Question about HP OfficeJet G85 All-In-One InkJet Printer
Press Enter to align cartridges
It is a HP OfficeJet G85
    Genius:
  • 2,120 Answers
Replace both ink cartridges.
Posted on Feb 23, 2009
G85 officejet keeps saying press enter to align cartridge
To bypass the cartridge alignment press and hold the Enter button, and then press Menu.
Oct 08, 2013 | HP PSC 2210 All-In-One InkJet Printer
Print Alignment Page continues to fail
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
My HP DeskJet g85 says "cartridge alignment has failed"
Here is the weblink which helps you in resolving cartridge alignment failure issue:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00657&cc=us&lc=en&dlc=en&product=60399
Click on the link above and follow all the steps give in web document.
Thank you.
Dec 06, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Cartridge
Easy! Just open the front latch by lifting up, unlock the cartridge you are replacing, and snap in a new one. I caution you to use only HP new cartridges for best results. You can find a pretty decent price on them at www.amazon.com. Also, reset your ink counter in the HP Image Zone to reflect the new cartridge install. Then run the align cartridges option and you're all set. Hope that helps. If so, please rate this solution. Thanks!
Sep 13, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
OfficeJet G85xi cartirdges will not align
Could be one of two things....
1 - you may have bad cartridges (usually the color)...when the machine does an alignment it looks for specific marks on the paper...ie..green check marks before each line etc...if the correct marks are not there you will get an alignment failure...if the green check marks are there etc then you have a different problem...first replace color cartridge with a HP Brand cartridge
2- spot sensor on the side of carriage is not working...this is the little blue/green light that comes on during alignment. Its what reads the markings on paper so if the markings are correctly there and you still get this error then the spot sensor needs to be replaced. Simple fix that u can do. We sell the spot sensor for $15
Inkworks
866-381-0541
Aug 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Printing
The printer hp officejet v40xi is asking for a cartridge alignment. When I press enter the printer does nothing want take paper or engage the paper nothing
Aug 12, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
ALIGN CARTRIDGES
Unplug the printer, wait 30 second and plug it back in. Sometimes that resets it.
Jul 23, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Alignment problems
Here's the deal with the cartridge alignment page....the machine will spit out a series of black lines mixed with yellow ink and at the beginning of each of these lines is a "Green" check mark. The carriage moves back and forth over these lines and green check marks and reads them by use of what is called a "spot sensor" that resides on the right side of the carriage assembly. This is usually noticed by the blue ray of light that shines out of it. So if you are getting an alignment failure one of two things is happening....1)You've have got a bad cartridge (usually the color) and it is not laying down the right colors, specifically the green check mark or 2)You've got a bad spot sensor...even though it may still be shining the blue light, the sensor board can't process the information. Its an easy fix either way.
Inkworks
Apr 25, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
270 people viewed this question
Seeker5211
Seeker5211
