Question about Garden
NO COMPRESSION MY ROVER MOWER WITH BRIGGS & STRATTON CLASSIC 37 ENGINE HAS LOST COMPRESSION WHILE MOWING, HOW BLOWS BACK THROUGH THE CARBY & HAS ONLY GOT 10PSI COMPRESSION ,I HAVE REPLACED THE HEAD GASKET & IT HAS 7TH CLEARANCE ON BOTH VALVES
  • gregcarpente Feb 22, 2009
    the mower was working fine ,but all of a sudden it stopped
    it had plenty of oil & airfilter was clean , is there a decompression lever internal that could have broke ?it just spits back through the carby when i try to start it
  • 62 Answers
SOURCE: What oil to petrol ratio does this engine run on?
http://www.briggsandstratton.com/maint_repair/manual_and_more/
Go here and enter the proper information, and see if they have the manual available.
Posted on Apr 18, 2009
#1 Taper
  • 1040 Answers
SOURCE: i have a briggs and stratton classic 3.5 mower,
You need to replace the diaphragm in the carburetor.
Jim
Posted on Jun 13, 2009
lester482529
  • 226 Answers
SOURCE: briggs and stratton engine smoking
if your oil level is to high it will do this. i would drain and refill the oil to oem specs slowly as not to overfill so it doesn't blow over the top of the piston.hope this helps
Posted on Jun 25, 2009
s_s_m_o_k_i_
  • 162 Answers
SOURCE: briggs and Stratton mower engine carburetta
you can download a manual for it here
http://www.briggsandstratton.com/maint_repair/manual_and_more/doclist.aspx?category=Engines&manual_type=Operator%20Manuals&menu=nav3&subMenu=3
Posted on Aug 01, 2009
  • 124 Answers
SOURCE: briggs and stratton quatum 5 hp lawn mower engine
More than likely you have a valve that is not seating properly or you have a sheared flywheel key that is throwing the ignition timing off.
Posted on Sep 20, 2009
Testimonial: "very helpful! thanks"
Rover QuantumXTL 50 mower wont idle
clean the carby or could have bent governor arm where spring goes
Feb 03, 2013 | Briggs & Stratton Briggs Stratton...
17.5 hp briggs and stratton mower - mowing fine - stopped to gas up - will not start back up - back fires a few times while turning motor over
sounds like you may have a broken valve spring. Do a compression test as you crank it. If the valve spring is broken, you will get nearly zero compression, it will turn over very easily and this would explain a couple of backfires.
Sep 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton lawn mower 4 stroke engine
did you hit something while mowing the key way between the flywheel and crank shaft might have sheared it will act like the blade is missing pull back on you while pulling the rope
May 25, 2012 | Briggs & Stratton Briggs Stratton...
Was mowing with riding mower was running fine started missing and black smoke coming out of exhaust stopped mower immediatetly oil in carb now and when try cranking it just cranks and cranks not firing
Pull plug and check compression. When cranking see if bottom pulley turns from engine. If compression is below 90 psi it won't start and you have an internal problem. Stopped mower immediately sounds like motor blew. Also check side of motor for cracked block, Good luck.
Mar 21, 2010 | Briggs & Stratton Garden
42' Poulan 20 hp-I was mowing & there was a loud pop,mower ideled down & quit. It will turn over but won't start.
Check compression, should be over 90psi to start. And check spark. The loud pop I am going to assume came from the exhaust, which if you lost spark would cause excess gas to ignite. Causes of no spark, bad coil, or defective and or damaged safty swith.
Mar 13, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Mower stutters when i turn up to full throttle.
Hi if it is older than 2 years it will need a new diaphram and gasket under carby you will also need to clean out the fuel bowl in the top of the tank this should fix your problem.
Apr 03, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
111 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
