 | PC Chips M871G Motherboard
I can't run my pc welly.
THE CPU IS NOT COOLING THE CPU PROPERLY, IS SHUTTING DOWN SO YOU DONT BURN UP THE MOTHERBAORD OR CPU MELT DOWN.
Feb 09, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
No Beep, Power supply problem?
it also came from power supply,but i suggest that u need to reset bios first, if problem not solve remove cmose battery for 12 hour then check
Feb 12, 2008 | ASUS P4S333-M Motherboard
MY PC IS NOT POWERD ON
If you are pressing the battery, not just touching it, then when you remove your hands, the computer freeze.
Remove the battery and check if the battery holder is in good order..
Correct the problem if you can, or ask help from a computer technician, Now if everything is okay check the battery voltage if it is 3 volts. if below 3V replace the battery with a new one.
Jan 30, 2008 | ASUS P4B266 Motherboard
Starting UPS
hi, guies
                 First all of  look in battary condition of ups, and that
battary sencing voltage circuit
 In your second case, please replace lithium cell with same and reconfigure the bios setup
Oct 22, 2007 | Computers & Internet
Asrock P4I45GV R5 Motherboard Logo
44 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
