Question about Ingersoll Rand 231C-KS - 1/2" Super Duty Air Impact Wrench Kit With Flip Socket Set And Bit Dr - - Ingersoll-Rand - IR 231C-KS
Oil leak have a 5 hp compressor which is pushing oil through the crankcase breather what could be the prob and how to sort it out
    Scholar:
  • 104 Answers
First check the oil level. It should not be overfilled. Is the compressor level?
If above is all OK, change the oil with the recomended ok. Check the IR web site for an approved oil. It is important that the right oil is used.
If you still have a problem it sounds like a time for piston rings.
Good Luck
Posted on Mar 19, 2009
Mac2400 leaking air at oil breather hole
I have read both your questions and after taking both into consideration it sounds like it needs new piston rings. On a gas engine it is called blow by but both have a piston with rings on them, as they wear the end gap gets bigger and bigger allowing compressed air to bypass the rings into the crankcase where the oil is, the breather is there to allow air from the room to enter and exit as the piston goes up and down to avoid pressure or vacuum in the crankcase, the air on the top side of the piston is supposed to go into the tank but in your case some of it is going around the piston rings and into the crankcase building pressure and blowing oil out. There is not much inside a compressor like a gas engine, taking the head off and the oil pan should let you take off the connecting rod bolts and push the pistons out the top. This answer is based on the two comments of cant build all the air pressor and it is blowing oil out the crankcase breather. If you hit the 80 psi and unplug the compressor can you hear air coming from the limit switch box that the power cord goes into ? I will wait for your answer to continue.
Mar 23, 2016 | Makita MAC2400 Electric Powered Air...
When I plug my Magnum 2 HP 5 gallon compressor in, it blows out oil out of the red plug that you put oil in
Could be you are filling it too much, such as to the top of the oil hole instead of the bottom of the hole. I suggest you check the manual.
Perhaps the compressor isn't level or perhaps the crankcase breather is blocked or not working properly or perhaps there is too much piston blow-by for the breather to cope with.
Feb 03, 2015 | Magnum Air Tools & Compressors
Oil cap and dipstick covered in creamy sludge, is this breather prob as not losing any water
Yes, it could be that a plugged up Positive Crankcase Ventilation (PCV) valve or engine crankcase breather (with filter) is the cause allowing moisture to condense in the crankcase. However, if the valve and breather are okay, a cylinder compression test should be done to verify that the cylinder head gasket is not leaking. Regardless, the engine oil should be drained and the engine flushed with clean oil and an appropriate crankcase flush additive. Entrained water in the oil (the creamy sludge) will damage engine bearings quickly.
Mar 05, 2011 | Volkswagen Golf Cars & Trucks
How do you clean breather hole on oil breather cap on air compres
Yep - that is what I would do ... find it and run something through it --- maybe blow a little air through it.
Dec 30, 2009 | Air Tools & Compressors
After warming up my suzuki 750 gsx leaks a oil/fuel mixture out of the air cleaner
You need to service the crankcase breather system. Basically, this means taking apart and cleaning all the goo out of the area where the crankcase breather tube goes into the air box. Also check the air filter for oil saturation and replace if needed - and clean any accumulated oil from the inside of the air filter box.
Nov 07, 2009 | Suzuki GSX 750 EF Motorcycles
1979 briggs and stratton 11 hp how to fix
If it is, as you say, a 1979 or so engine, the crankcase breather could have well worn out. This will cause the oil burning and blowby. Replace the breather as an assembly, they are cheap and available from any Briggs dealer. The leaks are probably loose bolts and/or bad gaskets. You will just have to figure where the leaks are and replace the appropriate gasket. The breather could also cause the leaks so do the breather first then run it for a while to see if it is still leaking
Sep 20, 2009 | Garden
Oil in air breather
sounds like you have too much oil in the engine (should normally be around 500-600ml when there is too much oil, it gets past the piston rings and pushes it through to the head.
May 20, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
TRACTOR BLEW WHITE SMOKE, AND STARTS TO SPUTTER
Start with making sure your oil lever is not over full. If it is it may be getting into the crankcase breather hose that goes to the carburetor hence the white smoke. Sometimes also you can blow a gasket in the breather system and it will do the same. Check for oil leaks in the breather system. Hope this helps. donnyb60
Mar 02, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
WILL NOT BUILD PRESSURE
Many craftsman compressor are built by champbell hausfeld using a dry type of cylinder and piston (no oil, no crankcase). If dry type, check for worn cylinder and piston ring. Pieces of the vinyl ring can jamb between the reed valves in the head causing air to escape from the intake. If your compressor has a crankcase and oil, check for broken reed valves in head. Spray soap solution on hoses, checkvalve, drainvalve, and fittings to check for leaks. Most likely problem is reed valves broken or open. Parts are available from sears or match parts to chpower.com. enjoy
Nov 26, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Ingersoll Rand 231C-KS - 1/2" Super Duty Air Impact Wrench Kit With Flip Socket Set And Bit Dr - - Ingersoll-Rand - IR 231C-KS Logo
104 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
